Driver
127
442,470
Tesla Model X 2021-2024 Service Bulletin
Brand: Tesla
Type of Machine: Automotive
Type of Manual: Service Bulletin
Model: Tesla Model X 2021-2024
Date: 2021 ; 2022 ; 2023 ; 2024
List of files:
CD-21-00-001 Authorization and Release for Inspection of Unsupported Vehicle R1.pdf
CD-21-00-002 Unsupported Vehicle Notification R4.pdf
CD-21-00-003 High Voltage Safety Inspection Result R3.pdf
CD-21-16-002 Instructions for HV Battery Electrical Disconnection R2.pdf
CD-21-16-003 Retrieving HV Battery Vitals R2.pdf
CD-21-20-002 Model X (2021-Plus) EDR Data Retrieval Guide.pdf
CD-21-92-001 Personal Protective and Emergency Equipment Guidance.pdf
CD-23-16-001 HV Battery Shipping Evaluation SX3Y.pdf
CD-24-16-001 Instructions for Packing Critically Damaged HV Battery Packs in UN Containers.pdf
CD-24-17-001 Alcohol Interlock Installation Guide.pdf
SB-21-00-004 Update Vehicle Firmware to Correct False FCWs or AEBs.pdf
SB-21-20-007 Replace Driver Airbag R1.pdf
SB-22-00-001 Update Vehicle Firmware To Remove Rolling Stop Functionality.pdf
SB-22-00-003 Update Vehicle Firmware to Correct Boombox Functionality R2.pdf
SB-22-00-007 Update Firmware to Allow Navigate on Autopilot to Comply with European Regulations R1.pdf
SB-22-00-009 Update Vehicle Firmware To Improve Car Computer Thermal Management R1.pdf
SB-22-00-012 Firmware Update to Correct Battery Management System.pdf
SB-22-00-014 Update Vehicle Firmware to Correct EPAS Software.pdf
SB-22-00-015 Update Vehicle Firmware to Correct Restraint Control Module Calibration.pdf
SB-22-17-002 Replace Key Fob(s).pdf
SB-22-17-003 Retrofit EPB Wires with Corrugated Tubing.pdf
SB-22-17-004 Replace Both Side Repeater Cameras.pdf
SB-22-18-002 Update Vehicle Firmware to Correct EXV Operation.pdf
SB-22-20-003 Replace Front Row Curtain Airbags.pdf
SB-22-31-001 Inspect Front Damper Solenoid Position.pdf
SB-22-33-001 Retrofit Hydraulic Control Unit Wake-Up Wire.pdf
SB-22-40-002 Replace Rear Plaid Drive Unit.pdf
SB-22-40-003 Inspect Plaid Rear Drive Unit Gearbox Fluid.pdf
SB-22-40-004 Inspect Plaid Rear Drive Unit Gearbox Fluid.pdf
SB-22-70-002 Update Vehicle Software to Correct Automatic Window Reversal R1.pdf
SB-23-00-001 Update Vehicle Software to Improve Certain FSD Beta Driving Maneuvers R1.pdf
SB-23-00-003 Update Software to Improve Regenerative Braking Functionality.pdf
SB-23-00-005 Update Vehicle Software to Correct Low Brake Fluid Level Threshold R1.pdf
SB-23-00-008 Update Vehicle Software to Incorporate Additional Autosteer Controls.pdf
SB-23-00-009 Update Vehicle Software to Incorporate Door Lockout Functionality.pdf
SB-23-10-001 Inspect Rear Quarter Inner Panels.pdf
SB-23-11-001 Inspect Front Door Cinch Actuators.pdf
SB-23-17-006 Inspect Forward Facing Camera Pitch Angle.pdf
SB-23-18-004 Retrofit AC Compressor Pipes With Support Bracket North America.pdf
SB-23-18-005 Replace Refrigerant and AC Lines.pdf
SB-23-20-004 Inspect Front Seat Belt Pre-Tensioners and Seat Belts for Correct Installation R1.pdf
SB-23-20-005 Inspect Driver Airbag.pdf
SB-23-44-004 Retrofit Charge Port Door Seal.pdf
SB-24-00-002 Update Vehicle Software to Enable Rearview Camera Display.pdf
SB-24-00-003 Update Vehicle Software To Enlarge Visual Warning Indicators R1.pdf
SB-24-00-004 Update Vehicle Software to Enable Rearview Camera Display R2.pdf
SB-24-00-006 Update Vehicle Software to Enable Pedestrian Warning Speaker.pdf
SB-24-10-002 Tighten Front Frame Rail Bolts.pdf
SB-24-21-001 Rear Touchscreen Bluetooth Audio Retrofit.pdf
SB-24-32-005 Replace Steering Yoke Due To Peeling Issue.pdf
TN-15-92-001 Installing Heli-Coil Inserts R4.pdf
TN-20-17-001 Coaxial Cable Overlay Guidelines R2.pdf
TN-21-16-001 Inspect MSP2 and MXP2 HV Battery for Underside Damage R2.pdf
TN-22-10-001 Modify B-Pillar Model X.pdf
TN-24-17-001 Lithium-Ion Low Voltage Battery Replacement.pdf
