Volkswagen ETKA International [07.2016] Full
Language: English & Ru
Type: ETKA International spare parts
Win: Windows XP; Windows Vista; Windows 7; Windows 8
CPU: Pentium/Athlon 1.8 GHz or higher
RAM: 512 MB of system memory
Hard Drive: 5 GB of available space
DVD-ROM
Year: 07.2016
Link high speed download
The electronic catalog ETKA contains full information on spare parts and accessories for cars Concern VAG (VW, Seat, Skoda, AUDI), including minivans.
autorepaircranes2016@gmail.com
A huge "thank you" for the loader and for the help with this release goes to algeni.
A huge "thank you" kbatpo
A huge "thank you" tosha2042
A huge "thank you" for the working x64 and x32 Multikeys goes to http://testprotect.com.
ATTENTION!
The loader demands input of the password.
The key for the standard version
Key: QTQ-8UWHZ-3EAWY-F7K6W-LEBQP-3V9LK-3V5DM-TJ99B-HYPAR-AZDRB-DVB35
The key for the full version with support of reading VIN-files from the FGST folder for ETKA 7.4/7.5 can be got on algeni@yandex.ru
In the Carscats folder files for support and control of the Carscats service. Probitiye of VIN codes online through local Etka 7.5
This release is intended to be used strictly by the ****, LLC clients for
educational and training purposes only and is neither meant nor suited for commercial
use. Commercial users should procure an official spare parts application such as
ETOS https://www.etosinfo.com or visit www.partslink24.com.
Microsoft .NET Framework is prerequisite and can be found at http://rutracker.org/forum/viewtopic.php?t=3808372.
Microsoft Visual C++ 2005-2008-2010-2012-2013-2015 Redistributable Package Hybrid [32-64]
is highly recommended and can be found at http://rutracker.org/forum/viewtopic.php?t=4594892 or https://download.microsoft.com/download/5/B/C/5BC5DBB3-652D-4DCE-B14A-475AB85EEF6E/vcredist_x86.exe
You can find links to VIN look up services in the "Ïðîáèòèå âèíîâ îíëàéí" folder.
This release contains the most recent updates. The base prices and the regional
setting are preset for the Russian market.
Attention! The installation process takes a long time especially that of the VIN
database and the computer might appear to be frozen at times. Also please
disable the antivirus protection for the whole duration of the installation
process.
ETKA is preset to be installed into the C:\ drive by default. If you intend to
install it into a hard drive labeled differently you will need to run the
relevant ini.exe file from the archive. For example, if you need to install ETKA
into the hard drive labeled as E:\ you will need to run the "ini.exe" file from "ETKA
7.3+7.4+7.5 (1126) International 07.2016\INI ôàéëû\International\E\" directory,
point it to the drive into which ETKA has been installed and confirm file
replacements if any. Also you will need to replace the letter "C:\" in the preset path for
the desktop icon "ETKA 7.x 2016" located inside the "ßðëûê íà ðàáî÷èé ñòîë"
folder with the letter corresponding to the drive into which you will be
installing the program. In addition please keep in mind that the file "LexHdl5.dll"
will be placed into the newly created "\Windows\System\" folder in that drive at
the time of installation. You will need to move this file to the C:\ drive.
Installing under Windows XP,7,8,10 x32
1. Uninstall any previous versions of ETKA if any and reboot the system.
2. Start the instalation process by running "ETKA.exe" from the "ETKA
International" folder. Set the path for the files to be unzipped to "C:\" -
the root directory of the C:\ drive - and the files will get unzipped into the
newly created "C:\ETKA\" folder. All of the needed paths have already been
preset; agree to any offers to overwrite the existing files.
3. Run "ETKA Loader.exe" from the "ETKA Loader" folder
4. Run "hardlock.exe" from the "\x32\Hardlock\" folder. Run "0000750A.reg" and
then "install.cmd" from the "\x32\MULTIKEY32" folder. No errors should pop up
and the driver should install correctly. Reboot the computer.
5. Run "registerControl.bat" and "registerControl .Net v4.0.bat" from the
"C:\ETKA\VWAU\RosyVisionControl" folder.
6. If you are so inclined you can also optionally install the VIN database for
v.7.3 and the Tnrpics pictures for v.7.3 and v.7.4 from their corresponding
folders. As always set the installation path to "C:\".
Installing under Windows 7,8,10 x64
1. The installation is similar to the one for Windows XP x32 with the exception
of the Hardlock and the Multikey which are located in the x64 folder along with
the corresponding instructions.
Installing under Windows XP x64
of the Hardlock and the Multikey which are located in the x64 folder.
The "Ïå÷àòü" ("Print") folder
Should you see garbled text at the time of printing please run "Êîäèðîâêà
øðèôòîâ ETKA äëÿ ïå÷àòè.reg" from the "Ïå÷àòü" ("Print") folder.
Should you encounter a printing error please replace the "Formular" folders for
every car brand of your version of ETKA.
You can update the price tags for the International version and for the ETKA
databases, disable mandatory updates, switch between different versions and
disable graphic files' version notifications in version 7.3 by clicking the
algeni loader icon on the desktop. You can find tuning instructions for the
loader in the "c:\ETKA\VWAU\Updater\Readme.Rus.pdf" folder. The most recent loader version is
available for download at
http://rutracker.org/forum/viewtopic.php?p=68629073#68629073.
A few recommendations
1. ETKA 7.3 is set up to look up VINs in the hard drive; no changes are necessary.
2. The AHCI mode offers the quickest hard drive performance.
3. Enable the "read only" mode for new VIN files and place them into the
"C:\ETKA\VWAU\USERDATA\FGST" folder. Do not open the folder itself otherwise the
program performance will be severely degraded.
4. VIN filtering works only for cars which model year is marked with a green dot.
5. For all other cars the parts selection is based on PR-codes from the decoded VIN.
6. Audi and VW VINs can be decoded from 1993 forward; for Skoda from 1999
forward and for Seat from 1995 forward.
7. If you encounter the "Error AA" while trying to install updates from the
"Áèáëèîòåêà" folder please copy the "LexHdl5.dll" file into the "windows\system"
folder.
- Volkswagen 2020 4.07GB Package DVD PDF Repair Manual, Workshop Manuals And Wiring Diagrams
- Volkswagen ETKA International [03.2016] VW-Seat-Skoda-Audi Full Instruction
- Volkswagen Flash Disc 04.2016
- Volkswagen ETKA International [10.2016]
- Thread Modes ABS/ESP CALCULATOR
- VOLKSWAGEN FULL MODELS 2023 MANUALS DVD EN PDF
- Volkswagen Car Maintenance Repair Manual, Circuit Diagrams 30.4 GB PDF
