autoken
9
12,954
VOLVO PTT2.40 VCADS
VOLVO PTT2.40 VCADS
This is what I did:
1 - Download the ptt 1.12 image
2 - Load the image on a virtual cd drive or burn it if you
prefer that.
3 - Run setup.exe at the cd root. Use a 6 digit number as
client id (Example: 654321)
4 - Let it finish (obviously) and restart
5 - Check if the sql server icon is present at the tray. If
not, install sql server 2005 managenemt studio (thanks to
gtchorik for this step)
5 - Run the chuck norris patch (run the .bat, if it is
compressed with rar or zip you need to uncompress all the
files)
6 - Run ptt with m333422 and offline mode, other way it
won't work
7 - Success !
Machine config: Win7Ult, no need to use xp compat. It didn't have vcads installed before, so I guess you have to run the cleanup utility to ensure a clean install. Now I'll try it on a winxp virtual machine to see if it works the same way.
Master
Cleaner
720
4,261,093
#3
hello,
Download ptt 1.11 I have not successfully installed the id m333422m, can you help me
Dear you,
1. This is just the KG not full package installation
2. it is old version
3. Please check for new version here
VOLVO PTT 2.04.87+KG+DEVTOOL 2016 Full
http://www.autorepairmanuals.ws/threads/volvo-ptt-2-04-87-kg-devtool-2016-full.37990/
Volvo PTT v2.04.55 [04.2015] Unlocked Full + Instruction
http://www.autorepairmanuals.ws/threads/volvo-ptt-v2-04-55-04-2015-unlocked-full-instruction.35870/
Volvo PTT 2.04.40 Unlocked Full + Instruction
http://www.autorepairmanuals.ws/threads/volvo-ptt-2-04-40-unlocked-full-instruction.35415/
salvatre_702
1
2,634
#4
hello,
Dear you,
1.-I need this version to work with old volvo, which has interface support 9998555
2,. This download is exposed as a solution to a need, on the contrary disappoints.
3.-I am looking for ptt 1.10-1.11for old volvo, can you help me please
4.- thanks
salvatre_702
1
2,634
#5
Dear you,
dear you
Apparently did not include the most important bat file 1.11
salvatre_702
1
2,634
#6
VOLVO PTT2.40 VCADS
This is what I did:
prefer that.
files)
won't work
7 - Success !
dear
I downloaded this activator, it does not work, you have not included bat file 1.11
salvatre_702
1
2,634
#7
VOLVO PTT2.40 VCADS
This is what I did:
prefer that.
files)
won't work
7 - Success !
dear
