Auto
Driver
625
1,779,985
Honda HDS 3.101.019 + ECU Rewrite [08.2016] Full + Instruction
Type: Dealer diagnostic software , ECU Rewrite for Honda & Acura
Region: USA
Version: 3.101.019
Win: WinXP, Vista, Windows7 32 & 64 bit
1 DVD FULL Pack
Year: 08.2016
HDS Database version: 22.06.2016
ECU Rewrite: 08.30.2016
Medicine: Reg file present
High speed link download from our serve
Pass: Thanks + PM Email "autorepairmanuals.ws@gmail.com"
Instruction:
1. Open the HDS PC folder. Run the Setup and choose either the USA market. If your in a different market, choose USA anyway.
2. After it installs, use either the 32 bit or 64 bit dealer patch, depending on what your Windows system is. MAKE SURE TO CHOOSE THE RIGHT PATCH.
2a. If you are going to use a Honda HIM or a Honda GNA600 scan tool, use the HIMGNA patch. If you are using a different device, you can leave it alone.
3. Open the HDS software and press F12, choose the device you will be using.
3a. If you are in a different market than USA, choose the market you are in.
4. Open the ihds folder. Run the setup and let it install.
5. If you are NOT using the OEM Honda MVCI tool, install the J2534 Rewrite software so you can update modules via passthru.
6. Enjoy!
Dealer diagnostic Honda & Acura. Includes versions for PC, HDS Pocket Tester. Contains a calibration Honda and Akur USA + Canada.
CM Update ECU Rewrite
Diagnostic System
Device manger
OBD Scantool
Teradyne Wireless Card Manager
Screen Capture
Unit Conversion Tool
Markets:
USA
Canada
Europe
General
Japan
This software turns your laptop or desktop computer into a functional diagnostic system tool capable of reading OBD diagnostic codes.
Honda functions include:
•DTC reading and clearing
•Snapshot function (capture data relative to a trigger event)
•Vehicle data display (value, line graph, or bar graph formats)
•DLC locator diagrams
•Data list display (real-time display of ECU parameters)
•Onboard tutorial
•Generic scan tool runs basic tests on non-Honda/Acura vehicles (HDS Tablet and Pocket Tester only)
•Control module update functions (HDS Tablet and Pocket Tester only)
Hardware and software requirements:
•PC or laptop with either Windows 2000 Professional (SP4 or later) or XP (SP1 or later)
•Hard disk drive with at least 400MB of free space
•CD-ROM drive (if a high-speed Internet connection is not available)
•Type II PC card drive (HDS Tablet only)
•RS232 port required to connect PC to HIM (PC version software only)
•Monitor capable of displaying in VGA mode or above (1024 x 768 recommended)
•Internet connection (high-speed connection recommended)
Communication Interface:
HIM / GNA660
NOTE: this program works only with the diagnostic interface GNA600 or HIM.
