526
1,883,031
VCDS lite VAG-COM 409 + USB Drive
Download this document, you need 200 Gallons
(Registered & Activated)
Pass: www.autorepairmanuals.ws
VCDS-Lite is a Windows-based Diagnostic tool for VW/Audi/Seat/Skoda for non-dongle interfaces. With VCDS-Lite you can do an automatic scan of all controllers for Fault Codes. Also, you can select an individual Control Module such as Engine, ABS or Airbag.
Works with simple K-Line/KL line/KKL-Line/VAG-COM 311/VAG-COM 409 interfaces (ISO 9141-2 protocol)
Instructions:
1. Unzip.
2. Run from the loader.exe file
If you run from the VCDSLite.exe file, the program will run unregistered and not activated.
ADEL27
300
#5
Salut à tous ,
J’ai bien réceptionné VCDS lite VAG-COM 409 + CRACK + Clé USB que j’ai réussi à l’utiliser sauf le tdi timmer, le graph qui m’indique en commentaire j’ai: No data from vag-com. dirigez-vous un groupe?
qu’en pensez vous?
