VCDS lite v.1.2 Full Activated
- Download this document, you need 300 Gallons
VCDS-Lite is a Windows-based Diagnostic tool for VW/Audi/Seat/Skoda for non-dongle interfaces. With VCDS-Lite you can do an automatic scan of all controllers for Fault Codes. Also, you can select an individual Control Module such as Engine, ABS or Airbag.
Works with simple K-Line/KL line/KKL-Line/VAG-COM 311/VAG-COM 409 interfaces (ISO 9141-2 protocol)
Instruction Installation:
Important!
Disable antivirus software (false positive) before start install !
"For activation need to make full Auto-Scan in a car and then it will be fully registered/activated"
VCDS-LiteWindows-based Diagnostic Software
for VW / Audi / Seat / Skoda
for generic 3rd-party interfaces
VCDS-Lite is our low cost solution for older (pre-2006) VW-Audi Group cars that do not require a direct CAN diagnostic connection.
The free shareware version does quite a lot and it's, well, free.
The fully registered version does pretty much everything the older dealers' tools could do on those cars, but even when fully registered, it will not have quite all of the functions that the full (non-lite) version of VCDS would provide.
Some of the differences between versions and between the free VCDS-Lite Shareware and the Fully Registered version:
Free Shareware:
Cannot do AutoScan
Won't display text for all fault codes
No Basic Settings (so no TBA, Xenon leveling, etc or checking timing on TDI's)
No Adaptation Saving (so no changing of locking/lights/horn behavior)
No Output Tests
No tech support from Ross-Tech Limitations of VCDS-Lite compared to VCDS even if Fully Registered:
No Generic OBD-II
Won't work with CAN-Bus vehicles
Fewer fault code definitions and label files
No built-in Activation (you'll be limited to a single PC)
No Advanced Measuring Blocks
No Acceleration Measurement
Important!
Free Shareware:
Cannot do AutoScan
No Output Tests
No Generic OBD-II
- Delphi Cars & Trucks DS150E [R3.2015] Full + Instruction
- The National Locksmith InstaCode [06.2016] Full + Instruction
- Wurth WoW 5.00.08 [11.2014] Full + Instruction
- Delphi Cars & Trucks DS150E [R1.2015] Full Unlocked + Instruction
- Heavy Truck Service 2013 (HT13) KG
- Latest Paccar DAVIE 4 Service Tester
- Hyundai Himsen Engine Instruction Manual
- How can I change language in Wurth Online World 5.00.12
- All Freightliner Workshop, Repair and Maintenance Manuals
- CD Hyundai Heavy Duty Truck Electrical System
- Euroricambi CATALOG SPARE PARTS TRUCK
- Mitchell TruckEst Estimator v3.0.1 [2016] Full Patch
- Truck, Bus, Trailer Catalog Spare Parts for European 2006-2013
- ZF Catalog Kit April 2009
- Portex FLAG CD Catalogue [04.2013]
