[HOT] SERVICE MANUAL FULL UPDATED [2019] - [HOT] NEWS UPDATED [07.2019] - [HOT] Check spam box if you did not get email payment - [HOT] COMBO BEST PRODUCT - [HOT] HOW TO BUY MEMBERSHIP - [HOT] CONTACT US - [HOT] ALL METHOD PAYMENT ACCEPTED- [HOT] WEB MONEY ACCEPTED [04.2019]
Renault CAN CLiP v157 [04.2016] Full Instruction + Patch
Discussion in 'Truck, Heavy Truck Manuals, Softwares' started by truck, Apr 22, 2016.
  1. truck
    truck S-Mod
    May 9, 2014
    2,842
    440
    83
    If you download this document, you will be lost 2000 Gallons
    CLICK HERE DOWNLOAD
    Email Support : autorepairmanuals.ws@gmail.com
    Language: English (Multilangual)
    Type: Renault Diagnostic Tool
    Region: All Region
    Version: v157
    Developer: SPX
    Platform: WinXP, Vista, Windows7
    1 DVD DATA
    Year: 04.2016
    Medicine: Present
    Pass: Thanks + PM
    Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues.
    Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions.
    It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported.
    Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.
    Program dealer car diagnostics Renault, Dacia, Samsung.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Instruction:
    1. After Instalaltion finish DO NOT run your CLiP!
    1st replace the original RSWin.exe file (backup 1st your original file!!!)
    with the Cracked .exe file in C:\CLIP_X91\Lib\Application\
    2. Now from the SAME location as you are (C:\CLIP_X91\Lib\Application\) run the RSWin.exe,
    choose "Register me now" and in the next window select "NO"!
    3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
    It will work till 31/12/2020
    4. Now as you are, RESTORE your original RSWin.exe and REMOVE the patched one!
    (Just keep a backup from the patched file somewhere...)
    5. From your Desktop anymore, run your CLiP, accept the Terms and CLiP it will load.
    You Done! :)
    SPECIAL NOTES:
    Maybe when you try to make your 1st REAL Diagnosis you received an "Error" (about CLiP Damaged...)
    try to Update your PC with ALL the Latest Windows Updates! IF again the SAME "Error"
    then use 1x other PC or Roll-Back to Version V116! CLiP it seems, she no likes some PC's!
    Also when you will make your Registration, try to have your PC On-Line to the Internet!
    IF you NOT able to use 1x other PC and you insist to use this Latest Release,
    then you can post your S/N and you will got your personal Registartion Key.
    For this workaround you will need to use your ORIGINAL RSRWin.exe and also 1st of all to
    DELETE these 2x files: "reg.xml" & "ntuser.dat" from your:
    C:\Documents and Settings\All Users (Windows XP)
    C:\ProgramData (Windows 7 32Bit)
    NOTE: BEFORE to delete your reg.xml file, open it & note somewhere your COMPLETE S/N!
    Enjoy & Good Clipping!
  2. Support
    Support Administrator Staff Member
    Sep 16, 2013
    352
    13
    18
    Gender:
    Male
    It is new and usefull thanks.
    Sent from a mobile device
  3. johnauto
    johnauto
    Sep 25, 2015
    128
    1
    18
    Your forum is very good, thanks for your supporting
  4. Master
    Master Administrator
    Sep 3, 2012
    12,915
    546
    113
    Occupation:
    Supplier
    Home Page:
    Dear all i downloaded and set up already, It is ok. Thanks for sharing.
  5. auto
    auto S-Mod
    Sep 3, 2012
    2,302
    584
    113
    Dear you check your email and share me pass thanks.
  6. Caterpillar
    Caterpillar
    Sep 3, 2012
    579
    48
    28
    Thanks for your sharing. I am downloading.
  7. Powerus
    Powerus
    Sep 16, 2013
    593
    7
    18
    Thanks for your sharing. I am downloading. Thanks.
  8. momed80
    momed80 Moderator
    May 8, 2014
    1,196
    91
    48
    Please check your email to see thanks
  9. heavy
    heavy
    Oct 29, 2012
    176
    2
    18
    Link is running ok thanks for your sharing
  10. Powerus
    Powerus
    Sep 16, 2013
    593
    7
    18
    Thanks for good soft, i am finding it. Thanks
Share This Page
"How to Buy Membership on forum"
