Mitsubishi Outlander XL Pinout Engine ECU engine family 4HN
CONTROL SYSTEM
Engine-ECU
In accordance with the data input by the sensors, the engine-ECU determines (calculates) optimal control and actuates the output actuators to suit the constantly changing driving conditions.
The engine-ECU consists of microprocessor, random access memory (RAM), read only memory (ROM), and input-output (I/O interface).
It has adopted a rewritable flash-memory ROM in which the control data can be changed or corrected through the use of a special tool. In addition, it has adopted an electrically erasable programmable read only memory (EEPROM) so that the learned correction data will not be deleted even if the battery is disconnected.
ECU Connector Input / Output Pin Arrangement
1
CAN interface (low)
2
Diagnosis k-line
3
4
Accelerator pedal position sensor (sub) earth
5
Cruise control switch ground
6
Accelerator pedal position sensor (main) earth
7
Power supply voltage applied to accelerator pedal position sensor (main)
8
Sensor earth (water in fuel sensor and exhaust gas temperature sensor)
9
Exhaust differential pressure sensor earth
10
Air temperature sensor earth
11
Engine-ECU earth
12
Engine-ECU earth
13
CAN interface (high)
14
Clutch switch <M/T>
15
16
Exhaust gas temperature sensor signal
17
Cruise control switch signal
18
Accelerator pedal position sensor (main) signal
19
Accelerator pedal position sensor (sub) signal
20
21
Exhaust differential pressure sensor signal
22
Air temperature senor signal
23
Engine-ECU earth
24
Power source 2
25
Fuel pump relay
26
Starter relay
27
Water in fuel sensor signal
28
Stop lamp switch
29
Air flow sensor signal
30
31
Ignition switch-ST
32
Power supply voltage applied to accelerator pedal position sensor (sub)
33
Power supply voltage applied to exhaust differential pressure sensor
34
Ignition switch-IG
35
Power source 1
36
Power source 2
37
38
Radiator fan relay
39
40
Condenser fan relay
41
A/C compressor relay
42
Engine control relay 1
43
44
45
Fuel additive pump
46
47
Power source 1
48
Power source 2
51
Fuel flow regulator
52
EGR cooler solenoid valve
53
54
Engine oil level sensor signal
55
Engine oil pressure switch
56
EGR valve position sensor earth
57
Rail pressure sensor earth
58
Throttle position sensor earth
59
Intake air pressure sensor signal
60
Intake air pressure sensor earth
61
Proportional oxygen sensor (current pump)
62
Proportional oxygen sensor (Nernst voltage)
63
Power supply
64
High pressure fuel regulator
65
66
67
68
EGR valve position sensor signal
69
Rail pressure sensor signal
70
Throttle position sensor signal
71
72
73
Proportional oxygen sensor (current adjust)
74
Proportional oxygen sensor (virtual ground)
75
Power supply
76
Power supply voltage applied to throttle position sensor
77
Crank angle sensor ground
78
79
Power supply voltage applied to intake air pressure sensor
80
Power supply voltage applied to rail pressure sensor
81
Engine coolant temperature sensor earth
82
83
Engine oil temperature sensor signal
84
85
86
Camshaft position sensor earth
87
Power supply
88
Power supply voltage applied to crank angle sensor
89
Crank angle sensor signal
90
Glow plug relay
91
Power supply voltage applied to camshaft position sensor
92
Power supply voltage applied to EGR valve position sensor
93
Engine coolant temperature sensor signal
94
95
Oil temperature sensor earth
96
97
98
Camshaft position sensor signal
101
102
103
104
Fuel temperature sensor signal
105
Fuel temperature sensor earth
106
107
Alternator FR terminal
108
109
Power supply voltage applied to variable geometry position sensor
110
Alternator L terminal
111
No. 1 fuel injector (high)
112
No. 4 fuel injector (high)
113
Glow diagnosis signal
114
115
116
117
Variable geometry position sensor signal
118
Intake air temperature sensor signal
Intake air temperature sensor earth
120
121
EGR valve motor (minus)
122
EGR valve motor (plus)
123
No. 3 fuel injector (high)
124
No. 2 fuel injector (high)
125
126
127
Variable geometry position sensor earth
128
129
130
131
Throttle valve control motor (minus)
132
Variable geometry control motor (minus)
133
Variable geometry control motor (plus)
134
135
No. 1 fuel injector (low)
136
No. 4 fuel injector (low)
137
138
139
140
141
142
Throttle valve control motor (plus)
143
144
145
146
Proportional oxygen sensor heater
147
No. 3 fuel injector (low)
148
No. 2 fuel injector (low)
Engine-ECU
1
CAN interface (low)
2
Diagnosis k-line
3
4
5
6
7
8
9
10
11
Engine-ECU earth
12
Engine-ECU earth
13
14
Clutch switch <M/T>
15
16
17
18
19
20
21
22
23
Engine-ECU earth
24
Power source 2
25
Fuel pump relay
26
Starter relay
27
28
Stop lamp switch
29
30
31
Ignition switch-ST
32
33
34
Ignition switch-IG
35
Power source 1
36
Power source 2
37
38
Radiator fan relay
39
40
Condenser fan relay
41
42
43
44
45
Fuel additive pump
46
47
Power source 1
48
Power source 2
51
Fuel flow regulator
52
53
54
55
56
57
58
59
60
61
62
63
Power supply
64
65
66
67
68
69
70
71
72
73
74
75
Power supply
76
77
78
79
80
81
82
83
84
85
86
87
Power supply
88
89
90
Glow plug relay
91
92
93
94
95
96
97
98
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
- Mitsubishi 4G15 Engine Manual
- Mitsubishi L200 2015 Service Manual CD (Triton)
- Mitsubishi Canter Engine 4M51 Workshop Manual Rus
- Mitsubishi Canter 4D34T3 Diesel Engine Shop Manual
- Mitsubishi ASX 2011 Workshop Manual
- Mitsubishi L200 2005 Wiring Diagram
- Mitsubishi Pajero 2001-2006 Service Manual
- Mitsubishi L200 2012 Workshop Manual
- Mitsubishi Mirage 2015 Workshop Manual
- Mitsubishi Pajero 2011 Workshop Manual
- Mitsubishi ASX 2015 Service Manual CD
- Mitsubishi Outlander 2007 Owner Manual
- Mitsubishi Canter URO3 For Australia Shop Manual Electrical
- Mitsubishi L200 Pinout Engine ECU engine 4D56
- Mitsubishi Colt 2004 Wiring Diagram
