Autotruck
Driver
71
266,914
Komatsu EPC 2011 updated
The properties of the selected library
1) The hard disk has a
folder, for example for download
Directory of Japanese cars was
create a folder:
C: \ CSS Books \ KLTD
2) Push the button "Add
library "and select an empty
folder and click on «Select»
3) Not paying attention to
warning that the selected
folder is not a library
click on «Ok».
4) Select that appears
library
5) Select the tab «Install Books ...» and
in the line «Look for books in ...»
And press the «Enter»
6) If the correct set of
addresses and no errors on
server will appear
to the server
7) In the download window appears Books
Folder CSS-Net
7) To download all the books of
folder, select the entire folder
you need to download and mouse
drag selection
folder in the folder added
8) In order to download some
Book select those books and
mouse drag
Selected books added
folder
9) Choose a way to download books
A) Full download Full download - Enable web access Enable web access:
preservation of the book completely. at
the opening of the book is first asked to
server, if no answer -
loaded from the saved place.
You can update the book.
B) Full download - Disable web access:
preservation of the book completely. for
the opening of the book Internet access is not
required. update books
automatically impossible.
C) Minimal download - Enable web
access: the book is saved as a
references and takes up little space. for
Opening the book must have access to
Internet.
10) The process of downloading will be
displayed in a separate window.
Source - the name of the downloaded file
Status - status of the upload
Remaining - the number of
the remaining files for this
model
11) After a successful conservation
Last page will show
confirmation of successful
downloads
12) Downloaded the book will be
appear in the list of active
libraries.
13) In the new folder will be
created a file in
spare parts that can be
write to disk and use
locally.
