Honda HDS 3.016.033 + ECU Rewrite [2015] Full Instruction
Manufacture: Dealer diagnostic software for Honda & Acura
Region: USA + Canada
Version: 3.016.033
Year: 2015
Medicine: freeware
Pass: Thanks + Comment on below
Desciption:
Dealer diagnostic Honda & Acura. Includes versions for PC, HDS Pocket Tester. Contains a calibration Honda and Akur USA + Canada.
CM Update ECU Rewrite
Diagnostic System
Device manger
OBD Scantool
Teradyne Wireless Card Manager
Screen Capture
Unit Conversion Tool
Markets:
USA
Canada
Europe
General
Japan
This software turns your laptop or desktop computer into a functional diagnostic system tool capable of reading OBD diagnostic codes.
Honda functions include:
Code:
•DTC reading and clearing
•Snapshot function (capture data relative to a trigger event)
•Vehicle data display (value, line graph, or bar graph formats)
•DLC locator diagrams
•Data list display (real-time display of ECU parameters)
•Onboard tutorial
•Generic scan tool runs basic tests on non-Honda/Acura vehicles (HDS Tablet and Pocket Tester only)
•Control module update functions (HDS Tablet and Pocket Tester only)
Hardware and software requirements:
Code:
•PC or laptop with either Windows 2000 Professional (SP4 or later) or XP (SP1 or later)
•Hard disk drive with at least 400MB of free space
•CD-ROM drive (if a high-speed Internet connection is not available)
•Type II PC card drive (HDS Tablet only)
•RS232 port required to connect PC to HIM (PC version software only)
•Monitor capable of displaying in VGA mode or above (1024 x 768 recommended)
•Internet connection (high-speed connection recommended)
Communication Interface:
Quote:
HIM / GNA660
NOTE: this program works only with the diagnostic interface GNA600 or HIM.
Archive include:
- HDS Install disk
- HIM-GNA
- DEALER-CODE
- HONDA HDS-UN-INSTALL
- HOW TO INSTALL HDS
- USA-Dealer
- USA-Dealer-64BIT
Instruction Guide Installation:
If you have an older version of software installed you need to REMOVE all traces.
you can use the HONDA HDS-UN-INSTALL video.
SPX MVCI Instructions
If installing for europe use the DEALER CODE in the DEALER-CODE.txt File.
If using SPX MVCI RUN THE Setup.exe in the HDS PC Folder.
If installing for the USA use the USA-DEALER.reg
(Dealer-Reg-64bit.reg is for 64bit systems)
When finished run HIM-GNA.exe
thats it, HDS and Rewrite installed.
If using HONDA HIM or GNA600 Rename these two files inside HDS PC
ECURewrite TO 1ECURewrite
SPXMVCI to 1SPXMVCI
Now Run the Setup.exe inside the HDS PC Folder.
If installing for the USA use the USA-DEALER.reg OR USA-DEALER-64BIT.reg at the end of this step
Now rename the 1ECURewrite folder back to ECURewrite and go inside the folder and open the HIM.txt File
you will see other files
AA = Amrican Acura
AH= American honda
CH = China
EU - Europe
GE = General
JP = Japan
LA = Latin American
open your regional file and copy the content and PASTE it into the HIM.txt file and save it
Now run the Setup.exe in the same folder , this will install Rewrite for HIM and GNA600
Select you tool at the end.
Version: 3.016.033
Year: 2015
Medicine: freeware
Desciption:
Diagnostic System
Device manger
OBD Scantool
Screen Capture
Markets:
USA
Canada
Europe
General
Japan
Code:
•Onboard tutorial
Code:
Quote:
HIM / GNA660
Archive include:
- HDS Install disk
- HIM-GNA
- DEALER-CODE
- USA-Dealer
- USA-Dealer-64BIT
SPXMVCI to 1SPXMVCI
AA = Amrican Acura
AH= American honda
CH = China
EU - Europe
GE = General
JP = Japan
LA = Latin American
- Honda EPC General [05.2016] Full Instruction + Patch
- Honda HDS 3.101.019 + ECU Rewrite [08.2016] Full + Instruction
- Honda HDS 3.017.012 + ECU Rewrite + HFL (HFT) Control Unit Update Full 2016
- Honda HDS 3.102.051 + ECU Rewrite [03.2018] Full + Instruction
- Honda HDS 3.101.015 + ECU Rewrite [06.2016] Full + Instruction
- Honda HDS v3.102.004 + i-HDS1.003.003 + ECU Rewrite [06.2017] Full + Instruction
- Honda HDS 3.008.008 Full How to install
- Honda HDS v3.101.044 + ECU Rewrite [12.2016] Full + Instruction
- Honda HDS 3.102.029 + ECU Rewrite [07.2017] Full + Instruction
- Honda EPC General v3.00 [11.2014] Full Instruction + Patch
- Honda Diagnostic System I-HDS 1.006.027 + HDS 3.104.024 [03.2021]
- Honda EPC 11-2014 + Instruction
- HONDA ELECTRONIC PARTS CATALOG EPC [03.2018]
- Honda Diagnostics System Ver 3.002.032
- Honda HDS 3.102.038 + ECU Rewrite [10.2017] Full + Instruction
