155
628,976
Kubota Tractor L2650DT Parts Manual
Model: Kubota L2650DT Tractor
Number of Pages: 329 Pages
Instructions For Parts Books
All Product Index
Crankcase
Oil Pan
Piston And Crankshaft
Main Bearing Case
Flywheel [With Dual Clutch]
Valve And Rocker Arm
Nozzle And Glow Plug
Cylinder Head Cover
Inlet Manifold
Camshaft
Gear Case
Water Flange And Thermostat
Fuel Camshaft
Injection Pump [Component Parts]
Engine Stop Lever
Speed Control Plate
Governor
Air Cleaner
Double Air Cleaner [Option]
Pre-Cleaner [Option]
Exhaust Manifold And Muffler
Under Muffler [Option]
Stop Rod
Accelerator Lever
Accelerator Lever [Hydrostatic Ps]
Accelerator Linkage
Fuel Filter [Component Parts]
Fan [Old Type]
Fan [New Type]
Water Pipe
Reserve Tank
Shutter
Dynamo [A]
Dynamo [Component Parts] [A]
Starter
Starter [Component Parts]
Battery
Switch
Panel
Light
Electrical Wiring [A]
Clutch [Dual Clutch]
Clutch Lever [With Dual Clutch]
Clutch Pedal [With Dual Clutch]
Clutch Housing [With Dual Clutch]
Transmission Case
Main Shaft [With Dual Clutch]
Countershaft 1 [Constant Mesh]
Countershaft 1 [Synchro Mesh]
Countershaft 2
Pto Countershaft 1 [With Dual Clutch]
Pto Countershaft 2 [With Dual Clutch]
Pto Shaft [With I.Mid Pto] [A]
Pto Shaft [W O I.Mid Pto] [A]
Mid Pto
Reverse Shaft
Main And Shuttle Gear Shift Lever
Main And Shuttle Gear Shift Lever [Hydrostatic Ps]
Main Gear Shift Linkage System
Main Gear Shift Linkage System [Hydrostatic Ps]
Main Gear Shift Fork [Constant Mesh]
Main Gear Shift Fork [Synchro Mesh]
Shuttle Gear Shift Fork
Hi-Lo Gear Shift Fork
Creep Shift Fork [Option]
Mid Pto Shift Lever
Pto Gear Shift Fork [With Dual Clutch]
Pto Gear Shift Lever
Pto Lever Guide
Spiral Bevel Pinion [A]
Spiral Bevel Pinion [A]:L2950f L2950dt [Ca]:L2650dt L2950dt
Rear Differential [A]
Rear Differential [A]:L2950f L2950dt [Ca]:L2650dt L2950dt
Differential Lock Pedal
Rear Axle
Rear Wheel (11.2-24 Fslfa)
Rear Wheel (12.4-24 Fl18) [A]:L2950f L2950dt [Ca]:L2650dt L2950dt
Rear Wheel (420 70-24 R4) [A]
Rear Wheel (13.6-16 Pd)
Rear Wheel (355 80-D20pd)
Rear Wheel (21.5l-16.1 R3) [A]
Brake
Brake Pedal
Front Axle
Front Axle Case
Differential Gear Shaft
Front Differential Case
Front Differential
Propeller Shaft
Front Wheel Drive Shaft [W O Mid Pto]
Front Wheel Drive Shaft [With Mid Pto]
Front Wheel Drive Lever [W O I.Mid Pto]
Front Wheel Drive Lever [With I.Mid Pto]
Front Wheel (7-16 Fslm)
Front Wheel (10-16.5 R4) [A]
Front Wheel (25x8.50-14 Pd)
Front Wheel (25x8.50-14 Nhs) [A]
Front Wheel (212 80-D15 Pd)
Front Wheel (27x8.50-15 Nhs) [A]
Front Wheel (29x12.50-15 Nhs) [A]
Front Axle Frame
Steering Linkage
Steering Linkage
Steering Cylinder [Component Parts]
Steering (Ps)
Steering Controller
Steering (Ps) [Component Parts]
Steering Controller [Component Parts]
Bevel Gear Case
Steering Handle
Steering Handle
Orchard Kit [Option]
Hydraulic Pump (Ps)
Hydraulic Pump (Ps) [Component Parts]
Hydraulic Oil Filter
Hydraulic Oil Line [With Dual Clutch]
Hydraulic Oil Line (Ps)
Hydraulic Oil Line
Hydraulic Oil Line
Hydraulic Block
Control Valve
Control Valve [Component Parts]
Draft Control Valve [Option]
Draft Control Valve [Component Parts]
Hydraulic Cylinder
Lift Arm
Position Lever
Feed Back Lever
Aux.Control Valve 1 [Option]
Aux.Control Valve 2 [Option]
Aux.Control Valve [Component Parts]
3-Point Linkege 1
3-Point Linkege 2
Top Linkage Bracket [Option]
Drawbar
Clevis-Drawbar [Option]
Swinging Drawbar [Option]
Front Grille
Front Grille Support
Hood (Bonnet)
Side Cover
Rear Hood (Rear Bonnet)
Main And Pto Change Cover
Fender
Floor Seat
Foot Cover [W O Wet Clutch]
Step
Rops
Label 1
Label 2
Accessories And Service Parts
