Driver
511
1,815,727
Navistar Engine Diagnostics 2017 + Patch
Navistar Engine Diagnostics, or NEDS for short, has replaced ServiceMaxx as of February 2017. Navistar® Engine Diagnostics is a diagnostic and programming service tool for Navistar® Engines. A fully-featured PC application, Navistar Engine Diagnostics is designed to meet the wide range of diagnostic challenges when servicing a mixed truck fleet. Coverage includes all J-1939 International electronic engine systems, allowing you to run special tests, change parameters and view and graph engine data. This is the top-of-the-line tool for dealers and fleets. The application updates periodically, enabling you to have the most up-to-date coverage.
Basic Features
Read and clear diagnostic fault codes
View signals and parameters
Print trip and vehicle reports
Advanced Features
Diagnostic Tests
KOEO – Key On Engine Off
KOER – Key On Engine Running
KOEO – Injector Buzz Test
KOER – Injector Contribution Test
Cylinder Cutout Test (EPA 04′ and newer)
Injector Disable Tests (EPA 04′ and newer)
Display and change configurable Parameters
Crank Inhibit
Fan Control
Idle Shutdown Timer
Warm-up Device
Warning and Protection System
Hydraulic Pressure Governor
PTO Control
Radiator Shutter
Vehicle Speed Limit
Vehicle Retarder
Two Speed Axle
Traction Control
Minimum System Requirements:
Microsoft® Windows® 2000, Windows XP, Windows Vista, or Windows 7
1GHz Intel Core 2 Duo, AMD Athlon X2 or better
2GB (32-bit) or 4GB (64-bit) of RAM
300MB of available hard disk space
1024 x 768 pixel monitor
One or more RP1210A compatible communication devices with SAE J1708 and/or SAE J1939 support
NOTE: Make sure to close Navistar Engine Diagnostics before installing a new version
diesel288
2
193
#3
Good morning dear, I need this program but the option to donate Gallons no longer exists.
can someone please help me ??
Master
Cleaner
719
4,409,073
#9
Dear you what window you are using? install java first, please see in the photo.
Or download and extract it again.
