Driver
129
490,083
Massey Ferguson 2260 Large Rectangular Baler Parts Catalog 652049
Brand: Massey Ferguson
Type of Machine: Hay Equipment, Baler
Type of Manual: Spare Parts Manual
Model: 2260 Large Rectangular Baler
Part Number: 652049
Number of Pages: 643 Pages
TABLE OF CONTENT
DRIVE SYSTEM
BELTS & FILTERS GUIDE
MAIN DRIVE
CLUTCH - FLYWHEEL
DRIVE SHAFT
SECONDARY DRIVE SHAFT
PRIMARY DRIVE SHAFT - NON-CE
PRIMARY DRIVE SHAFT - CE
BRAKE - FLYWHEEL
MOUNTING - GEARBOX AND FLYWHEEL
GEARBOX ASSEMBLY
AUXILIARY DRIVE - LEFT HAND
AUXILIARY DRIVE - RIGHT HAND
SHAFT AND SPROCKET - AUXILIARY
SLIP CLUTCH - AUXILIARY
DRIVE - CUTTER
SLIP CLUTCH - CUTTER
GEARBOX ASSEMBLY - CUTTER
CHAIN LUBE
PUMP - CHAIN LUBE
CHAIN LUBE - CUTTER
HYDRAULIC SYSTEM
PICK-UP - HYDRAULICS
PICKUP - HYDRAULICS
HYDRAULIC CYLINDER - PICKUP LIFT
HYDRAULIC - FRONT
HYDRAULIC VALVE ASSEMBLY - BALE DENSITY
HYDRAULIC RESERVOIR
BALE DENSITY - HYDRAULICS
BRAKE HYDRAULICS - SINGLE AXLE
BRAKE HYDRAULICS - TANDEM AXLE
STEERING LOCK - TANDEM AXLE
BLOWER HYDRAULICS
BLOWER
CUTTER - LIFT
VALVE - HYDRAULIC
CUTTER - KNIFE
HYDRAULICS - BALE EJECTOR
HYDRAULICS - BALE CHUTE LIFT
HYDRAULIC CYLINDER ASSEMBLY
JACK - HYDRAULIC
ELECTRICAL SYSTEM
ELECTRICAL CONNECTORS - KIT, REPAIR
GTA C1000 CONSOLE AND MOUNTING - NON-CE
GTA C1000 CONSOLE AND MOUNTING - CE
C2100 CONSOLE AND MOUNTING - NON CE
C2100 CONSOLE AND MOUNTING - CE
GTA MOUNTING - OPTION
WIRING - CONTROL BOX
WIRING - PICKUP
WIRING - UPPER
WIRING - LOWER
ELECTRICAL KIT
WIRING - CUTTER
LIGHTS - NON-CE
LIGHTS - CE
BALE CHUTE - ROLLER
MODULE - REAR
ELECTRICAL CONNECTORS - WEATHER PACK
ELECTRICAL CONNECTORS - AMP, DEUTSCH AND WEATHERPACK
ELECTRICAL CONNECTORS - AMP AND DEUTSCH
ELECTRICAL CONNECTORS - DEUTSCH AND METRI-PACK
BALE FEEDING SYSTEM
WINDGUARD
ROLLER - WINDGUARD
WRAPPER, WEAR PLATE AND SCRAPER - MOUNTING
PICKUP FLOTATION
PICKUP AUGERS
PICKUP DRIVE - LEFT HAND
PICKUP DRIVE - RIGHT HAND
PICKUP CLUTCH
PICKUP REEL
PICKUP SHIELDS - LEFT HAND
SHIELD MOUNTING - LEFT HAND
PICKUP SHIELDS - RIGHT HAND
SHIELD MOUNTING - RIGHT HAND
GAUGE WHEEL - PICK-UP
PICKUP AUGERS - ADAPTER
MOUNTING - CUTTER
CUTTER
ROTOR - CUTTER
KNIFE ASSEMBLY - MOUNTING
KNIFE ASSEMBLY
BALE FORMING SYSTEM
PACKER - FEEDING AUGER
MOUNTING - PACKER CRANK
CRANK - PACKER
STUFFER DRIVE - LEFT HAND
STUFFER DRIVE - RIGHT HAND
CLUTCH - DOG
BRAKE ASSEMBLY
CHUTE - FEEDER
STRUTS AND WRAPPERS - PACKER
LINKAGE - STUFFER CLUTCH
HOLDING FINGER - STUFFER CHAMBER
MOUNTING - CONNECTING RODS
CONNECTING ROD LUBE
PLUNGER
MOUNTING - STRIPPER
BALE KNOTTING SYSTEM
MOUNTING - NEEDLE
KNOTTER MOUNTING
KNOTTER
MAIN SHAFT ASSEMBLY - KNOTTER
KNOTTER SLACKER - UPPER
HEAD - KNOTTER
KNOTTER CLUTCH
KNOTTER BRAKE
TWINE FINGER AND HAY DOG - KNOTTER
TENSIONER
MOUNTING - STAR WHEEL
STAR WHEEL TOWER
LINKAGE - STAR WHEEL
STAR WHEEL
U-JOINT - STAR WHEEL
KNOTTER ARM MOUNTING
TENSIONER - LOWER
TENSION ARM
KNOTTER MONITOR
MOUNTING - KNOTTER LUBE PUMP
KNOTTER LUBE PUMP
KNOTTER LUBE
KNOTTER LUBE VALVE - PRIMARY
KNOTTER LUBE VALVE - SECONDARY
BALE EJECTING SYSTEM
SELECTABLE EJECTOR
MOUNTING - BALE EJECTOR
MOUNTING - ROLLER BALE CHUTE
BALE WEIGHT - MOUNTING
CHASSIS
HITCH AND JACK MOUNTING
HITCH - CE
PLUNGER RAILS, KNIVES AND HAY DOG
BALE DENSITY DOORS
HOOD AND MOUNTING - NON-CE
HOOD AND MOUNTING - CE
SHIELDS - TOP
KNOTTER SHIELDS - NON-CE
KNOTTER SHIELDS - CE
TWINE BOX MOUNTING - LEFT HAND
TWINE BOX MOUNTING - RIGHT HAND
TWINE CAN - LEFT HAND
TWINE CAN - RIGHT HAND
SUPPORT - LEFT HAND
SUPPORT - RIGHT HAND
DOOR ASSEMBLY - LEFT HAND
DOOR ASSEMBLY - RIGHT HAND
DRIVE SHIELDS - AUXILIARY
SHIELDS - SINGLE AXLE
STEP ASSEMBLY
SHIELDS - TANDEM AXLE
MOUNTING - HANDRAIL
TOOL BOX
DECALS
DECALS - LOGO
DECALS - OPERATIONAL
AXLES, SPINDLES, AND WHEELS
AXLE MOUNTING - SINGLE AXLE
HUB AND SPINDLE - SINGLE AXLE
AXLE ASSEMBLY - TANDEM AXLE
AXLE - RIGID
HUB ASSEMBLY
AXLE - STEERING
HUB ASSEMBLY - STEERING
WHEELS
BRAKE SYSTEM
BRAKE MOUNTING - SINGLE AXLE
BRAKE ASSEMBLY - LEFT HAND
BRAKE ASSEMBLY - RIGHT HAND
BRAKE SYSTEM - RIGID
BRAKE SYSTEM - STEERING
DUST COVER - BRAKE SYSTEM
PARK BRAKE - SINGLE AXLE
PARK BRAKE - TANDEM AXLE
ACTUATOR ASSEMBLY - PARK BRAKE
AIR BRAKE - SINGLE AXLE
AIR BRAKE - TANDEM AXLE
AUTO BRAKE - CE
ACCUMULATOR
MOUNTING - CASTER
MAINFRAME
WHEEL ASSEMBLY - CASTER
HITCH
MOUNTING - HYDRAULIC
CONTROL BOX - ACCUMULATOR
ELECTRICAL
CART - UNLATCHING
BALE SHIFT BAR AND LINKAGE
CART - LEFT HAND
CART - RIGHT HAND
FRAME AND PANEL - REAR
CENTRALIZED LUBE
DECALS - ACCUMULATOR
ROAD LIGHTS
BALE WEIGHT KIT
LUBE SYSTEM KIT
DECAL KIT - ACCUMULATOR
ACCESSORIES
DRIVE SHAFT KIT - PRIMARY
ROLLER BALE CHUTE KIT
ROLLER BALE CHUTE
GTA C1000 CONSOLE KIT - NON-CE
GTA C1000 CONSOLE KIT - CE
C2100 CONSOLE KIT - NON CE
C2100 CONSOLE KIT - CE
ACCUMULATOR MOUNTING KIT
VALVE ASSEMBLY - ACCUMULATOR
SHEAR BOLT KITS
MODULE KIT
MODULE HARNESS KIT
KNOTTER TRIP KIT
MOTOR ASSEMBLY - TRIP
TELEMETRY INSTALLATION KIT
TELEMETRY KIT
HYDRAULIC JACK KIT
EXTENSION KIT - HITCH
DECAL KIT - FRENCH
DECAL KIT - SPANISH
SHIELD KIT - SINGLE AXLE
KIT - AIR BRAKE
