Tesla Cybertruck 2024 Service Bulletin
Brand: Tesla
Type of Machine: Automotive
Type of Manual: Service Bulletin
Model: Tesla Cybertruck 2024
Date: 2024
List of files:
CD-24-20-001 Cybertruck Event Data Recorder Retrieval Guide.pdf
SB-24-00-003 Update Vehicle Software To Enlarge Visual Warning Indicators R1.pdf
SB-24-10-004 Inspect Front Door Panel Brackets.pdf
SB-24-11-001 Replace Door Check Strap Joint Bolts.pdf
SB-24-11-002 Inspect Door Striker Fasteners.pdf
SB-24-12-001 Retrofit Frunk Aero Seal.pdf
SB-24-16-001 Replace Device Cluster Assembly To Address HVC Communication Issue.pdf
SB-24-16-002 Replace Ancillary Bay Harness To Address PCS2 Harness Retention.pdf
SB-24-17-001 Inspect RH Curtain Airbag Harness.pdf
SB-24-30-001 Inspect Underbody Fasteners.pdf
SB-24-31-001 Inspect Front Knuckles And Front Upper Control Arms.pdf
SB-24-31-003 Inspect Front Stabar Link Fasteners.pdf
SB-24-32-002 Replace Steering Column Control Module (SCCM).pdf
SB-24-32-003 Replace Front Steering Actuator.pdf
SB-24-32-004 Retrofit Updated Rear Steering Actuator R3.pdf
SB-24-33-003 Inspect Accelerator Pedal.pdf
SB-24-40-002 Replace Tri Motor Rear Drive Unit Inverters.pdf
TN-24-16-002 Inspect the Cybertruck HV Battery for Underside Damage.pdf
Brand: Tesla
Date: 2024
List of files:
- Tesla Model S 2012-2016 Repair Manual + Wiring Diagram
- Tesla Model X 2015-2016 Workshop Manual
- Tesla Model 3 Service Manual Wiring Diagram [2018-2019]
- Tesla Model 3 SOP4 [02.2020] Wiring Diagram
- Tesla Model S 2012-2014 Service Manual
- Tesla Model S LHD 19.1.2015 1004573-00-E Wiring Diagram
- Tesla Model S LHD 2013 1004573-00-E Wiring Diagram
- Tesla Model Y LHD SOP Wiring Diagram_2020
- Tesla Model S LHD 1004573-00-E 8.13.2014 Wiring Diagram
- Tesla Model X LHD SOP2 Wiring Diagram
- Tesla Model S 2017 Offline Service Manual, Wiring Diagram
- Tesla Models S 2012-2016 Service Manual & Wiring Diagrams
- Tesla Model S LHD 2012 1004573-00-D Wiring Diagram
- Tesla Model X_LHD_SOP3 Wiring Diagram
- Tesla Model S LHD 6.7.2014 Wiring Diagram
