JLR SDD V 150 FULL
JLR SDD V 150 FULL
IDS SDD Land Rover/Jaguar is a dealer diagnostic program for Land Rover/Jaguar.
SDD works with Land Rover/Range Rover since 2005 and Jaguars from 1995.
Supported devices:
VCM I & II, Rotunda
Da-Dongle
Drewtech Mongoose JLR
JLR VCI
[IMPORTANT]Requirements:
O.S.: Windows 7
Acrobat Reader 10+
Internet Explorer 8 or 9
Hard Drive: 80 GB of available space
Conflicts:
SDD can't be installed on the same PC with Ford/Mazda IDS and other programs that derived from Ford IDS.
Installation order:
Install full package - SDD_{version}.00_FULL.exe
Install Land Rover files - VDF_L{A,V}_{version}.exe
Install Jaguar files - VDF_J{A,V}_{version}.exe
Install Pin-point tests - SPA_{version}.exe
Install updates - SDD_{version}.**.exe
If you use 64-bit Windows you MUST run CMD.exe with administrative rights and execute next command:
Code:
mklink /D "C:\Program Files\JLR" "C:\Program Files (x86)\JLR"
Install drivers for diagnostic device.
Disabling automatic updates
Need to remove/rename folder:
Win7 - "C:\ProgramData\FLEXnet\Connect\Database"
WinXP - "C:\Documents and Settings\All Users\Application Data\FLEXnet\Connect\Database"
Remove message due to the fact that updates not installing
Need to remove/rename file:
Win7 - "C:\ProgramData\JLR\IDS\Log Files\InstallationLog.txt"
WinXP - "C:\Documents and Settings\All Users\Application Data\JLR\IDS\Log Files\InstallationLog.txt"
Resolve troubles:
Can't download calibration files:
in SDD go to "Settings" tab;
check that dialer information is set;
go to "System Utilities" -> "Network options" and press "Activate" button.
Good Luck
Supported devices:
VCM I & II, Rotunda
Da-Dongle
JLR VCI
O.S.: Windows 7
Acrobat Reader 10+
Conflicts:
Installation order:
Code:
Resolve troubles:
Good Luck
- Vivid Workshop Data 2015 Fee download
- Multiecuscan 3.6 [04.2017] Full Patch + Instruction
- Actia Multidiag KG 01.2013
- Multiecuscan 3.7 [07.2017] Full Patch + Instruction
- ElsaWin 6.0 Plus VW [01.2017] Multilingual
- VCDS lite VAG-COM 409 + CRACK+ USB Drive
- Vivid WorkShopData v10.2 full KG 1 LINK Download
- Vediamo License KG 05.00.05
- Fiat Multiecuscan 3.5 [2.2017] Full Patch Instruction
- Multiecuscan 3.9 R1+FIX Full Patch + Instruction
- Volvo PTT 2.03.40 With Full
- DVD Software Volvo PROSIS Construction Equipment Manuals and EPC
- Wurth WOW 5.00.12 [04.2016]
- ELSAWin 6.0 AUDI Database [03.2017]
- Autocom Cars & Heavy Duty R1 2016
