Hyundai
78
153,125
Lamborghini Tractor Nitro R 100 T4i ZKDY460200TL10001 Workshop Manual and Wiring Diagrams
Brand: Lamborghini
Type of Manual: Workshop Manual and Wiring Diagrams
Model: Lamborghini Nitro R 100 T4i ZKDY460200TL10001 Tractor
Number of Pages: 1419 Pages
1. Introduction
1.1. Introduction​
1.2. Tightening torques for nuts and bolts of electrical connections​
1.3. Wheel rim to hub screws and nuts tightening torques​
1.4. Installation of solenoid valves and cartridge valves​
1.5. Installation of quick couplers​
2. Technical characteristics
1.1. Engine​
1.2. Transmission​
1.3. Rear axle​
1.4. Front axle​
1.5. Bodywork - Cab - Platform​
1.6. Hydraulic system​
3. Calibrations and electronic diagnosis
1.1. Diagnostic tools​
1.2. Diagnostic tool screens​
1.3. Commissioning and calibrating the tractor​
1.4. ECU alarms​
4. Method of intervention
1.1. Separating engine from transmission​
1.2. Replace the crankshaft O-ring (flywheel end).​
1.3. Fitting and removing seal seat​
1.4. Fitting and removing transition pipe​
1.5. Line​
1.6. Removal and refitting of the oil sump pan​
1.7. Closing components​
1.8. Topping up with oil​
1.9. Removal and refitting of the flywheel (fixing elements)​
1.10. Removal and refitting of the cylinder head cover​
1.11. Support.​
1.12. Intermediate gear​
1.13. Removal and refitting of the oil cooler​
1.14. Lubricating oil filter console.​
1.15. Removal and refitting of the oil pickup pipe​
1.16. Removal and refitting of the lubricating oil pipe (exhaust gas turbocharger)​
1.17. Removal and refitting of the lubricating oil pipe (exhaust gas turbocharger)​
1.18. Removal and refitting of the lubricating oil return pipe (exhaust gas turbocharger)​
1.19. Removal and refitting of the lubricating oil return pipe (exhaust gas turbocharger)​
1.20. Fitting and removing the high pressure pump​
1.21. Removal and refitting of the injectors​
1.22. Removal and refitting of the common rail.​
1.23. Removal and refitting of the charge air duct​
1.24. Removal and refitting of the charge air manifold​
1.25. Intake manifold (turbocharger)​
1.26. Charge air manifold.​
1.27. Charge air duct​
1.28. V-belt pulley.​
1.29. Actuating elements​
1.30. V-belt pulley.​
1.31. Removal and refitting of the thermostat​
1.32. Testing the thermostat (after removal)​
1.33. Line​
1.34. Line​
1.35. Line​
1.36. Connection (crankcase, exhaust gas recovery, coolant pipe).​
1.37. Fitting compensator (exhaust pipe).​
1.38. Pipe (thermostat housing, exhaust gas recovery, coolant pipe)​
1.39. Removal and refitting of the turbocharger​
1.40. Removal and refitting of the turbocharger​
1.41. Exhaust manifold (turbocharger)​
1.42. Exhaust manifold (turbocharger)​
1.43. Exhaust manifold (turbocharger)​
1.44. Removing and refitting the belt tensioner (ribbed V-belt, level 1).​
1.45. Fitting and removing the console (ribbed V-belt, level 1)​
1.46. Engine mounting​
1.47. Engine mounting​
1.48. Engine mounting​
1.49. Disassembly and assembly of the connector box​
1.50. Disassembly and assembly of the connector box​
1.51. Disassembly and assembly of the connector box​
1.52. Disassembly and assembly of the connector box​
1.53. Disassembly and assembly of the connector box​
1.54. Connector casing.​
1.55. Console​
1.56. Removing and fitting hydraulic pump drive.​
1.57. Engine flywheel​
1.58. Engine​
1.59. A/C compressor belt​
1.60. Alternator / water pump belt​
1.61. Connecting rod drum check (L3)​
1.62. Removing and fitting pistons (L3)​
1.63. Check the piston (L3)​
1.64. Removing and fitting piston rings (L3)​
1.65. Checking piston rings (L3)​
1.66. Disassembly and assembly the cylinder head (fastening elements) (L3).​
5. Wiring diagrams
1.1. Introduction​
1.2. Basic electronics for mechanics (1/2)​
1.3. Basic electronics for mechanics (2/2)​
1.4. Electrical and electronic components (1/2)​
1.5. Electrical and electronic components (2/2)​
