sebbe76
2
324
NavCoder 2.9.183
NavCoder 2.9.183 With NavCoder you can...
*View the ibus data in real time and in plain text! 95% of all ibus messages can be displayed in English or other languages
*Scan the ibus and retrieve information on every connected device
*Scan and retrieve service information, showing vehicle kms and last service data
*Code the Light Control Module and switch off light bulb warning messages (great if you are fitting LED lights) as well as code Daytime Running Lamps (DRL)
*Code the Navigation computer (Mk2, Mk3 or Mk4) and set any setting you like.
*You can load languages, change from Mono to Colour nav or vice versa,
adjust split screen mode, and change regional settings.
*Code the TV and enable TV-in-Motion, change backup camera from NTSC to PAL and so on
*Code the ULF and TCU Bluetooth Telephone modules, enable voice recognition, and adjust speed dependent volume
*Sync the car clock to your laptop clock to the second
*Test the PDC, showing each sensor working in real time, with distance to obstruction
*Save and read ibus log files to help in analysing the ibus data flow through the vehicle.
*Live Data Session
Read and Code Navigation
Read the current coding and setup your navigation the way you want.
Change the boot mode from Mono (as used in E46 mono navs) to colour-screen navs (as used almost everywhere).
You can also set the languages to any combination you want, and recode the nav for another vehicle (useful if you are selling second-hand navigation units). Note: loading an OS and loading new languages requires a BMW OS disk. They can be found on the web...
Read and Code TV
The very popular "TV in motion" setting is found here.
You can also set your backup camera to PAL or NTSC - something that the BMW diagnostic software cannot do!
Read and Code Radio
Change area, set RDS options, and more.
Read and Code ULF and TCU Telephone modules
Did you know that ULF modules from Coding Index 05 have voice recognition built in? Code it with NavCoder!
Easily send any message you onto the ibus with the Message Tester
You can also save 5 commands into 5 function buttons.
You can also enter any ibus command and decode it into plain text - very useful when developing ibus applications.
SUPPORTED PLATFORMS
NavCoder runs on the following platforms:
Windows 7
Windows Vista
Windows XP
Windows 2000
Windows 1998 (confirmation required after v2.6.0 due to additional OCX controls used)
Windows 95 (confirmation required after v2.6.0 due to additional OCX controls used)
NavCoder can be used in the following vehicles...
BMW 3-series E46 (1998-2007)
BMW 5-series E39 (1995-2004)
BMW 7-series E38 (1994-2001)
BMW X3 E83 (2004-current [expected to be produced until 2010])
BMW X5 E53 (1999-2006)
BMW Z4 E85 E86 (2002-2008)
BMW New Mini One and Cooper R50 (2001-2006)
BMW New Mini Convertible R52 (2005-2008)
BMW New Mini Cooper S R53 (2001-2006)
Interface K+DCAN cable
