VAS-PC ODIS Flash Discs UPDATED [03.2019]
New Flashdaten VAG
VW Flash Disk (3.2019)
VW Commercial Flash Disk (3.2019)
Audi Flash Disk (3.2019)
Seat Flash Disk (3.2019)
Skoda Flash Disk (3.2019)
Bentley Flash Disk (3.2019):
Lamborghini Flash Disk (3.2019)
VAS-PC Offline Update Programming Procedure:
• Insert the Update Programming CD into your PC.
• Minimize or Run your VAS-PC.
• Open "My Computer".
• Open your "E:" Drive. A folder named "datflash" and a file named "label" will be
displayed on the screen.
• Minimize the window.
• Open "My Computer" to open up a new window.
• Open your "C:" drive.
• Open the "SIDIS" folder.
• Open the "Home" folder.
• Copy/Paste the folder named "datflash" to the "Home" folder.
• Close both open windows and maximize the VAS-PC screen.
• Remove programming CD from your PC.
• Activate Vehicle Self Diagnosis from your VAS-PC and select
On Board Diagnostic (OBD).
• Select appropriate address word for module being updated
• At the bottom of the screen, select 019 – Update Programming.
Note the files have to be for the control unit you are going to flash.
The VAS-PC will NOT let you flash a TDi to a Transmission or
a DSG to a 5sp auto. The file needs to be writen for that specific control unit.
Some times there is a compainion file that the VAS-PC reads and make that
dertimination of weither to flash or NOT!
New Flashdaten VAG
- Vivid Workshop Data 2015 Fee download
- Multiecuscan 3.6 [04.2017] Full Patch + Instruction
- Actia Multidiag KG 01.2013
- Multiecuscan 3.7 [07.2017] Full Patch + Instruction
- ElsaWin 6.0 Plus VW [01.2017] Multilingual
- VCDS lite VAG-COM 409 + CRACK+ USB Drive
- Vivid WorkShopData v10.2 full KG 1 LINK Download
- Vediamo License KG 05.00.05
- Fiat Multiecuscan 3.5 [2.2017] Full Patch Instruction
- Multiecuscan 3.9 R1+FIX Full Patch + Instruction
- Volvo PTT 2.03.40 With Full
- DVD Software Volvo PROSIS Construction Equipment Manuals and EPC
- Wurth WOW 5.00.12 [04.2016]
- ELSAWin 6.0 AUDI Database [03.2017]
- Autocom Cars & Heavy Duty R1 2016
