Autoequipment
Manager
182
450,833
Toyota Techtream v10.30.029 10.2015
Instruction:
1. Run file set up untill finish
2. After finish
go to C:\Program Files\Toyota Diagnostics\Techstream\Env\IT3System.ini
Change....TISFunction=1 become TISFunction=0
3. Copy file "MainMenu" Then apply the crack in folder C:\Program Files\Toyota Diagnostics\Techstream\bin
Versaion: V10.30.029
Languages: English, Multilanguge
Win: WinXP, Vista, Windows7
Year: 10.2015
The program for the diagnosis of car TOYOTA, LEXUS, SCION. Required for the diagnosis of PassThru J2534 compatible adapter.
TIS techstream is the replacement for the Diagnostic Tester. It combines the functionality of TIS and the scantool into a single portable device. With TIS techstream, technicians can simultaneously view/analyze on-board vehicle data, browse relevant TIS service documents, and reprogram vehicles all from the driver's seat via wireless connection to TIS.
Toyota Flash Reprogramming DVD Vehicle Reprogramming :
Toyota/Scion/Lexus ECMs can be reprogrammed using the TIS techstream scantool. The ECM reprogramming function is only available with the authentic TIS techstream software which runs on the above mentioned scantool.
TIS techstream software version requirements are specified in applicable Technical Service Bulletin (TSB)/Service Communication (SC) documents, which can be accessed with a subscription to this website. Older documents may state to use the Diagnostic Tester as being the required tool. TIS techstream is the replacement for the Diagnostic Tester and can be used for all Toyota/Scion/Lexus vehicles marketed in the United States.
About Techstream: Scantool Diagnostics
TIS techstream offers full support for 1989 – current vehicles marketed in the United States. Periodic software updates will be available to support new models. TIS techstream provides quick and easy access to all available systems on the vehicle as well as a one touch vehicle status report (Health Check).
suttocr500
New Member
350
#9
Toyota Techtream v10.30.029 [10.2015] Full
Here is crack for Toyota Techstream 10.30.029
Replace original file "MainMenu.exe" with cracked.Then start Techstream and go to "Software Registration" and paste this:
1111111111111111111111111111111110001511111111
This code is for every area the same
Enjoy
Year: 10.2015
Enjoy
Year: 10.2015
hi there i got techstream off you but can not get it to work can you help
