Auto
Driver
625
1,781,845
Toyota Techstream 11.10.034 [2016/04]
Toyota Techstream 11.10.034 [2016/04] + Activator
Year / Release Date : 2016/04
Version : 11.10.034
System requirements : Windows XP-10 x32 & x64
Language : Multilingual (Russian available)
Medicine : None
Description : Dealer diagnostic software for Toyota, Lexus, Scion.
The program for the diagnosis of car TOYOTA, LEXUS, SCION. Required for the diagnosis of PassThru J2534 compatible adapter.
TIS techstream is the replacement for the Diagnostic Tester. It combines the functionality of TIS and the scantool into a single portable device. With TIS techstream, technicians can simultaneously view/analyze on-board vehicle data, browse relevant TIS service documents, and reprogram vehicles all from the driver's seat via wireless connection to TIS.
Toyota Flash Reprogramming DVD
Vehicle Reprogramming :
Toyota/Scion/Lexus ECMs can be reprogrammed using the TIS techstream scantool. The ECM reprogramming function is only available with the authentic TIS techstream software which runs on the above mentioned scantool. TIS techstream software version requirements are specified in applicable Technical Service Bulletin (TSB)/Service Communication (SC) documents, which can be accessed with a subscription to this website. Older documents may state to use the Diagnostic Tester as being the required tool. TIS techstream is the replacement for the Diagnostic Tester and can be used for all Toyota/Scion/Lexus vehicles marketed in the United States.
About Techstream
Scantool Diagnostics
TIS techstream offers full support for 1989 – current vehicles marketed in the United States. Periodic software updates will be available to support new models. TIS techstream provides quick and easy access to all available systems on the vehicle as well as a one touch vehicle status report (Health Check).
Toyota Techstream v11.xx.xxx Crack
http://www.autorepairmanuals.ws/threads/toyota-techstream-v11-xx-xxx-crack.37641/
