International Truck onCommand ISIS [04.2015] + Installation Guide
Languages: English, Spanish, French
Type: International Service Information, Master service Manual
Win: WinXP, Vista, Windows7
1 DVD & Instruction Install Present
Year: 04.2015
Region: Europe
Link High Speed on Google Drive/ 7 Parts
PASS: Thanks + Send to email " autorepairmanuals.ws@gmail.com"
The 2015 update to the ISIS CD continues the enhancements to the completely new viewing system which was introduced on the 2015 DVD. The ISIS DVD is Internet Explorer 5 compatible.
This will make it easy to link to different types of information. Much of the content has been cleaned up.
Also, there is an update to the ActiveCGM control that is used to display the graphics.
You only need the update if you are running on Windows XP.
Models List:
1000
1552
1652
2000
2500
2574
2600
2674
3000 FE
3000 RE
3000
3200
3200 IM
3300
3400
3600
3700
3800
3900
4100
4200
4300
4400
4700
4800
4900
5000
5000i
5500i
5600i
5900i
7100
7300
7400
7500
7600
7700
8100
8200
8300
8500
8600
9000
9000I
9100
9100I
9200
9200I
9300
9400
9400I
9600
9700
9800
9800SFA
9900
9900I
9900IX
BE 200
CE 200
CE 300
CE BUS
CE S BUS
CF 500
CF 600
City Star
Dura Star
FE BUS
HC BUS
IC BUS
LC BUS
Lone Star
MXT
Pay Star
Pro Star
RE 300
RE BUS
RE S BUS
RXT
Tran Star
Work Star
International Vendors:
AEROQUIP
AKW
ALLISON
ANCHORLOK
AXILOCK
BENDIX
BOSCH
CUMMINS
DANA SPICER
DAYCO
DELCO
DELCO-REMY
DETROIT DIESEL
DOW CORNING
EATON
EATON FULLER
FABCO
FULLER
GOLD SEAL
GUNITE
HALDEX/EATON
HENDRICKSON
HOLSET
HORTON
KYSOR
LEECE NEVILLE
LUCAS VARITY
LUK
MERITOR
MGM
MIDLAND
MODINE
MOR/RYDE
MOTOROLA
MPSI
NEWAY
PRESTOLITE
REYCO
ROCKWELL
SANDEN
SHEPPARD
SIKKENS
SPICER
STOPMASTER
TRW
VICKERS
WABCO
WACKER
YORK
International Engines:
MAXXFORCE DT
MAXXFORCE 5
MAXXFORCE 7
MAXXFORCE 9
MAXXFORCE 10
MAXXFORCE 11
MAXXFORCE 13
DT 360
DT 408
DT 466
DT 466E
DT 530
DT 570
DTA 360
DTA 466
HT 530
HT 570
T 444E
VT 365
VT 275
530
530E
7.3L
MWM Acteon
International Master Service Manual (Truck Group)
International Master Service Manual (Engine Group)
International Vehicle Recall Campaigns
International Authorized Field Change (AFC) Letters
International Technical Service Information (TSI) Letters
Installation Guide:
- Run setup.exe and wait complete install
- After no run software copy folder "document" to c:\OCSI
- Run software, click support, choose disk C: , click update
- Restart software
You should be logged in as regular user of the PC. When running the setup.exe
you may get a box asking if you want to run the Install program as another user.
If you are not an Administrator, then you should have the administrator fill in user name and password here.
This program uses an ActiveX control that gets installed separately once a line drawing is encountered when browsing thru the Service Manual.
It would be a good idea if you are doing this setup for someone who doesn't have Administrator rights to go to the help screen off the main ISIS screen and load the control from there.
Someone without Administrator rights can't install the ActiveX control.
If you do the setup as one user and another user wants to run the application,
if the Vehicle Diagnostics folder is not found on the desktop, you can create a shortcut from the C:\NAV\ISISII\msmframe.htm to the desktop (if running from PC), or a shortcut from that file on the CD (if running from CD).
Running the Master Service Manual:
You may get the following messages in the Master Service Manual screen. You must answer the prompts properly to get it to work
Active content can harm your computer or disclose personal information. Are you sure you want to allow CDs to run active content on your computer?
You must click Yes
To help protect your security, Internet Explorer has restricted this file from showing active content that could access your computer. Click here for options.
One option is "Allow blocked content". Select that option.
Allowing active content such as script and ActiveX controls can be useful, but active content might also harm your computer. Are you sure you want to let this file run active content?
You must click Yes
Scripts are usually safe. Do you want to allow scripts to run?
You must click Yes
