silversonic
346
Does anyone have a torrent or working links for John Deere AG_EN_201207_01 data disk (iso)? I only need the first disk to get the 2013 disks to work. I've tried the rapidshare links but the error says that only the original uploader can download the files. Any assistance would be appreciated.
LGVictoria
30
silversonic
346
I was able to install SA (thank you LGVictoria!). My goal is to find information on a John Deere 2550 tractor. It shows to need the following DVD labeled: AGHIST_EN_200801_01
Can anyone post links or torrents for the AGHIST_EN_200801_01 DVD?
Thank you for any assistance that you guys can provide.
LGVictoria
30
I am sure I've installed and uninstalled Serv Adv 4.0 at the very least 20 times. I can get the key to work but as soon as I load the Sauce update, it says the license is invalid. No, I don't open Service Advisor after loading it until I've run the Sauce update, however, I have opened it to make sure the key was working, then uninstalled it and reloaded then Sauce update, then failure. One thing that I find confusing, is the instructions say to load the sauce DVD, let it auto run, then copy it to the desktop (my DVD won't auto run….Win 7). Am I reading something wrong here? It makes more sense to me to run it from the desktop after copying it and after changing the sa.ini file? I put the termination date and my keygen date the same on the sa.ini and keygen. Warning date is one month prior. Any advise would be greatly appreciated.
Finally, I'm about ready to give up on this version of Service Advisor. Anyone know where I can buy 4.1 from a reliable source? The guy we've bought from has sold us 3 non-working copies of Service Advisor in a row. Thanks everyone.
bullseyemods
15
4,676
Ok. lets get this working for you. are you trying 2012 data or 2013? no need to copy anything to your desktop.....
the only thing that is important about this first disk is that the sa.ini is adjusted the date dont need to be set to the same as the kg i set it usually to 2050 or 2100 l the. if you are going to be running all the data disks of a saved location on the local or external hdd the file just needs to be modified and stored there.if you are planning on using disks make the mod to the sa.ini file before you burn your disk. if none of this can be done or applied just copy and save disk 1 anywhere in your pc and mod the sa.ini file, you dont need to run it first if you dont have the correct patch file........lets start from scratch, just install sa and use kg and lic the software (dont run sause update) jd sa should open and ask you to load data. do so by mapping the drive to the modified disk and let it do its thing. try that lets see what happens. I would hate to sell you this software. i have made it work this way hundreds of times. if you really cant get it i could log onto your pc with teamviewer and assist you... no charge. it should be very easy install
LGVictoria
30
I have reinstalled SA, confirmed licence working. Ran sauce and then lost the license again. I've reinstalled SA and confirmed the license is working again. I've installed Team Viewer and can give you the id from it via msg. We are Pacific Time, Victoria BC, not sure where you are at? Yes, have AG_201207_01 DVD and this is the DVD I am trying to load. Also, have all the 2013 Data DVD's but they won't work either.
Thanks!
LGVictoria
30
And….I give up. I had installed Service Advisor CF 4.0 and was trying to load the AG_201207_01 data disc. which likely won't work on CF. I think that was my problem. I have the 2013 data discs for CF but they upgrade 4.0 to 4.1 and then the license fails. I've ordered a new program…4.1. I appreciate all the help on this forum, unfortunately, I had overlooked this compatibility issue.
banshee00
New Member
14
Get software
no do nothing. this action is what we want because all its doing is loading the updated sause folder and updating dtac cases. auto load is fine... but what needs to be done is the sa file needs a diffrent warning trigers so it is very important to copy and paste the disk somewhere in your pc. after done loading you change the sa file because when we do the rest of the steps and lic service advisor it will ask you to load data and you set and you change path when it askes change the path to your copied file, then continue to load the data with the patch sa you creat. this sa file tells the service advisor programs the expoeration if disks, so if the sa file is not changed the disks will never open because they are expired. understand this? if not i will make a file you can download with step by step skreen captures.
Can you make the keygen and the data disks for upgrade to 4.1? I need to change the expiration dates of the license. The host id is 206a8a304b833c3f6d6e. Thanks in advance. Banshee00
cornjsag
1
1,820
Hello Bullseyemods. Could you help me about my SA? I have installed and the SA 4.0.002 crack. The DVD data own the 201301. I did exactly as ordered with SA.INI but message appears that the SA version is not compatible with the DVD. SAUCE not updated the folder to change, but I know she will move to the SA version 4.1.011. The patch has not been updated at the time of the crack. I got to change the record of 201012 to 201301, but only asked to update the SA, and marked cancel. Still in version 4.0.002. I need to have the data DVD in 2012? Can you help me?
Sorry Ingles Google translator...
