Sis User Import File 2011A
- Download this document, you need 300 Gallons
Hi sis user import file 2011A
Installation instructions for CATERPILLAR SIS 2011
Run program from CD - STW2006A
Indicate path where program must be installed and choose CD/DVD Drives where your DVDs with data are.
After installation completes insert DVD SIS DATA and run Setup.exe
Run program Service Technician WorkBench
Warning!
Only after entering LicenseKey you can work with program!
To launch SIS create shortcut on your desctop - "Service Information System", and choose destination
path "C:\Program Files\Caterpillar\IncSISbinsis.exe"
To work with SIS you need to do the next:
1. Run SIS
2. Press button "Import SIS User"
3. Choose file SISUsers.xml and press "Load"
4. Check checkbox in "Select Users" window, press "Import" and wait 1-2 minutes.
After successful completing of user import procedure press "Load"
5. Enter -
Login ID - autocd1
Password - 12345
and press "Login"
6. Press on "View License Agreement", and choose any string in the window - "Use the System to conduct your business" and
press "YES"
7. In the next window for question "Do you want to start the SIS integration functionality?" choose answer "No"
If you do not want to change DVDs while working with catterpillar you should do the next:
1. Make 6 virtual drives and connect 6 DVDs with data.
2. Copy each disc to separate folder on your hard drive.
After this all, run SIS and in the right lower corner press on icon "SIS" (Yellow with black stripe in the middle)
Choose Configure and press on button ADD. Specify pathes to DVDs with data.
That is all.
Warning!
1. Run SIS
5. Enter -
Login ID - autocd1
Password - 12345
and press "Login"
press "YES"
That is all.
- Full Software Volvo IMPACT 2011
- Volvo VCADS Pro V2 Full
- VCDS Lite 1.0 full
- VOLVO IMPACT 2015
- Download Cummins INCAL 04/ 2013 the newest
- Volvo VCADS Pro 2.3.500
- Tech Tool V2.01 FULL Installation
- Perkins SPI 2012A KG
- Volvo prosis 2013 full active
- Metafile for CUMMINS CALTERM
- Allison Doc 8 KG
- WABCO TEBS-E v2.0 Activation + PIN
- How to your ECM with Calterm III
- CAT SIS ET CBT 2012 Master Install
- DVD Software MAN MANTIS EPC Update 477 (02.2012)
