Momed80
151
35,863
Palfinger Hydraulic Crane PK 62002 EH (S507-SK-E) Spare Parts Catalog 2011
Brand: Palfinger
Type of Machine: Hydraulic Crane
Model: Palfinger PK 62002 EH (S507-SK-E) Hydraulic Crane
Serial Number: 100165784
Publication Date: 2011
Number of Pages: 190 Pages
INDEX
0 Preface
0 .02 Preface-EN
0 .20 Signs and symbols
0 .21 Signs and symbols
0 .22 Signs and symbols
0100 Base
0100.01000-A Base
0100.02100-A Attachments TOQU
0100.02200-A Attachments - Clamp housing
0100.03200-A Valve bracket FFST
0100.03301-A Valve bracket FFST
0100.04100-A Bracket H,FFST
0100.05000-A Slewing system
0100.06200-A Piping - slewing system FFST
0100.07000-A Piping - lube system
0100.08100-A Piping - control PVG32,VDM07
0100.09200-A Hoses FFST
0100.10100-A Extension box R3X STZY
0100.10101-A Outrigger extension cylinder UP2229
0100.10102-A Outrigger extension cylinder UP2230
0100.11000-A Extension - box piping R3X,VDM07
0100.11011-A Pretension valve UV519
0100.11012-A Pretension valve UV402
0100.12200-A Support STZY
0100.12201-A Stabilizer ram UP2160A
0100.12202-A Construction kit HXE1340
0100.12304-A Check valve UV511
0100.12305-A Pretension valve UV469
0100.13000-A Pipes - support VDM07
0100.13001-A Pretension valve UV218
0100.14000-A Oil cooler 10,5kW
0200 Control - support VDM07
0200.01000-A Control valve VDM07
0200.01001-A Control valve - details
0200.02000-A Control system
0250 Control - crane PVG32
0250.01000-A Control valve PVG32
0250.01000-A Inlet element
0250.02000-A Switch actuation
0250.03000-A Separate element
0250.05000-A End element
0300 Safety devices
0300.04000-A Slew limitation
0300.05000-A Encoder
0301 Electrical parts
0301.03000-A Housing PT050,FFST
0301.03100-A Attachment board PT050,FFST
0301.03200-A Decals PT050,FFST
0301.06000-A Adaptor, switch
0301.07000-A Wire plug
0301.08000-A Line-up terminal
0301.09000-A Relay (1)
0301.09100-A Relay (2)
0301.10000-A Miscellaneous
0400 Crane column
0400.01000-A Crane column FL
0400.02000-A Attachments - crane column
0400.02001-A Lifiting cylinder - details
0400.02002-A Attachments - Clamp housing
0400.03200-A Piping - lifting cylinder PT050
0400.03201-A Load holding valve UV531-...
0500 Main boom
0500.01000-A Main boom
0500.01001-A Outer boom ram - details
0500.02000-A Piping - outer boom cylinder
0600 Outer boom
0600.01000-A Outer boom
0600.01001-A Hose clip
0600.01002-A Attachments - Clamp housing
0700 Boom extensions
0700.01000-A Extension boom 1 + piping
0700.01001-A Boom extensions ram 1 details
0700.02100-A Extension boom 2 + piping
0700.02101-A Boom extensions ram 2 details
0700.03100-A Extension boom 3 + piping
0700.03101-A Boom extensions ram 3 details
0700.04100-A Extension boom 4 + piping
0700.04101-A Boom extensions ram 4 details
0700.05100-A Extension boom 5 + piping
0700.05101-A Boom extensions ram 5 details
0700.06000-A Extension boom 6 + piping
0700.06001-A Boom extensions ram 6 details
1000 Miscellaneous
1000.01000-A Miscellaneous
1000.02000-A Crane hook
1000.03000-A Decals
1000.04200-A Decals (PK62002-EH)
AB001
Download
AB002 Auxiliary equipment
Download
INDEX
0760 Remote control BMS2
0760.01000 Transmitter
0760.02000 Transmitter - details
0760.03000 Electric
0760.04000 Receiver
0760.05000 Cable harness
0760.05001 Plug
0760.06000 Accessories
0760.07000 Decals
INDEX
1212 Oil tank TKL0
1212.00050 Oil tank, cpl. TL300
1213 Oil cooler
1213.07000 Oil cooler BKA56,BKA57
1213.07000A Oil cooler BKA63-12(24)V
1213.07300A Oil cooler EP2149+00003(4)
