PowerBoss Sweeper Armadillo 9X 9XCE Parts Catalog Wiring Diagram 4100000 2018
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model:
PowerBoss Armadillo 9X Series SW9XKDSL; SW9XKGAS; SW9XKLPG Sweeper
PowerBoss Armadillo 9X CE Series 9XRDSLCE; 9XRGASCE; 9XRLPGCE Sweeper
Engine: Kubota V1505 Diesel, WG1605 Gas, WG1605 LPG Engine
Part Number: 4100000
Publication Date: 05.2018
Number of Pages: 186 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Frame Assembly
Hydraulic Brake Assembly
Hydraulic Brake Assembly - Continued
Brake - 8” Arma L/H Pn-3321450
Brake - 8” Arma R/H Pn-3321471
Steering Wheel, Gauges & Fuses
Steering Column
Side Broom Assembly - Drive Motor, Arm, And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
Rtr Switch Detail Lift Arm
Lpg Mount Assembly
Hopper - Filter And Shaker Motor Components
Hopper - Cover And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Detail
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Engine Kubota V1505 Diesel - Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Manifold
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Assy & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assy, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel, WG1605 Gas & Lpg - Hydraulic Pump Detail
Engine Kubota WG1605 Lpg - Air Cleaner Detail
Engine Kubota WG1605 Gas - Air Cleaner Detail
Engine Kubota WG1605 Gas & Lpg Engine Assembly
Engine Kubota WG1605 Gas & Lpg - Mounts-Exhaust Side
Engine Kubota WG1605 Gas & Lpg - Mounts-Intake Side
Engine Kubota WG1605 Gas & Lpg - Mounting Fastener Detail
Engine Kubota WG1605 Gas & Lpg - Mounting Air Cleaner Bracket
Engine Kubota WG1605 Gas & Lpg - Radiator Mounts
Engine Kubota WG1605 Gas & Lpg - Exhaust Detail
Options And Standard Ce Features
Opt - Michigan Suspension Seat (600005)
Opt - Tires Pneumatic With Welded Nuts (660075)
Opt - Raise Hopper, Main Broom Shut Off (690100)
Ce Models Standard Feature
Opt - Ce Key Latch 9x (690102)
Opt - Seat Switch Engine Shut Off (690147)
Opt - Low Lp Indicator (690148)
Opt - Hopper Pressure Bypass (690231)
Opt - Seat Belt For Standard Seat With Lock (690230)
Opt - Seat Belt For Suspension Seat With Lock (690233)
Opt - Air Conditioning Unit Riser (690317)
Opt - Air Conditioning, Lp/Gas (690378)
Opt - Air Conditioning, Dsl (3316990)
For Ce Models (690380)
For Ce Models (690381)
Opt - Hopper, Stainless Steel (3315078)
Opt - Spotlight, Curb Broom (3316152)
Opt - Overhead Guard (3317260)
Opt - Heater (3316472)
Opt - Fan/Defroster (3317266)
Opt - Fire Extinguisher (3317268)
Opt - Light, Flash Amber (3317270)
Opt - Light, Flash Blue (3317271)
Opt - Light, Rotating Red (3317272)
Opt - Light, Rotating Amber (3317273)
Opt - Light, Strobe Amber (3317276)
Opt - Hd Curb Broom, Right (3317302)
Opt - Hd Curb Broom, Left (3330752)
Opt - Safety, Fire In Hopper Indicator (3317307)
Opt - Ce Backup Alarm & Neutral Safety Switch (3317306p)
Opt - Backup Alarm & Neutral Safety Switch (3317306)
Opt - Powerflex (3322125)
Opt - Air Cleaner, External Aux (3330896)
Opt - Air Cleaner, Heavy Duty (3331034)
Opt - Air Cleaner, External Aux Overhead Guard (3331338)
Opt - Lh Curb Broom Kit Assembly (3338666)
Opt - Dual Curb Broom Kit Assembly With Hopper (3333918)
Dual Curb Broom Sub-Assembly (3319421)
Side Broom Lift Lh (3335420)
Opt - Extreme Environment Dust Cover (3334437)
Opt - Vacuum Wand, 4” Orange (3334787)
Opt - Vacuumized Side Broom (3338470)
Miscellaneous Options
Hydraulic Schematic 9x
Hydraulic Schematic 9x Ce
Electrical Schematic With Kubota V1505 - Diesel
Electrical Schematic With Kubota WG1605 - Gas & Lpg
Warranty
Brand: PowerBoss
Model:
Preface
Dimensions & Weight
Sweeping System
Frame Assembly
Steering Column
Rear Drive Assembly
Console Assembly
Lpg Mount Assembly
Battery Components
Impeller Assembly
Main Broom Assembly
Vacuum Switch
Warranty
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
