Subaru WRX & STI Factory Service Manual 2015
Type: html
1. Foreword
HOW TO USE THIS MANUALS HU
1. How to Use This Manuals
SPECIFICATIONS SPC
1. WRX
2. WRX STI
PRECAUTION PC
1. Precaution
NOTE NT
1. Note
IDENTIFICATION ID
1. Identification
RECOMMENDED MATERIALS RM
1. Recommended Materials
PRE-DELIVERY INSPECTION PI
1. Pre-delivery Inspection
PERIODIC MAINTENANCE SERVICES PM
1. General Description
2. Schedule
3. Engine Oil
4. Engine Oil Filter
5. Spark Plug
6. V-belt
7. Timing Belt
8. Fuel Line
9. Fuel Filter
10. Air Cleaner Element
11. Cooling System
12. Engine Coolant
13. Clutch System
14. Transmission Gear Oil
15. CVTF
16. Front Rear Differential Gear Oil
17. Brake Line
18. Brake Fluid
19. Disc Brake Pad and Disc
20. Parking Brake
21. Suspension
22. Wheel Bearing
23. Axle Boots Joints
24. Tire Inspection and Rotation
25. Steering System Power Steering
26. A/C Filter
ENGINE 1 SECTION
FUEL INJECTION FUEL SYSTEMS FUSTI
2. Throttle Body
3. Intake Manifold
4. Engine Coolant Temperature Sensor
5. Crankshaft Position Sensor
6. Camshaft Position Sensor
7. Knock Sensor
8. Throttle Position Sensor
9. Mass Air Flow and Intake Air Temperature Sensor
10. Manifold Absolute Pressure Sensor
11. Fuel Injector
12. Tumble Generator Valve Assembly
13. Tumble Generator Valve Actuator
14. Oil Flow Control Solenoid Valve
15. Wastegate Control Solenoid Valve
16. Front Oxygen A/F Sensor
17. Rear Oxygen Sensor
18. SI-DRIVE SUBARU Intelligent Drive Selector
19. Engine Control Module ECM
20. Main Relay
21. Oxygen Sensor Relay
22. Electronic Throttle Control Relay
23. Fuel Pump Relay
24. Fuel Pump Control Unit
25. Fuel
26. Fuel Tank Protector
27. Fuel Tank
28. Fuel Filler Pipe
29. Fuel Pump
30. Fuel Level Sensor
31. Fuel Sub Level Sensor
32. Fuel Filter
33. Pulsation Damper Assembly
34. Pressure Regulator Damper Assembly
35. Fuel Delivery Return and Evaporation Lines
36. Fuel System Trouble in General
EMISSION CONTROL AUX. EMISSION CONTROL DEVICES ECSTI
2. Front Catalytic Converter
3. Rear Catalytic Converter
4. Canister
5. Purge Control Solenoid Valve
6. Fuel Level Sensor
7. Fuel Sub Level Sensor
8. Drain Filter
9. Leak Check Valve Assembly
10. PCV Hose Assembly
11. PCV Valve
12. Secondary Air Pump
13. Secondary Air Combination Valve
INTAKE INDUCTION INSTI
2. Air Cleaner Element
3. Air Cleaner Case
4. Air Intake Duct
5. Intake Duct
6. Intercooler
7. Turbocharger
8. Air By-pass Valve
9. Resonator Chamber
10. Chamber Assembly
MECHANICAL MESTI
2. Compression
3. Idle Speed
4. Ignition Timing
5. Intake Manifold Vacuum
6. Engine Oil Pressure
7. Fuel Pressure
8. Valve Clearance
9. Engine Assembly
10. Engine Mounting
11. Preparation for Overhaul
12. V-belt
13. Crank Pulley
14. Timing Belt Cover
15. Timing Belt
16. Cam Sprocket
17. Crank Sprocket
18. Camshaft
19. Cylinder Head
20. Cylinder Block
21. Intake and Exhaust Valve
22. Piston
23. Connecting Rod
24. Crankshaft
25. Engine Trouble in General
26. Engine Noise
EXHAUST EXSTI
2. Front Exhaust Pipe
3. Center Exhaust Pipe
4. Joint Pipe
5. Rear Exhaust Pipe
6. Muffler
COOLING COSTI
2. Radiator Fan System
3. Engine Coolant
4. Water Pump
5. Thermostat
6. Radiator
7. Radiator Cap
8. Radiator Main Fan and Fan Motor
9. Radiator Sub Fan and Fan Motor
10. Reservoir Tank
11. Coolant Filler Tank
12. Engine Cooling System Trouble in General
LUBRICATION LUSTI
2. Oil Pressure System
3. Engine Oil
4. Oil Pump
5. Oil Pan and Strainer
6. Oil Pressure Switch
7. Engine Oil Cooler
8. Oil Pipe
9. Engine Oil Filter
10. Engine Lubrication System Trouble in General
SPEED CONTROL SYSTEMS SPSTI
2. Accelerator Pedal
IGNITION IGSTI
2. Spark Plug
3. Ignition Coil
STARTING/CHARGING SYSTEMS SCSTI
2. Starter
3. Generator
4. Battery
ENGINE DIAGNOSTICS ENSTIdiag
1. Basic Diagnostic Procedure
2. Check List for Interview
3. General Description
4. Electrical Component Location
5. Engine Control Module ECM I/O Signal
6. Engine Condition Data
7. Data Link Connector
8. General Scan Tool
9. Subaru Select Monitor
10. Read Diagnostic Trouble Code DTC
11. Inspection Mode
12. Drive Cycle
13. Clear Memory Mode
14. System Operation Check Mode
15. Malfunction Indicator Light
16. Diagnostics for Engine Starting Failure
17. Diagnostic Procedure for Subaru Select Monitor Communication
18. List of Diagnostic Trouble Code DTC
19. Diagnostic Procedure with Diagnostic Trouble Code DTC
20. Diagnostic Procedure without Diagnostic Trouble Code DTC
21. General Diagnostic Table
GENERAL DESCRIPTION GDSTI
1. List of Diagnostic Trouble Code DTC
2. Diagnostic Trouble Code DTC Detecting Criteria
ENGINE 2 SECTION
FUEL INJECTION FUEL SYSTEMS FUw/o STI
2. Throttle Body
3. Intake Manifold
4. Tumble Generator Valve Assembly
5. Tumble Generator Valve Actuator
6. Fuel Insulator
7. Fuel Injector
8. Fuel Pressure Sensor
9. High Pressure Fuel Pump
10. Engine Wiring Harness
11. Engine Coolant Temperature Sensor
12. Engine Oil Temperature Sensor
13. Crankshaft Position Sensor
14. Crankshaft Position Sensor Plate
15. Camshaft Position Sensor
16. Oil Control Solenoid
17. Knock Sensor
18. Throttle Position Sensor
19. Mass Air Flow and Intake Air Temperature Sensor
20. Manifold Absolute Pressure and Intake Air Temperature Sensor
21. Wastegate Control Solenoid Valve
22. Front Oxygen A/F Sensor
23. Rear Oxygen Sensor
24. SI-DRIVE SUBARU Intelligent Drive Selector
25. Engine Control Module ECM
26. Main Relay
27. Oxygen Sensor Relay
28. Electronic Throttle Control Relay
29. Fuel Pump Relay
30. Fuel Injector Relay
31. Fuel Pump Control Unit
32. Fuel
33. Fuel Tank Protector
34. Fuel Tank
35. Fuel Filler Pipe
36. Fuel Pump
37. Fuel Level Sensor
38. Fuel Sub Level Sensor
39. Fuel Filter
40. Fuel Delivery and Evaporation Lines
41. Fuel System Trouble in General
EMISSION CONTROL AUX. EMISSION CONTROL DEVICES ECw/o STI
4. Canister
6. EGR Pipe
7. EGR Control Valve
8. EGR Cooler
9. Fuel Level Sensor
10. Fuel Sub Level Sensor
11. Drain Filter
12. Leak Check Valve Assembly
13. PCV Pipe
14. PCV Connector
15. PCV Hose
16. PCV Hose Assembly
17. PCV Valve
INTAKE INDUCTION INw/o STI
3. Air Cleaner Case
4. Air Intake Boot
5. Air Intake Duct
6. Intake Duct
7. Intercooler
8. Turbocharger
9. Oil Catch Tank
10. Scavenge Pump
11. Air By-pass Valve
12. Resonator Chamber
MECHANICAL MEw/o STI
2. Compression
3. Idle Speed
4. Ignition Timing
7. Fuel Pressure
8. Cam Clearance
9. Engine Assembly
10. Engine Mounting
12. V-belt
13. Crank Pulley
14. Chain Cover
15. Timing Chain Assembly
16. Cam Sprocket
17. Crank Sprocket
18. Rocker Cover
19. Camshaft
20. Cam Carrier
21. Cylinder Head
22. Cylinder Block
23. Intake and Exhaust Valve
24. Piston
25. Connecting Rod
26. Crankshaft
27. Engine Trouble in General
28. Engine Noise
EXHAUST EXw/o STI
4. Rear Exhaust Pipe
5. Muffler
COOLING COw/o STI
3. Engine Coolant
4. Water Pump
5. Water Pipe Assembly
6. Thermostat
7. Radiator
8. Radiator Cap
9. Radiator Main Fan and Fan Motor
10. Radiator Sub Fan and Fan Motor
11. Reservoir Tank
LUBRICATION LUw/o STI
3. Engine Oil
4. Oil Pump
8. Engine Oil Cooler Pipe
9. Oil Catch Tank
10. Scavenge Pump
11. Oil Pipe
12. Engine Oil Filter
13. Oil Level Switch
14. Engine Lubrication System Trouble in General
SPEED CONTROL SYSTEMS SPw/o STI
IGNITION IGw/o STI
2. Spark Plug
3. Ignition Coil
STARTING/CHARGING SYSTEMS SCw/o STI
2. Starter
3. Generator
4. Battery
5. Battery Sensor
ENGINE DIAGNOSTICS ENw/o STIdiag
11. Inspection Mode
12. Drive Cycle
17. List of Diagnostic Trouble Code DTC
18. Diagnostic Procedure with Diagnostic Trouble Code DTC
19. Diagnostic Procedure without Diagnostic Trouble Code DTC
20. General Diagnostic Table
GENERAL DESCRIPTION GDw/o STI
TRANSMISSION SECTION
CONTROL SYSTEMS CS
2. AT Shift Lock Control System
3. Select Lever
4. Select Cable
5. AT Shift Lock Solenoid and P Range Switch
6. Body Integrated Unit
7. MT Gear Shift Lever
8. MT Gear Shift Cable
9. MT Gear Select Cable
10. Reverse Check Cable
11. General Diagnostic Table
CONTINUOUSLY VARIABLE TRANSMISSION CVTTR690
2. CVTF
3. Differential Gear Oil
4. Variator Chain Break-in
5. Road Test
6. Stall Test
7. Time Lag Test
8. Secondary Pressure Line Pressure Test
9. Transfer Clutch Pressure Test
10. Automatic Transmission Assembly
11. Transmission Mounting System
12. Extension Case Oil Seal
13. Differential Side Retainer Oil Seal
14. Inhibitor Switch
15. Secondary Speed Sensor
16. Primary Speed Sensor
17. Front Wheel Speed Sensor
18. Rear Wheel Speed Sensor
19. Secondary Pressure Sensor
20. Control Valve Body
21. Transmission Harness
22. Transmission Control Module TCM
23. CVTF Cooler With Warmer Function
24. Air Breather Hose
25. Drive Plate
26. Preparation for Overhaul
27. Torque Converter Assembly
28. Extension Case
29. Rear Drive Shaft
30. Transfer Clutch
31. Center Differential Carrier
32. Transfer Reduction Driven Gear
33. Parking Pawl
34. Intermediate Case
35. CVTF Filter
36. Reverse Brake Assembly
37. Forward Clutch Assembly
38. Reduction Driven Gear
39. Transmission Control Device
40. Transmission Case
41. Primary Pulley and Secondary Pulley
42. Variator Chain
43. Drive Pinion Shaft Assembly
44. Front Differential Assembly
45. Oil Pump
46. Oil Pump Chain
47. Converter Case Cover
48. Front Reduction Drive Gear
49. Front Reduction Driven Gear
50. Converter Case
51. Diagnostics with Phenomenon
CONTINUOUSLY VARIABLE TRANSMISSION DIAGNOSTICS CVTdiag
5. Transmission Control Module TCM I/O Signal
6. Subaru Select Monitor
7. Read Diagnostic Trouble Code DTC
8. Clear Memory Mode
9. Inspection Mode
10. Drive Cycle
11. System Operation Check Mode
12. Learning Control
13. AT OIL TEMP Warning Light Display
14. AWD Warning Light Display
15. Diagnostic Procedure for Subaru Select Monitor Communication
16. List of Diagnostic Trouble Code DTC
17. Diagnostic Procedure with Diagnostic Trouble Code DTC
18. Diagnostic Procedure without Diagnostic Trouble Code DTC
19. Diagnostics with Phenomenon
GENERAL DESCRIPTION CVT GDCVT
MANUAL TRANSMISSION AND DIFFERENTIAL 6MTTY75
2. Transmission Gear Oil
3. Manual Transmission Assembly
4. Transmission Mounting System
5. Oil Seal
6. Differential Side Retainer Oil Seal
7. Switches and Harness
8. Air Breather Hose
9. Preparation for Overhaul
10. Transfer Case and Extension Case Assembly
11. Transfer Drive Gear
12. Transfer Driven Gear
13. Center Differential
14. Shift Link Assembly
15. Transmission Case
16. Main Shaft Assembly for Single-Range
17. Drive Pinion Shaft Assembly
18. Front Differential Assembly
19. Reverse Idler Gear
20. Shifter Fork and Rod
MANUAL TRANSMISSION AND DIFFERENTIAL 6MTTY85
3. Oil Seal
4. Differential Side Retainer Oil Seal
5. Transmission Mounting System
6. Manual Transmission Assembly
7. Drivers Control Center Differential Control Module
8. DCCD Multi Select Switch
10. Air Breather Hose
11. Back-up Light Switch
12. Neutral Position Switch
13. Extension Case
14. Reverse Check System
15. Transfer Drive Gear
16. Transfer Driven Gear
17. Center Differential
18. Transmission Case
19. Main Shaft Assembly
20. Driven Gear Assembly
21. Reverse Idler Gear Assembly
22. Drive Pinion Shaft Assembly
23. Front Differential Assembly
24. Shifter Fork and Rod
25. Clutch Housing
26. General Diagnostic Table
MANUAL TRANSMISSION AND DIFFERENTIAL DIAGNOSTICS 6MTdiag
5. Drivers Control Center Differential DCCD Control Module I/O Signal
8. Drive Cycle
9. Clear Memory Mode
10. Drivers Control Center Differential DCCD Mode Display
11. AWD Warning Light Display
12. Diagnostic Procedure for Subaru Select Monitor Communication
13. List of Diagnostic Trouble Code DTC
14. Diagnostic Procedure with Diagnostic Trouble Code DTC
15. Diagnostic Procedure without Diagnostic Trouble Code DTC
16. Diagnostics with Phenomenon
CLUTCH SYSTEM CL
2. Clutch Disc and Cover
3. Flywheel
4. Release Bearing and Lever
5. Operating Cylinder
6. Master Cylinder
7. Clutch Pipe and Hose
8. Clutch Fluid
9. Clutch Fluid Air Bleeding
10. Clutch Pedal
11. Clutch Switch
12. General Diagnostic Table
CHASSIS SECTION
FRONT SUSPENSION FS
2. Wheel Alignment
3. Front Crossmember
4. Front Crossmember Support Plate
5. Front Stabilizer
6. Front Ball Joint
7. Front Arm
8. Front Strut
9. General Diagnostic Table
REAR SUSPENSION RS
2. Wheel Alignment
3. Rear Sub Frame
4. Rear Stabilizer
5. Rear Trailing Link
6. Upper Arm
7. Front Lateral Link
8. Rear Lateral Link
9. Rear Shock Absorber
10. General Diagnostic Table
WHEEL AND TIRE SYSTEM WT
2. Tire and Wheel
3. T-type Tire
4. Tire Pressure Monitoring System
5. General Diagnostic Table
TIRE PRESSURE MONITORING SYSTEM DIAGNOSTICS TPMdiag
2. General Description
3. Electrical Component Location
4. Control Module I/O Signal
5. Subaru Select Monitor
6. Read Diagnostic Trouble Code DTC
7. Clear Memory Mode
8. Read Current Data
9. Register Transmitter ID
10. Display Transmitter ID
11. Inspection Mode
12. Tire Pressure Warning Light / Trouble Indicator Light Illumination Pattern
15. General Diagnostic Table
DIFFERENTIALS DI
2. Differential Gear Oil
4. Rear Differential T-type
5. Rear Differential Front Oil Seal
6. Rear Differential Side Oil Seal
7. Rear Differential Front Member
8. Rear Differential Mount Bushing
TRANSFER CASE TC
2. Transfer Case and Extension Case Assembly
3. Transfer Clutch
4. Extension Case
5. Oil Seal
6. Transfer Drive Gear
7. Transfer Driven Gear
9. Center Differential Carrier
10. Center Differential
11. Transfer Clutch Pressure Test
DRIVE SHAFT SYSTEM DS
2. Propeller Shaft
3. Front Axle
4. Front Hub Unit Bearing
5. Rear Axle
6. Rear Hub Unit Bearing
7. Front Drive Shaft
8. Rear Drive Shaft
VEHICLE DYNAMICS CONTROL VDC VDC
2. Relay and Fuse
3. Vehicle Dynamics Control System
4. VDC Control Module and Hydraulic Control Unit VDCCMH/U
5. ABS Sequence Control
6. VDC Sequence Control
7. Yaw Rate and G Sensor
8. Steering Angle Sensor
9. Front ABS Wheel Speed Sensor
10. Rear ABS Wheel Speed Sensor
11. Front Magnetic Encoder
12. Rear Magnetic Encoder
13. VDC OFF Switch
VEHICLE DYNAMICS CONTROL VDC DIAGNOSTICS VDCdiag
5. Control Module I/O Signal
8. Inspection Mode
10. Warning Light Illumination Pattern
11. List of Diagnostic Trouble Code DTC
12. Diagnostic Procedure with Diagnostic Trouble Code DTC
13. General Diagnostic Table
BRAKE BR
2. Front Brake Pad
3. Front Disc Rotor
4. Front Disc Brake Assembly
5. Rear Brake Pad
6. Rear Disc Rotor
7. Rear Disc Brake Assembly
8. Master Cylinder
9. Brake Booster
10. Brake Fluid
11. Air Bleeding
12. Brake Hose
13. Brake Pipe
14. Brake Pedal
15. Stop Light Switch
16. Brake Vacuum Pump
17. Brake Vacuum Sensor
18. General Diagnostic Table
BRAKE VACUUM CONTROL BVC DIAGNOSTICS BVCdiag
8. Inspection Mode
10. List of Diagnostic Trouble Code DTC
11. Diagnostic Procedure with Diagnostic Trouble Code DTC
PARKING BRAKE PB
2. Parking Brake Lever
3. Parking Brake Cable
4. Parking Brake Assembly Rear Disc Brake
POWER ASSISTED SYSTEM POWER STEERING PS
2. Power Steering System
3. Steering Wheel
4. Universal Joint
5. Steering Column
6. Steering Gearbox
7. Electric Power Steering Gearbox
8. Pipe Assembly
9. Oil Pump
10. Reservoir Tank
11. Power Steering Fluid
12. Power Steering Control Module
POWER ASSISTED SYSTEM POWER STEERING DIAGNOSTICS PSdiag
8. Inspection Mode
10. STEERING Warning Light
BODY SECTION
HVAC SYSTEM HEATER VENTILATOR AND A/C AC
2. Air Conditioning System
3. Refrigerant Pressure with Manifold Gauge Set
4. Refrigerant Recovery Procedure
5. Refrigerant Charging Procedure
6. Refrigerant Leak Check
7. Relay and Fuse
8. Compressor Oil
9. Blower Motor Unit Assembly
10. Blower Motor
11. Power Transistor Auto A/C Model
12. Heater Core
13. Control Panel
14. Compressor
15. Condenser
16. Heater and Cooling Unit
17. Evaporator
18. Expansion Valve
19. Hose and Pipe
20. Pressure Switch Triple Pressure Switch
21. Ambient Sensor
22. Sunload Sensor Auto A/C Model
23. In-Vehicle Sensor Auto A/C Model
24. Evaporator Sensor
25. FRESH/RECIRC Door Actuator
26. Mode Door Actuator
27. Air Mix Door Actuator
28. Air Vent Grille
29. Heater Duct
30. Heater Vent Duct
31. A/C Filter
32. Diagnostics with Phenomenon
HVAC SYSTEM AUTO A/C DIAGNOSTICS ACdiag
4. Auto A/C Control Module I/O Signal
5. Diagnostic Chart for Self-Diagnosis
7. Subaru Select Monitor
8. Read Diagnostic Trouble Code DTC
10. Inspection Mode
11. Read Current Data
12. System Operation Check Mode
13. Diagnostic Procedure for Subaru Select Monitor Communication
14. List of Diagnostic Trouble Code DTC
15. Diagnostic Procedure with Diagnostic Trouble Code DTC
AIRBAG SYSTEM AB
2. Airbag Connector
3. Inspection Locations after a Collision
4. Drivers Airbag Module
5. Knee Airbag Module
6. Passengers Airbag Module
7. Side Airbag Module
8. Curtain Airbag Module
9. Airbag Control Module
10. Front Sub Sensor
11. Front Door Impact Sensor
12. Side Airbag Sensor
13. Curtain Airbag Sensor
14. Satellite Safing Sensor
15. Roll Connector
16. Airbag Module Disposal Deployment Processing on Vehicle
AIRBAG SYSTEM DIAGNOSTICS ABdiag
5. Airbag Connector
6. Airbag Control Module I/O Signal
9. Inspection Mode
10. Clear Memory Mode
12. Event Record Data
13. Batch save of Event record data
14. Airbag Warning Light Illumination Pattern
15. Airbag Warning Light Failure
17. Diagnostic Chart with Trouble Code
OCCUPANT DETECTION SYSTEM DIAGNOSTICS ODdiag
5. Airbag Connector
6. Control Module I/O Signal
9. Inspection Mode
12. Airbag Warning Light Illumination Pattern
13. Passengers Airbag ON/OFF Indicator Light Illumination Pattern
SEAT BELT SYSTEM SB
2. Pretensioner Connector
4. Seat Belt Warning System
5. Front Seat Belt
6. Rear Seat Belt
7. Disposal of Pretensioner
LIGHTING SYSTEM LI
2. Relay and Fuse
3. Headlight System
4. Day Time Running Light System
5. Clearance Light and Illumination Light System
6. Front Fog Light System
7. Turn Signal Light and Hazard Light System
8. Back-up Light System
9. Stop Light System
10. Interior Light System
11. Auto Headlight Beam Leveler System
12. Combination Switch Light
13. Light Control Sensor
14. Headlight Assembly
15. Headlight Bulb
16. Hazard Switch
17. Turn Signal Light Hazard Light Module
18. Front Turn Signal Light Assembly
19. Front Turn Signal Light Bulb
20. Clearance/Parking Light Bulb
21. Front Side Marker Light Bulb
22. Front Fog Light Assembly
23. Front Fog Light Bulb
24. Side Turn Signal Light Assembly
25. Rear Combination Light Assembly
26. Tail/Stop Light Bulb
27. Rear Turn Signal Light Bulb
28. Rear Side Marker Light Bulb
29. Back-up Light Bulb
30. License Plate Light
31. High-mounted Stop Light
32. Spot Map Light
33. Room Light
34. Trunk Room Light
35. LED Illumination Light
36. Vanity Mirror Light
37. Ignition Switch Illumination
38. Auto Headlight Beam Leveler Control Module
39. Rear Height Sensor
40. Day Time Running Resistor
41. Door Switch
AUTO HEADLIGHT BEAM LEVELER SYSTEM DIAGNOSTICS ALdiag
9. Inspection Mode
10. Read Current Data
13. Diagnostics with Phenomenon
WIPER AND WASHER SYSTEMS WW
2. Relay and Fuse
3. Wiper and Washer System
4. Combination Switch Wiper
5. Wiper Blade
6. Washer Tank and Motor
7. Front Wiper Arm
8. Front Wiper Motor and Link
9. Front Washer Nozzle
ENTERTAINMENT ET
2. Relay and Fuse
3. Audio System
4. Navigation System
5. Audio
6. Front Speaker
7. Rear Speaker
8. Woofer
9. Power Amplifier
10. Antenna
11. Steering Satellite Switch
12. Microphone
13. Navigation Body
14. GPS Antenna
15. Rearview Camera System
16. Front Accessory Power Supply Socket
17. Rear Accessory Power Supply Socket
18. AUX Input Terminal
COMMUNICATION SYSTEM COM
2. Relay and Fuse
3. Horn System
4. Horn
5. Horn Switch
GLASS/WINDOWS/MIRRORS GW
2. Relay and Fuse
3. Power Window System
4. Power Window Control Switch
5. Front Door Glass
6. Front Regulator and Motor Assembly
7. Remote Control Mirror System
8. Outer Mirror Assembly
9. Remote Control Mirror Switch
10. Rearview Mirror
11. Rear Door Glass
12. Rear Regulator and Motor Assembly
13. Windshield Glass
14. Rear Window Glass
15. Rear Window Defogger System
16. Wiper Deicer System
BODY STRUCTURE BS
INSTRUMENTATION/DRIVER INFO IDI
2. Relay and Fuse
3. Combination Meter System
4. Multi-function Display MFD System
5. Combination Meter
6. Speedometer
7. Tachometer
8. Fuel Gauge
9. Engine Coolant Temperature Gauge
10. Multi-function Display MFD
11. Steering Switch
INSTRUMENTATION/DRIVER INFO DIAGNOSTICS IDIdiag
9. Inspection Mode
12. User Customizing
15. Diagnostics with Phenomenon
SEATS SE
2. Front Seat
3. Rear Seat
4. Power Seat System
5. Seat Heater System
SECURITY AND LOCKS SL
2. Relay and Fuse
3. Door Lock Control System
4. Keyless Entry System
5. Keyless Access System
6. Push Button Start System
7. Security System
8. Front Inner Remote
9. Front Outer Handle
10. Front Door Latch and Door Lock Actuator Assembly
11. Rear Inner Remote
12. Rear Outer Handle
13. Rear Door Latch and Door Lock Actuator Assembly
14. Trunk Opener Switch
15. Trunk Lid Latch and Actuator Assembly
16. Front Hood Lock Assembly
17. Remote Openers
18. Ignition Key Lock
19. Key Lock Cylinders
20. Security Control Module
21. Impact Sensor
22. Keyless Entry Control Module
23. Keyless Buzzer
24. Body Integrated Unit
25. Keyless Transmitter
26. Access Key
27. Immobilizer Control Module
28. Immobilizer Antenna
29. Keyless Access Indoor Antenna
30. Keyless Access Outdoor Antenna
31. Trunk Opener Button
32. Receiver
33. Keyless Access CM
34. ID Code Box
35. Steering Lock CM
36. Push Button Ignition Switch
37. Starter Relay Push Button Start
38. IG Relay1 Push Button Start
39. IG Relay2 Push Button Start
40. Accessory Relay Push Button Start
41. Starter Cut Relay
42. Access Buzzer
43. Function Setting Customize
44. Keyless Access With Push Button Start System
SUNROOF/T-TOP/CONVERTIBLE TOP SUNROOF SR
2. Relay and Fuse
3. Sunroof Control System
4. Glass Lid
5. Sunroof Assembly
6. Sunroof Motor
7. Sunroof Switch
8. Sunshade
EXTERIOR/INTERIOR TRIM EI
2. Front Under Cover
3. Mud Guard
4. Floor Under Protector
5. Fuel Tank Protector
6. Front Hood Duct
7. Front Grille
8. Front Bumper
9. Rear Bumper
10. Cowl Panel
11. Roof Molding
12. Side Garnish
13. Trunk Lid Garnish
14. Rear Spoiler
15. Heat Shield Cover
16. Ornament
17. Door Trim
18. Instrument Panel Lower Cover
19. Glove Box
20. Center Console
21. Console Box
22. Instrument Panel Assembly
23. Lower Inner Trim
24. Upper Inner Trim
25. Rear Quarter Trim
26. Rear Shelf Trim
27. Trunk Room Trim
28. Sun Visor
29. Assist Grip
30. Roof Trim
31. Floor Mat
EXTERIOR BODY PANELS EB
2. Front Hood
3. Front Fender
4. Front Door
5. Front Sealing Cover
6. Rear Door
7. Rear Sealing Cover
8. Door Sash Tape
9. Trunk Lid
10. Weather Strip
CRUISE CONTROL SYSTEM CC
2. Relay and Fuse
3. Cruise Control System
4. Cruise Control Module
5. Cruise Control Command Switch
6. Combination Meter
7. Stop Light Brake Switch
8. Clutch Switch
9. Inhibitor Switch
10. Transmission Control Module TCM
11. Neutral Position Switch
12. Diagnostics with Phenomenon
CRUISE CONTROL SYSTEM DIAGNOSTICS CCdiag
4. Engine Control Module ECM I/O Signal
6. Read Cancel Code
7. Real-time Diagnosis
8. Diagnostics with Phenomenon
9. List of Cancel Code
10. Diagnostic Procedure with Cancel Code
IMMOBILIZER DIAGNOSTICS IMdiag
4. Immobilizer Control Module I/ O Signal
8. Diagnostics Chart for Security Indicator Light
9. List of Diagnostic Trouble Code DTC
10. Diagnostic Procedure with Diagnostic Trouble Code DTC
LAN SYSTEM DIAGNOSTICS LANdiag
9. CAN Communication Circuit Check
KEYLESS ACCESS WITH PUSH BUTTON START SYSTEM DIAGNOSTICS KPSdiag
10. Inspection Mode
11. Keyless Access System Check
BODY CONTROL SYSTEM DIAGNOSTICS BCdiag
8. Inspection Mode
9. Read Current Data
10. User Customizing
11. Registration Body Integrated Unit
12. Function Check
WIRING SYSTEM SECTION
WIRING SYSTEM WI
2. Working Precautions
3. Fuse And Relay
4. Power Supply Circuit
5. Ground Circuit
6. Airbag System
7. Air Conditioning System
8. Audio System
9. Back-up Light System
10. CAN Communication System
11. Charging System
12. Clearance Light and Illumination Light System
13. Combination Meter System
14. Coolant Temperature System
15. Cruise Control System
16. CVT Control System
17. Drivers Control Center Differential Control System
18. Electric Power Steering System
19. Engine Electrical System
20. Front Accessory Power Supply Socket System
21. Front Fog Light System
22. Front Wiper and Washer System
23. Fuel Gauge System
24. Headlight Beam Leveler System
25. Headlight System
26. Horn System
27. Immobilizer System
28. Interior Light System
29. Keyless Access System
30. Keyless Entry System
31. Multi-function Display MFD System
32. Navigation System
33. Occupant Detection System
34. Oil Pressure Warning Light System
35. Parking Brake / Brake Fluid Level Warning Light System
36. Power Seat System
37. Power Window System
38. Push Button Start System
39. Radiator Fan System
40. Rear Accessory Power Supply Socket System
41. Rear Defogger System
42. Rear Differential Oil Temperature Warning Light System
43. Rearview Camera System
44. Rearview Mirror System
45. Remote Control Mirror System
46. Remote Engine Start System
47. Seat Belt Warning System
48. Seat Heater System
49. Security System
50. Shift Lock Control System
51. Speedometer System
52. Starter System
53. Stop Light System
54. Sunroof Control System
55. Tire Pressure Monitoring System
56. Turn Signal Light and Hazard Light System
57. Vacuum Pump Control System
58. Vehicle Dynamics Control System
59. Wiper Deicer System
60. Harness Components Location
61. Front Wiring Harness
62. Bulkhead Wiring Harness In Engine Compartment RH
63. Bulkhead Wiring Harness In Engine Compartment LH
64. Bulkhead Wiring Harness In Compartment RH
65. Bulkhead Wiring Harness In Compartment LH
66. Engine Wiring Harness and Transmission Cord
67. Instrument Panel Wiring Harness RH
68. Instrument Panel Wiring Harness LH
69. Roof Cord
70. Rear Wiring Harness RH
71. Rear Wiring Harness LH
72. Door Cord RH
73. Door Cord LH
74. Rear Wiring Harness and Trunk Lid Cord
75. Antenna Cord
Type: html
1. Foreword
SPECIFICATIONS SPC
1. WRX
2. WRX STI
PRECAUTION PC
1. Precaution
NOTE NT
1. Note
IDENTIFICATION ID
1. Identification
2. Schedule
3. Engine Oil
5. Spark Plug
6. V-belt
7. Timing Belt
8. Fuel Line
9. Fuel Filter
11. Cooling System
12. Engine Coolant
13. Clutch System
15. CVTF
17. Brake Line
18. Brake Fluid
20. Parking Brake
21. Suspension
22. Wheel Bearing
26. A/C Filter
ENGINE 1 SECTION
2. Throttle Body
3. Intake Manifold
7. Knock Sensor
11. Fuel Injector
20. Main Relay
23. Fuel Pump Relay
25. Fuel
27. Fuel Tank
29. Fuel Pump
32. Fuel Filter
4. Canister
8. Drain Filter
11. PCV Valve
3. Air Cleaner Case
4. Air Intake Duct
5. Intake Duct
6. Intercooler
7. Turbocharger
MECHANICAL MESTI
2. Compression
3. Idle Speed
4. Ignition Timing
7. Fuel Pressure
8. Valve Clearance
9. Engine Assembly
10. Engine Mounting
12. V-belt
13. Crank Pulley
15. Timing Belt
16. Cam Sprocket
17. Crank Sprocket
18. Camshaft
19. Cylinder Head
20. Cylinder Block
22. Piston
23. Connecting Rod
24. Crankshaft
26. Engine Noise
EXHAUST EXSTI
4. Joint Pipe
6. Muffler
COOLING COSTI
3. Engine Coolant
4. Water Pump
5. Thermostat
6. Radiator
7. Radiator Cap
10. Reservoir Tank
LUBRICATION LUSTI
3. Engine Oil
4. Oil Pump
8. Oil Pipe
IGNITION IGSTI
2. Spark Plug
3. Ignition Coil
2. Starter
3. Generator
4. Battery
11. Inspection Mode
12. Drive Cycle
ENGINE 2 SECTION
2. Throttle Body
3. Intake Manifold
6. Fuel Insulator
7. Fuel Injector
17. Knock Sensor
26. Main Relay
29. Fuel Pump Relay
32. Fuel
34. Fuel Tank
36. Fuel Pump
39. Fuel Filter
4. Canister
6. EGR Pipe
8. EGR Cooler
11. Drain Filter
13. PCV Pipe
14. PCV Connector
15. PCV Hose
17. PCV Valve
3. Air Cleaner Case
4. Air Intake Boot
5. Air Intake Duct
6. Intake Duct
7. Intercooler
8. Turbocharger
9. Oil Catch Tank
10. Scavenge Pump
2. Compression
3. Idle Speed
4. Ignition Timing
7. Fuel Pressure
8. Cam Clearance
9. Engine Assembly
10. Engine Mounting
12. V-belt
13. Crank Pulley
14. Chain Cover
16. Cam Sprocket
17. Crank Sprocket
18. Rocker Cover
19. Camshaft
20. Cam Carrier
21. Cylinder Head
22. Cylinder Block
24. Piston
25. Connecting Rod
26. Crankshaft
28. Engine Noise
EXHAUST EXw/o STI
5. Muffler
COOLING COw/o STI
3. Engine Coolant
4. Water Pump
6. Thermostat
7. Radiator
8. Radiator Cap
11. Reservoir Tank
3. Engine Oil
4. Oil Pump
9. Oil Catch Tank
10. Scavenge Pump
11. Oil Pipe
IGNITION IGw/o STI
2. Spark Plug
3. Ignition Coil
2. Starter
3. Generator
4. Battery
5. Battery Sensor
11. Inspection Mode
12. Drive Cycle
CONTROL SYSTEMS CS
3. Select Lever
4. Select Cable
2. CVTF
5. Road Test
6. Stall Test
7. Time Lag Test
25. Drive Plate
28. Extension Case
30. Transfer Clutch
33. Parking Pawl
35. CVTF Filter
42. Variator Chain
45. Oil Pump
46. Oil Pump Chain
50. Converter Case
9. Inspection Mode
10. Drive Cycle
5. Oil Seal
3. Oil Seal
13. Extension Case
25. Clutch Housing
8. Drive Cycle
CLUTCH SYSTEM CL
3. Flywheel
6. Master Cylinder
8. Clutch Fluid
10. Clutch Pedal
11. Clutch Switch
CHASSIS SECTION
FRONT SUSPENSION FS
2. Wheel Alignment
5. Front Stabilizer
6. Front Ball Joint
7. Front Arm
8. Front Strut
REAR SUSPENSION RS
2. Wheel Alignment
3. Rear Sub Frame
4. Rear Stabilizer
6. Upper Arm
2. Tire and Wheel
3. T-type Tire
11. Inspection Mode
DIFFERENTIALS DI
TRANSFER CASE TC
3. Transfer Clutch
4. Extension Case
5. Oil Seal
2. Propeller Shaft
3. Front Axle
5. Rear Axle
8. Rear Drive Shaft
2. Relay and Fuse
13. VDC OFF Switch
8. Inspection Mode
BRAKE BR
2. Front Brake Pad
3. Front Disc Rotor
5. Rear Brake Pad
6. Rear Disc Rotor
8. Master Cylinder
9. Brake Booster
10. Brake Fluid
11. Air Bleeding
12. Brake Hose
13. Brake Pipe
14. Brake Pedal
8. Inspection Mode
PARKING BRAKE PB
3. Steering Wheel
4. Universal Joint
5. Steering Column
6. Steering Gearbox
8. Pipe Assembly
9. Oil Pump
10. Reservoir Tank
8. Inspection Mode
BODY SECTION
7. Relay and Fuse
8. Compressor Oil
10. Blower Motor
12. Heater Core
13. Control Panel
14. Compressor
15. Condenser
17. Evaporator
18. Expansion Valve
19. Hose and Pipe
21. Ambient Sensor
28. Air Vent Grille
29. Heater Duct
31. A/C Filter
10. Inspection Mode
AIRBAG SYSTEM AB
2. Airbag Connector
15. Roll Connector
5. Airbag Connector
9. Inspection Mode
5. Airbag Connector
9. Inspection Mode
SEAT BELT SYSTEM SB
5. Front Seat Belt
6. Rear Seat Belt
LIGHTING SYSTEM LI
2. Relay and Fuse
3. Headlight System
15. Headlight Bulb
16. Hazard Switch
32. Spot Map Light
33. Room Light
41. Door Switch
9. Inspection Mode
2. Relay and Fuse
5. Wiper Blade
7. Front Wiper Arm
ENTERTAINMENT ET
2. Relay and Fuse
3. Audio System
5. Audio
6. Front Speaker
7. Rear Speaker
8. Woofer
9. Power Amplifier
10. Antenna
12. Microphone
13. Navigation Body
14. GPS Antenna
2. Relay and Fuse
3. Horn System
4. Horn
5. Horn Switch
2. Relay and Fuse
5. Front Door Glass
10. Rearview Mirror
11. Rear Door Glass
BODY STRUCTURE BS
2. Relay and Fuse
6. Speedometer
7. Tachometer
8. Fuel Gauge
11. Steering Switch
9. Inspection Mode
SEATS SE
2. Front Seat
3. Rear Seat
2. Relay and Fuse
7. Security System
17. Remote Openers
21. Impact Sensor
23. Keyless Buzzer
26. Access Key
32. Receiver
34. ID Code Box
42. Access Buzzer
2. Relay and Fuse
4. Glass Lid
5. Sunroof Assembly
6. Sunroof Motor
7. Sunroof Switch
8. Sunshade
3. Mud Guard
6. Front Hood Duct
7. Front Grille
8. Front Bumper
9. Rear Bumper
10. Cowl Panel
11. Roof Molding
12. Side Garnish
14. Rear Spoiler
16. Ornament
17. Door Trim
19. Glove Box
20. Center Console
21. Console Box
26. Rear Shelf Trim
27. Trunk Room Trim
28. Sun Visor
29. Assist Grip
30. Roof Trim
31. Floor Mat
2. Front Hood
3. Front Fender
4. Front Door
6. Rear Door
8. Door Sash Tape
9. Trunk Lid
10. Weather Strip
2. Relay and Fuse
8. Clutch Switch
9. Inhibitor Switch
6. Read Cancel Code
10. Inspection Mode
8. Inspection Mode
12. Function Check
WIRING SYSTEM WI
3. Fuse And Relay
5. Ground Circuit
6. Airbag System
8. Audio System
11. Charging System
26. Horn System
49. Security System
52. Starter System
69. Roof Cord
72. Door Cord RH
73. Door Cord LH
75. Antenna Cord
- Subaru - Forester SJ 2013 Service Manual [2013, PDF, ENG]
- Subaru - Forester SJ 2014 Service Manual
- Subaru Legacy B4 Wiring Diagram
- Subaru Forester 2003 Service Manual
- Subaru 2013 XV Service Manual
- Subaru Forester 2015 Service Manual + Wiring Diagram
- SUBARU XV Cross HYBRID 2014 USA Workshop Manual
- Subaru Repair Manuals Full Set DVD
- Saburu Forester 2007 Wiring Diagram
- Saburu Legacy GT 1996 System Wiring Diagrams
- Subaru Impreza Outback Sport 2015 (Includes XV and Hybrid) Service Manual + Wiring Diagram
- SUBARU FORESTER 2019-2020 Service Manual & Electrical Wiring Diagram
- Subaru BRZ Z10_2017 Service Manual
- SUBARU Technical Training Manual
- Subaru Forester 1999-2002 Service Repair Manual
