paul422
6
10,302
Navistar ServiceMaxx V43.26 [07.2016] FULL
Download this document, you need 1000 Gallons
santonino1981
1,050
#3
Hey, I lost 1000 gallons because the file within the RAR are infected with a trojan named WIN32/VB.QOT , this is nasty trojan because the files can not be disinfected with any virus, so the files are deleted every extraction process, so please return my 1000 gallons, I will choose other download from here, and the files for J1939 and 1978 can be downloaded complete from the ServiceMaxx site, the keygen is another thing.
Master
Cleaner
720
4,235,553
#4
Dear you,
1. Thanks for coming
2. Please turn off your virut soft first
3. You can check your email and download again and extract again, always keeping protect in winrar file, when you use it you can extract.
santonino1981
1,050
#5
Wrong, the two installers are infected, and the keygen too, I tested in a virtual machine and got other system executables infected with the same trojan (and change from exe to dll in form); then I downloaded the most recent two installers from the ServiceMaxx site and they are fine without any trojan, used the infected the keygen (tested too under virtual machine) and the two fresh and uninfected installer accepted the activation code.
So you have here a trojan that's nasty, so nasty my turned off antivirus deleted directly without user interaction, is of these trojans that are not normal and inoffensive because, so please understand, or you fix the RAR content or I got refunded my 1000 gallons and I will use these to download the same keygen from other page here within Auto Repair Manuals, thanks.
paul422
6
10,302
#6
I don't understand why there's a problem. It's been tested successfully. Please try using another computer to open it,thank you!
santonino1981
1,050
#7
Please explain why other files (local files in my machine) not related to the files within the RAR are infected? explain these, the error is turning off the antivirus, sometimes is not a real trojan but a blacklisted inoffensive file so temporally turning off the antivirus makes sense to use the keygen (because of the code within), but this time is a bad shit trojan and the keygen is not the only infected file but the others two installers too, and no, other computers will not get different results, or you work without antivirus or your antivirus is bad, this is real bad shit with this trojan.
santonino1981
1,050
#9
I am using Windows XP, with NOD32 antivirus, as I said the keygen and the two installers contains the trojan WIN32/VB.QOT , and I then downloaded the two installers (not in fected) from the MaxxForce site in the Internet, so is not reason the installers within the RAR files need to be infected to function, really here is a case of corrupt files, in XP I can see multiple unrelated EXE files modified and break because of the trojan, probably you use Windows 7 and above, but here the XP is OK with the antivirus.
I turned off the antivirus to proceed with the running of the infected installers and the infected keygen, and again tried the same full way installing the two installers (not infected) from the ServiceMaxx site (Internet) using the infected keygen and the keys were accepted (all of the running under a virtual XP machine for testing); remember one thing, within the RAR are three files, that is two installers and the keygen, and the three are infected with the same trojan, that's a corrupt RAR file by definition and a payload to infect the computer.
I don't want to be said I need to upgrade to Windows 7 or above, because XP run the work flawlessly (with so much auto software and adapters drivers) here with the antivirus and other protections, and no Internet, because is only for exclusive work, any test for new software and keygens are made first in a Windows virtual machine, I understand some keygens could be blacklisted by the antivirus, but these are no real trojans, so they are not dangerous in the absolute, I know the difference and here this a real nasty trojan.
I need the refund of the 1,000 gallons because I can not use the file correctly; the antivirus used was NOD32 Antivirus.
Master
Cleaner
720
4,235,553
#10
Dear you please check in your email thanks.
