Momed80
87
25,633
Komatsu Excavator PC75UU-2 SN 5001-UP Parts Catalog
Type of Machine: Excavator
Model: Komatsu PC75UU-2 SN 5001-UP Excavator
Number of Pages: 346 Pages
PC75UU-2 S N 5001-UP
ENGINE RELATED PARTS
ENGINE MOUNT (MOUNT)
ENGINE MOUNT (HOSE)
ENGINE MOUNT (SWITCH WIRING)
ENGINE MOUNT (BRACKET)
ENGINE MOUNT (HEATER) (CANOPY)
ENGINE MOUNT (HEATER) (CAB)
DAMPER
COOLER COMPRESSOR
C00LER COMPRESSOR (COMPRESSOR)(#7563-)
COOLING SYSTEM
COOLING (RADIATOR AND OIL COOLER)
COOLING (SUB TANK)
COOLING (MOUNTING)
COOLING (SUB TANK) (CAR COOLER PARTS) (WITH CAR COOLER)
CONDENSER (MOUNT)
CONDENSER (PIPING)
FUEL TANK AND RELATED PARTS
FUEL TANK (TANK)
FUEL TANK (FUEL LINE)
ELECTRICAL SYSTEM
BATTERY AND MOUNTING
BATTERY AND MOUNTING (COLD WEATHER SPEC.)
BATTERY AND MOUNTING (RELAY)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (FOR MONO BOOM)(#7075-)
ELECTRICAL (SAFETY EQUIPMENT) (CANOPY)
ELECTRICAL (SAFETY EQUIPMENT) (CAB)
HYDRAULIC SYSTEM
HYDRAULIC TANK
MAIN VALVE (MOUNT AND ELBOW) (FOR FRONT VALVE)
MAIN VALVE (MOUNT AND ELBOW) (FOR REAR VALVE)
MAIN VALVE (MOUNT AND ELBOW) (FOR UPPER VALVE)
MAIN VALVE (BRACKET)
MAIN PUMP (MOUNT AND ELBOW)
CONTROL PUMP (MOUNT AND ELBOW)
SUCTION LINE
DELIVERY LINE
RETURN LINE
DRAIN LINE(#5001-7927)
DRAIN LINE(#792
ACTUATOR LINE (BOOM)
ACTUATOR LINE (BUCKET¤ ARM AND OFFSET)
ACTUATOR LINE (SWING AND BLADE)(#5001-7927)
ACTUATOR LINE (SWING AND BLADE)(#792
ACTUATOR LINE (TRAVEL)(#5001-7927)
ACTUATOR LINE (TRAVEL)(#792
ACTUATOR LINE (BAND AND MOUNT)
ATTACHMENT LINE (TELESCOPIC ARM)
ATTACHMENT LINE (ATTACHMENT)
P.P
P.P (1)
P.P (2)
P.P (3)
P.P (4)
P.P.C MAIN LINE (P.P
P.P.C MAIN LINE (P.P (1)
P.P.C MAIN LINE (P.P (2)
P.P (5)
P.P.C MAIN LINE (ADDITIONAL SOLENOID VALVE) (SECOND TRAVEL SPEC.)
P.P (6)
P.P (7)
P.P (8)
MAIN REVOLVING FRAME AND RELATED PARTS
REVOLVING FRAME
REVOLVING FRAME (TELESCOPIC ARM)
BOOM FOOT PIN(#5001-7927)
BOOM FOOT PIN(#792
BOOM FOOT PIN(#7075-)
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
OPERATOR'S SEAT
OPERATOR'S CAB (CAB)
OPERATOR'S CAB (RAIL)
OPERATOR'S CAB (BRACKET)
OPERATOR'S CAB (DOOR 1 2)
OPERATOR'S CAB (DOOR 2 2)
OPERATOR'S CAB (PULL UP)
OPERATOR'S CAB (LAMP)
OPERATOR'S CAB (MOUNT)
HANDLE(#7928-10063)
FLOOR MAT
FLOOR MAT (TELESCOPIC ARM AND ATTACHMENT)
WINDOW WASHER
CANOPY
HEATER (HOSE)
CAR COOLER (PIPING AND MOUNT)
CAR COOLER (COOLER UNIT)(#7563-)
RADIO
ASHTRAY
FLOOR FRAME (FLOOR FRAME)
FLOOR FRAME (BASE)
FLOOR FRAME (TRAVEL CONTROL)
FLOOR FRAME (OFFSET CONTROL)(#5001-10370)
FLOOR FRAME (OFFSET CONTROL)(#10371-)
FLOOR FRAME (FOOT REST)(#7075-)
FLOOR FRAME (FUEL CONTROL LEVER)(#5001-10370)
FLOOR FRAME (FUEL CONTROL LEVER)(#10371-)
FLOOR FRAME (BLADE CONTROL)
FLOOR FRAME (LEVER¤ L.H.) (WITHOUT ONE TOUCH DECEL)
FLOOR FRAME (LEVER¤ L.H.) (WITH ONE TOUCH DECEL)
FLOOR FRAME (PIPING¤ L.H.) (KOMATSU PATTERN)(#5001-5646)
FLOOR FRAME (PIPING¤ L.H.) (JIS PATTERN)(#5647-)
FLOOR FRAME (COVER¤ L.H.) (CANOPY)
FLOOR FRAME (COVER¤ L.H.) (CAB)
FLOOR FRAME (LEVER¤ R.H.)
FLOOR FRAME (PIPING¤ R.H.)
FLOOR FRAME (PANEL)
FLOOR FRAME (MONITOR SYSTEM)
FLOOR FRAME (WIRING)(#5001-10370)
FLOOR FRAME (WIRING) (WITH ONE TOUCH DECEL)(#10371-)
FLOOR FRAME (WIRING)(#7075-10370)
FLOOR FRAME (WIRING) (WITH ONE TOUCH DECEL)(#5001-10370)
FLOOR FRAME (ELECTRICAL PARTS)
FLOOR FRAME (PLATE)
FLOOR FRAME (TRAVEL SPEED PEDAL) (SECOND TRAVEL SPEC.)
FLOOR FRAME (WORK EQUIPMENT CONTROL)
FLOOR FRAME (WORK EQUIPMENT CONTROL) (TELESCOPIC ARM AND ATTACHMENT)
FLOOR FRAME (HEATER) (CANOPY)
FLOOR FRAME (HEATER) (CAB)
FLOOR FRAME (DECEL MOTOR) (SECOND TRAVEL SPEC.)(#5001-10370)
FLOOR FRAME (FUEL CONTROL DIAL)(#10371-)
FLOOR MOUNT (FLOOR MOUNT) (CANOPY)
FLOOR MOUNT (FLOOR MOUNT) (CAB)
FLOOR MOUNT (MOUNT PARTS)
FLOOR COVER (CANOPY)
FLOOR COVER (CAB)
HAND RAIL
GUARD
HOOD (COVER)
HOOD (HOOD)
LEFT SIDE COVER (CANOPY)
LEFT SIDE COVER (CAB)
RIGHT SIDE COVER
FRONT COVER (TANK COVER)(#5001-10370)
FRONT COVER (TANK COVER)(#10371-)
FRONT COVER (COVER L.H.)
FRONT COVER (FRONT COVER) (CANOPY)
FRONT COVER (FRONT COVER) (CAB)
REAR VIEW MIRROR(#10064-)
COUNTER WEIGHT
COUNTER WEIGHT (TELESCOPIC ARM)
UNDER COVER
SWING CIRCLE AND RELATED PARTS
SWING CIRCLE
SWING MACHINERY AND MOTOR (SWING MACHINERY)(#5001-7927)
SWING MACHINERY AND MOTOR (SWING MACHINERY)(#792
SWING MACHINERY AND MOTOR (MOUNT AND ELBOW)(#5001-7927)
SWING MACHINERY AND MOTOR (MOUNT AND ELBOW)(#792
SWIVEL JOINT (MOUNT AND ELBOW)(#5001-7927)
SWIVEL JOINT (MOUNT AND ELBOW)(#792
SWIVEL JOINT (MOUNT AND ELBOW) (SECOND TRAVEL SPEC.)
SWIVEL JOINT (MOUNT AND ELBOW) (SECOND TRAVEL SPEC.) (WITHOUT BLADE)
TRAVEL AND LOWER PIPING
LOWER HYDRAULIC LINE (TRAVEL MOTOR LINE)
LOWER HYDRAULIC LINE (BLADE CYLINDER LINE)
LOWER HYDRAULIC LINE (TRAVEL HI LINE) (SECOND TRAVEL SPEC.)
FINAL DRIVE (MOUNT AND ELBOW)
FINAL DRIVE (MOUNT AND ELBOW) (SECOND TRAVEL SPEC.)
SPROCKET
UNDER CARRIAGE
FRONT IDLER
IDLER CUSHION
TRACK ROLLER(#5001-7927)
TRACK ROLLER(#7928-10370)
TRACK ROLLER(#10371-)
CARRIER ROLLER (FOR RUBBER SHOE)(#5001-7927)
CARRIER ROLLER (FOR STEEL SHOE)(#5001-7927)
CARRIER ROLLER (FOR RUBBER SHOE OR STEEL SHOE)(#7928-10370)
CARRIER ROLLER (FOR RUBBER SHOE OR STEEL SHOE)(#10371-)
RUBBER SHOE(#5001-7927)
RUBBER SHOE(#792
TRACK SHOE (TRIPLE GROUSER WITH HOLE AND RUBBER GROUSER TYPE)
TRACK FRAME AND COVER
WORK EQUIPMENT
BOOM (1ST¤ 2ND BOOM¤ 3RD BRACKET AND SUB LINK)
BOOM (1ST¤ 2ND BOOM¤ 3RD BRACKET AND SUB LINK) (ATTACHMENT)
BOOM (MONO BOOM)(#10371-)
BOOM (PIN)
BOOM (PIN) (MONO BOOM)(#7075-)
BOOM (HYDRAULIC LINE)
BOOM (HYDRAULIC LINE) (MONO BOOM)(#7075-)
BOOM (HYDRAULIC LINE) (TELESCOPIC ARM)
BOOM (WORK LAMP AND COVER)
BOOM (WORK LAMP AND COVER) (MONO BOOM)(#7075-)
BOOM (SAFETY EQUIPMENT)(#5001-7927)
BOOM (SAFETY EQUIPMENT)(#792
BOOM (ATTACHMENT LINE) (ATTACHMENT)
BOOM CYLINDER
BOOM CYLINDER (INNER PARTS) (MONO BOOM)(#7075-)
ARM CYLINDER
ARM CYLINDER (INNER PARTS) (MONO BOOM)(#7075-)
ARM CYLINDER (ACCESSORIES PARTS)
OFFSET CYLINDER
ARM (ARM AND PIN)
ARM (ARM) (TELESCOPIC ARM)
ARM (ARM AND PIN) (ATTACHMENT)
LONG ARM (ARM AND PIN)
ARM (COVER) (TELESCOPIC ARM)
ARM (PIN) (TELESCOPIC ARM)
ARM (ATTACHMENT PIPING) (ATTACHMENT)
LONG ARM (HOSE)
ARM (PIPING) (TELESCOPIC ARM)
ARM (SAFETY EQUIPMENT)(#5001-7927)
ARM (SAFETY EQUIPMENT)(#7928-10370)
ARM (SAFETY EQUIPMENT)(#10371-)
ARM (SAFETY EQUIPMENT) (TELESCOPIC ARM)(#5001-7927)
SLIDE ARM CYLINDER
BUCKET CYLINDER
BUCKET CYLINDER (INNER PARTS) (MONO BOOM)(#7075-)
BUCKET CYLINDER (FOR SLIDE ARM)
BUCKET LINK
BUCKET PIN(#5001-10370)
BUCKET PIN(#10371-)
BUCKET PIN (FOR NARROW WIDTH BUCKET)(#10371-)
BUCKET¤ 0.25M3 (MINI 0
BUCKET¤ 0.25M3 (MINI 0 (1)
BUCKET¤ 0.18M3 (MINI 0
BUCKET¤ 0.18M3 (MINI 0 (1)
BUCKET¤ 0.11M3 (MINI 0
BUCKET¤ 0.11M3 (MINI 0 (1)
BUCKET¤ 0.08M3 (MINI 0
BUCKET¤ 0.08M3 (MINI 0 (1)
BUCKET¤ 0.25M3 (MINI 0 (2)
BUCKET¤ 0.25M3 (MINI 0 (3)
BUCKET¤ 0.30M3 (MINI 0
BUCKET¤ 0.30M3 (MINI 0 (1)
BLADE
BLADE CYLINDER (PIN AND COVER)
BLADE CYLINDER (CYLINDER)
MARKS AND PLATES
MARKS AND PLATES (ENGLISH)
PLATE (CAB) (ENGLISH)
ACCESSORY
SPARE PARTS
CAP AND OVERALL
GENERAL TOOLS
SERVICE KIT AND COMPONENT PARTS
SERVICE KIT
SWING MOTOR (1 2)(#5001-7927)
SWING MOTOR (1 2)(#792
SWING MOTOR (2 2)(#5001-7927)
SWING MOTOR (2 2)(#792
MAIN VALVE (FRONT) (1 3)
MAIN VALVE (FRONT) (2 3)
MAIN VALVE (FRONT) (3 3)
MAIN VALVE (REAR) (1 3)
MAIN VALVE (REAR) (2 3)
MAIN VALVE (REAR) (3 3)
P.P.C. VALVE (FOR WORK EQUIPMENT CONTROL) (R.H.)(#5001-7927)
P.P.C. VALVE (FOR WORK EQUIPMENT CONTROL) (R.H.)(#792
P.P.C. VALVE (FOR WORK EQUIPMENT CONTROL) (L.H.)(#5001-7927)
P.P.C. VALVE (FOR WORK EQUIPMENT CONTROL) (L.H.)(#792
P.P.C. VALVE (FOR OFFSET ATTACHMENT CONTROL)(#5001-7927)
P.P.C. VALVE (FOR OFFSET ATTACHMENT CONTROL)(#7928-10370)
P.P.C. VALVE (FOR OFFSET ATTACHMENT CONTROL)(#10371-)
MAIN PUMP (CONTROL PISTON) (1 3) (INNER PARTS)
MAIN PUMP (PISTON PUMP) (2 3) (INNER PARTS)
MAIN PUMP (GEAR PUMP) (3 3) (INNER PARTS)
CONTROL PUMP (PUMP) (INNER PARTS) (FOR P.P.C. MAIN LINE)
SWIVEL JOINT (INNER PARTS)(#5001-7927)
SWIVEL JOINT (INNER PART)(#792
TRAVEL MOTOR (1 3) (HYDRAULIC MOTOR)
TRAVEL MOTOR (1 3) (HYDRAULIC MOTOR) (SECOND TRAVEL SPEC.)(#5001-10370)
TRAVEL MOTOR (1 3) (HYDRAULIC MOTOR) (SECOND TRAVEL SPEC.)(#10371-)
TRAVEL MOTOR (2 3) (BRAKE VALVE)
TRAVEL MOTOR (2 3) (BRAKE VALVE) (SECOND TRAVEL SPEC.)(#5001-10370)
TRAVEL MOTOR (2 3) (BRAKE VALVE) (SECOND TRAVEL SPEC.)(#10371-)
TRAVEL MOTOR (3 3) (FINAL DRIVE)
TRAVEL MOTOR (3 3) (FINAL DRIVE) (SECOND TRAVEL SPEC.)(#5001-10370)
TRAVEL MOTOR (3 3) (FINAL DRIVE) (SECOND TRAVEL SPEC.)(#10371-)
MAIN VALVE (UPPER VALVE) (1 2) (INNER PARTS)
MAIN VALVE (UPPER VALVE) (2 2) (INNER PARTS)
