James Rodrigues
Driver
1,447,646
HINO Diagnostic eXplorer DX2 1.1.20.7 [07.2020] Diagnostic Software
Size: 127mb (Winrar files)
Region: All regions
Interface Languages: English, Russian, Janpanese, Chinese, Spanish, Thai, French, Indonesian, Vietnamese
Database Languages: Only English
OS: Windows 7, Window 8, Window 10 32 & 64 bit (Tested on win 10 pro 1607 64bit)
Year: 2020
Date: [07.2020]
Version: 1.1.20.7
Type: Hino DX2 diagnostic program for trucks Hino
Print Functions: Present
Instruction: Present
Medicine: Present
High-Speed Link Download
After download send to email to get pass autorepairmanuals.ws@gmail.com
Description : Hino DX2 diagnostic program for trucks Hino (Diagnosis, Customization, Reprogramming, Simulation)
- US markets, Japan, Russia and others
- RUS, DEF, JPN, USA , CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
The program runs on any Windows.
BENEFITS TO HINO DX I Low speed HINO DX I in contact with large amounts of data, failure to extend the functionality of the software led to the need to develop a new diagnostic system.
From 2015 to diagnose HINO vehicles introduced to the work of the next generation system
- HINO Diagnostic eXplorer II (HINO DX II) ON THE ACTIVATION and updates to the PM !!!
Hino Explorer Diagnostic diagnostic software for Hino Trucks
The HINO Diagnostic eXplorer (hereafter referred to as HINO DX) is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
Main Functions
Acquires and deletes trouble data.
Links diagnostic trouble codes read from the ECU to corresponding diagnostic work flow sequences and directly displays the required data.
Obtains sensor conditions from the vehicle when trouble occurs (Freeze Frame function).
Monitors the sensors and actuators equipped on the engine (Data Monitor function) and tests the operation of solenoid valves by forcefully operating them (Active Test function).
Simulates diagnostic work with only a PC(Simulation function).
Automatically saves fetched ECU data and analyzes trouble based on the saved data even when the cause of trouble cannot be grasped.
Full Customization Capability
* Turn on Engine Protection Shutdown System
* Set Maximum Vehicle Speed
* Set Maximum Cruise Control Speed
* Set PTO idle speeds fixed and variable
* Change Injector Calibration QR Code when replacing injectors
* Supply Pump relearning when replacing SCV or supply pump
* Complete DPF testing and regeneration capabillity
* Built in Help Menus for troubleshooting specific diagnostics
