Mercedes, Setra Fault Codes
- Download this document, you need 300 Gallons
Type: pdf
Fault Codes for on-board diagnostics
Setra S300/S400/S500
Mercedes Turismo/Travego/Cito/Citaro/Integro
The on-board diagnostics does not replace the off-board diagnostics (Star diagnostics), as certain functionalities can only be checked using the off-board diagnostics (e.g. the channel assignment of the sensors and actuators for the BS and ABS/TCR systems).
The systems summarised here in a table only represent a non-real, maximum scope of equipment. However, the scope of systems that may actually be downloaded in the on-board diagnostic system depends on the vehicle's equipment and technical specifications. For this reason, it may not be possible to call up some of the systems on the actual vehicle.
Type: pdf
- Radio Code Calculators, Readers, Serials, Code Seekers Collection
- Database Pin Out ECU 2015
- Fiat OBD II diagnostic interface pinout
- ATSG Automatic Transmission Service Group 2012
- BMW OBD-II diagnostic interface pinout
- Audi OBD-II diagnostic interface pinout
- Citroen OBD-2 diagnostic pinout
- SAE J1939 9 pin deutsch connector and DB9 Serial adapter pinout
- VAG 01.04.2014 - (All Engine Codes + All Gearbox Codes)
- BMW OBD II vehicle diagnostic connector pinout
- OBD-2 ISO-9141-2 (ISO 14230-4, KWP2000) serial cables schematics pinout
- ORIGINAL File ECU Database
- Key Programming and Service Indicators 2009
- BMW old 15 pin diagnostic interface connector pinout
- Daewoo 12 pin diagnostic interface pinout
