Universal Allison DOC v13.0.0 + Instruction 03.2015
Universal Allison DOC v13.0.0 [03.2015]
Languages: English
Verion: V13.00
Year: 03.2015
Pass: Thanks + Coment on below to get pass
Allison DOC V13 KG Work Offline
http://www.autorepairmanuals.ws/threads/allison-doc-v13-kg-work-offline.35731/
The Allison DOC (Diagnostic Optimized Connection) For PC Service Tool is a diagnostic system designed for use with Allison?s 3000/4000 Product Families transmissions, 1000/2000 Product Families transmissions, and transmissions using CEC2/CEC1 controls. This PC-based diagnostic program is capable of reading from an Allison 4th Generation Control System Module TCM, WTEC II and WTEC III Electronic Control Units (ECU), a 1000/2000/2400 Series Transmission Control Module (TCM), and a CEC2 and CEC1 Electronic Control Units (ECU).
New for Version 13.0.0 for March 2015 :
1 ) Model Year 15 Support for Allison 5th Generation Controls
2 ) Updated Allison Transmission Troubleshooting Manuals (English translations only)
3 ) Model Year 14 support for H 40/50 EP Electronic Control Systems
4 ) Dearborn DPA5 support for H 40/50 EP Systems (usb connected only) and GMLAN 4th Generation TCMs
5 ) Integrated E-Learn authorization for Allison 5th Generation Controls Protected Parameter reprogramming**
6 ) Ability to command Main Mod Pressure while performing an Allison 5th Generation Clutch Test* (model year restrictions apply)
* Not available with Fleet level licenses
** Advanced Feature, Proof of Additional Training Required
Allison TCMs Supported
1 ) 1K/2K, 3K/4K, and TC10 5th Generation Controls.
2 ) 1K/2K and 3K/4K 4th Generation Controls.
3 ) CEC3 (Off-Highway) 4th Generation Controls.
4 ) CEC2 Electronic Control Unit (ECU) data.*
5 ) CEC (On-highway and Off-highway) Electronic Control Unit (ECU) data.*
6 ) World Transmission Electronic Control (WTEC) II/III Electronic
7 ) 1000/2000/2400 Series Transmission Control Module (TCM) data.
8 ) H 40/50 EP Electronic Control Unit (ECU) data.*
Allison DOC(r) For PC Features
1 ) TAC Data Collection capability for WTEC III ECUs
2) Display of multiple transmission parameters and Diagnostic Trouble Codes.
3) Display of Failure Records.
4) A graphic display of limited data using analog and digital gauges.*
5) Reprogramming of ECU or TCM settings**
6) Ability to activate/reset tests and tranmission capabilities (clutch
test, solenoid test, adaptive shifts, throttle calibration, etc.)*
7) Recording of vehicle data bus information into snapshot sessions.
8) Display of vehicle data bus traffic.*
9) E-mailing of snapshots along with optional comments.
10) Ability to Export snapshots to a comma-delimited file (4th/5th Gen Controls only).
11) Ability to create/display/print diagnostic reports.
12) Access to transmission Troubleshooting Manuals, including context-sensitive links.
13) Integrated help with video-based training materials.
14) The ability to launch TCM Reflash when installed.
15) Automated application updates.
16) Access to Service Information Letters via the Allison Transmission web site.
17) Ability to monitor TRANSHEALTH(TM) status and to generate and display
TRANSHEALTH(TM) reports*, **
18) Display of vehicle prognostics information, when supported by a 4th/5th Generation TCM.
19) Language support for English, French, Japanese, Spanish, Russian, German, Portuguese,
Simplified Chinese, Korean, French Canadian, Italian, Polish, and Thai.
20) Reads engine faults.
21) Displays engine data when selected and if connected to a 4th generation control.
* Not available with Fleet Level Licenses
INSTALLATION INSTRUCTIONS:
Notes:
- You must have administrative privileges to install and uninstall this program.
1 ) Insert installation DVD or installation USB thumb drive.
2 ) If installation process does not begin momentarily, Select "Start"->"Settings"
->"Control Panel" from the "Start" menu on the task bar.
3 ) From the Control Panel select "Add/Remove Programs".
4 ) Select "Install" on the Add/Remove Programs Properties Dialog.
5 ) Select "Next" and follow instructions as necessary.
Languages: English
Verion: V13.00
Year: 03.2015
Notes:
- Universal Allison DOC v14.0.0 Build [02.2017] Full + Instruction
- Allison DTCs Service Manuals and Wiring DVD
- Universal Allison DOC v11.6 [09.2014] Diagnostics Soft
- Universal Allison DOC v2019.1.0 Build 04.2019 Transmission Diagnostic Software Full + Instruction
- Allison Transmission & ZF Transmission PDF Parts Catalog Troubleshooting & Service Manual 2020 Full DVD
- Allison Drivers Manuals
- [UL] Allison DOC v2021.5 2022 Remote Installation
- ALLISON TCM REFLASH 6.1 Install + Active Full
- Allison DOC v2020.2.0 Install + Active License
- Allison DOC v2021.3 Install + Active
- Allison DOC v2021.1 Install + Active License
- ALLISON DOC UPDATE FILES MAY 2018
- Allison DOC v2020.2 Data Update 2021.06 Install + Active License
- Allison DOC v2021.4 Install + Active License
- [NEW 2021] Allison DOC v2021.2 Install + Active
