SCANIA DIAGNOSTICS SDP3 2.47.1
Scania Diagnos & Programmer 3 Version 2.47.1
New general features
No major new general features in the issue.
New system-specific features
Troubleshooting wizards for checking the ignition system
Troubleshooting wizards for checking the ignition system. Applies to L,
P, G, R and S series and gas-powered trucks.
This wizard contains the full collection of troubleshooting wizards for the
ignition system. Here you can find, among other things, the wizard for
visually checking the ignition system, checking misfiring and checking
ignition voltage.
The wizard also contains links to the Scania operational data portal
where operational data for ignition voltage over time, number of misfires
over time and misfiring frequency can be found. The operational data is
intended to be used as a support in troubleshooting fault codes and
troubleshooting wizards.
An internet connection and Scania account are required to view
operational data for the vehicle you are connected to.
The troubleshooting wizards can be found under Functions > Check >
Powertrain/Engine/Ignition system > Checking the ignition system.
Scania SDP3 Functions:
Check and adjustements
Conversion
Maintenance
Campaign
Bodywork
Fault Codes
Fault Reporting
Programming of Control units
Supported resolving trouble codes to text description for the following types:
EMS (S6, S7, S8).
GMS (OPC4, OPC5).
RET (RET1, RET2).
AWD (AWD1).
EEC (SCR1, EEC3).
COO (COO6, COO7).
HMS (HMS1).
Some interesting options:
AdBlue ON/OFF.
EGR ON/OFF.
Chassis ID/VIN Change.
Immobilizer ON/OFF.
Truck Power INCREASE.
ECU Recovery.
ECU Reset.
ECU Unlock.
Scania SDP3 Support Systems:
EMS – Engine management system.
GMS – Gearbox management system.
RET – Retarder system.
AWD – All wheel drive system.
CLS – Clutch Control.
EEC – Exhaust Emission Control.
COO (COO7) – Coordinator.
BWS (BCI1) – Bodywork system.
ignition voltage.
Conversion
Maintenance
Campaign
Bodywork
Fault Codes
Fault Reporting
EMS (S6, S7, S8).
GMS (OPC4, OPC5).
RET (RET1, RET2).
AWD (AWD1).
EEC (SCR1, EEC3).
COO (COO6, COO7).
HMS (HMS1).
AdBlue ON/OFF.
EGR ON/OFF.
Immobilizer ON/OFF.
ECU Recovery.
ECU Reset.
ECU Unlock.
- Full Software Volvo IMPACT 2011
- Volvo VCADS Pro V2 Full
- VCDS Lite 1.0 full
- VOLVO IMPACT 2015
- Download Cummins INCAL 04/ 2013 the newest
- Volvo VCADS Pro 2.3.500
- Tech Tool V2.01 FULL Installation
- Perkins SPI 2012A KG
- Volvo prosis 2013 full active
- Metafile for CUMMINS CALTERM
- Allison Doc 8 KG
- WABCO TEBS-E v2.0 Activation + PIN
- How to your ECM with Calterm III
- CAT SIS ET CBT 2012 Master Install
- DVD Software MAN MANTIS EPC Update 477 (02.2012)
