Hino Truck L Series Body Builder Book 2023
Brand: Hino
Type of Manual: Body Builder Book
Model: Hino L Series Truck
Book Number: BM2152B6CAN
CONTENTS:
Chapter 1 Preface
Purpose
Relation To Other Hino Manuals
Non-Guarantee
Certification And Compliance With Safety Regulations And Standards
Installation, Modification, And Alteration
Change Of This Book
Relation Between This Book And The Vehicle Warranty
Further Information
Chapter 2 Government Regulations
Safety Standards
Vehicle Noise Regulations Information
Emission Control Regulations
Chapter 3 Specifications
Model Line-Up
Weights And Dimensions
Weight Distribution Of The Optional Equipment
Cautions To Install Various Kind Of Body
Chapter 4 Truck Body And Special Equipment Installation Procedure And Precautions
General Precaution
Weight Distribution And Center Of Gravity
The Tilt Hood
The Fuel Nylon Tube
Caution Label Of Fuel Tank
Installation Of Fender And Mudguard
Welding Work
Minimum Clearance With Rear Spring And Rear Spring Hanger
System Control Computers
Precaution For Abs And Vsc
Precaution For Ldw And Cms
The Antenna Position
Removing The Instrument Panel
Additional Wiring In The Engine Compartment
Resetting Of Vehicle Speed Sensoring Pulse Converter
Maximum Vertical Travel Range Of Lateral Rod (Rear Air Suspension Model)
Leveling Valve (Rear Air Suspension Model)
Exhaust System
Dpr Filter
Def - Scr System
Vertical Exhaust Tail Pipe
Installing Equipment On The Cab Roof
Vehicle Storage
Chapter 5 Chassis Modification
General Cautions
Chassis Frame Properties
Chassis Frame Drilling
Flange Cutting
Chassis Frame Welding
Rear Overhang Extension
Stiffening Of Side Pails
Wheelbase Modifications
Parking Brake Control Cable Modification And Alteration
Propeller Shaft Modification And Alteration
Service Brake Modifications
Electric Wiring Modifications
Alteration Of Exhaust System
Cautions Needed In Additional Machining And Alteration Of The Cab
Chapter 6 Instructions For Building Up Of Rear Body
Main Sill (Sub-Frame)
Rear Axle
Rear Body Length And Main Sill (Sub-Frame) Dimensions
U-Bolts
Mounting Of Rear Fender And Mudguard
Chapter 7 Electrical System
Lamps, Reflective Devices And Associated Equipment
Fuse Block, Relay Panel And Fusible Link Block
Installation Of Additional Switches
Alternator Output Characteristic
Electrical Power Sources
Back-Up Alarm (Opt)
Harness Wiring
Body Builder Can
Installation Of The Battery Disconnect Switch
Installation Of Flasher Cutting
Trailer Electrical Connection
Chapter 8 Painting
General Cautions
Cautions For Use Of Thinner And Solvents Containing Thinner
Color Code Of Top Coat Paint For Cab
Proper Precaution Of The Top Coat Of Paint
The Parts Which Have No Resistance To High Temperature And Their Temperature Limit
Cautions For Forced Drying
Parts And Allowable Heat Limit
How To Remove And Reinstall The Parts Of The Hood And Cab
Weather Strip Installation
Handling Of Electronic Control Unit (Ecu)
Cautions For Painting The Tire Disc Wheels
Precaution For Installing Wheel Onto The Vehicle
Chapter 9 Chassis Drawings
Cab Drawings
Cab Back Drawings
Chassis Drawings
Chassis Frame Drawings
Drilling Holes On The Side Rail (Around Rear Suspension)
Chapter 10 Mounting Details Of Chassis Equipment
Air Tank
Exhaust System
Chapter 11 Power Take Off (Pto)
Transmission P.T.O.
Split Shaft P.T.O.
Transmission Models To Be Installed Hino's Vehicles
Other Notices
Mounting Position Of Transmission P.T.O. Assy
Engine Rev. Control For Mounting Of Body Or Equipment
Signal For Allison Transmission
Chapter 12 Other Data (Suspension Deflection Chart, Brake Piping Diagram, Electric Wiring Diagram, Connectors, Metric, U.Scustomary Unit Equivalents)
Connectors
Metric/U.S. Customary Unit Equivalents
Brand: Hino
CONTENTS:
Chapter 1 Preface
Purpose
Non-Guarantee
Change Of This Book
Further Information
Safety Standards
Model Line-Up
General Precaution
The Tilt Hood
The Fuel Nylon Tube
Welding Work
Exhaust System
Dpr Filter
Def - Scr System
Vehicle Storage
General Cautions
Flange Cutting
Rear Axle
U-Bolts
Back-Up Alarm (Opt)
Harness Wiring
Body Builder Can
Chapter 8 Painting
General Cautions
Cab Drawings
Cab Back Drawings
Chassis Drawings
Air Tank
Exhaust System
Transmission P.T.O.
Split Shaft P.T.O.
Other Notices
Connectors
- Hino Dutro Workshop Repair manual(INCLUDING WIRING DIAGRAM/GEARBOX OVERHAUL)
- Hino Series 500 Workshop Manual
- Hino Series 300 Workshop Manual
- Hino FD, FE, FF, SG Engine Service Manual 2002
- Hino Series 700 Workshop Manual
- Hino 300 Dutro S05C Workshop Manual
- Hino Diesel Engine W04D,W04C,W04C-TI Workshop Manual
- Hino E13C Engine Electrical Circuits
- HINO 238, 258LP, 268, 338 SERIES WORKSHOP MANUALS
- Common Rail System for HINO Dutro / TOYOTA Dyna N04C-T# Type Engine
- Hino DUTRO WU & XZU Series Repair Manual
- Hino E13C Type Engine Service Manual
- Specification Technical Motor Hino SO5C-TAJ08C-TT
- Catalog Hino Series 300,500,600,700
- Hino Truck Model 700 Series ABS System (English)
