Remigio.Marcelo
159
#15
MAN Mantis v.522 EPC 10.2015 + Instruction Installation
Link from data.autorepairmanuals.ws high speed download
Languages: English (Multilanguage)
Operating System: WinXP, Vista , Windows7 (32BIT, 64BIT), WIN8
Version: v.522
Year: 10.2015
Medicine: Present have already, just set up and use
Pass: Thanks + Reply to get pass
Spare parts catalog for MAN Trucks, Buses and Engines .
The new versions of the program allows to enter complete VIN of the machine for identification, but defines by VIN only model and date of release.
There is a search of figure by original number of a detail and list of automobiles, where the detail was applied, also replaced numbers of details both new and old. For search of spare parts of the concrete machine it is necessary to know VIN or precisely to know model, wheel formula, interaxial distance, type of a suspension and cabin, also the type and modification of the engine installed on the machine.
The search by VIN in the program is realized as follows. It is possible to enter complete VIN or to use with 4 till 6 symbols VIN for definition such as (up to five symbols enter the zero) and with 7 till 10 symbols for definition of number of chassis, also it is possible to choose a type and number the chassis from the list of possible variants. All other data to specify require search directly on the machine.
The abbreviation MAN - means Machine-building factories Ausburg and Nuremberg. The firm "MAN" is based in 1915 and is one of the biggest manufacturers of vehicles, including buses and also components for their assembly (axles, transmissions, engines, cabins).
Install Instructions MANTIS:
- Insert the MANTIS DVD in the computer's DVD Driver
- Start Windows Explorer and select the DVD drive
- Double clikc "MANTIS setup.exe"
- DO NOT CHANGE DESTINATION PATH , Leave it like that .
- After the Extract finish , you can RUN the program from Desktop Icon "MANTIS" .
- DONE , Enjoy !!!!
Pass code please
Remigio.Marcelo
159
#17
Dear you check pass in your email thanks.
Hi,
It is take long time before I reply again and the down load has been successfully but the problem is I can not install the MAN EPC it is because during the installation there is a error message that shows LANG file is missing and Installation will cancel so many time Tried but not success. Please help, the total installation in ISO format is 6.31GB any solution for this?
Master
Cleaner
720
4,248,553
#18
Hi,
Dear you,
1. Thanks for coming and responding on forum
2. This is full package just download, set up and use no need active
3. Please check again your window, you can remove all and then set up again. Win 7 32 bit is better.
Arturo12232
100
#20
Version: v.522
Year: 10.2015
- DONE , Enjoy !!!!
