Support
Cleaner
180
99,627,013
HINO Diagnostic eXplorer DX2 1.1.21.6 [08.2021] Diagnostic Software
Download this document, you need 7500 Gallons
Size: 210.4 Mb (Winrar Files)
Brand: HINO
Region: All regions
Interface Languages: English, Russian, Japanese, Chinese, Spanish, Thai, French, Indonesian, Vietnamese
Database Languages: Only English
OS: Windows 7, Window 8, Window 10 32 & 64 bit (Tested on Window 10 Pro v1904)
Date: 2021/08
Version: 1.1.21.6
DP File: 2.6.21.0
Type of vehicle: Trucks
Type of software: Hino DX2 diagnostic program for Hino Trucks Diagnostic eXplorer
Print Functions: Present
Instruction: Present
Medicine: Present
Supporter: Present by Teamviewer, Anydesk....etc..
High-Speed Link Download
* Models List of Hino DX2 08/2021 diagnostic software:
Hino 700 Series Diagnostic Software
Hino 600 Series Diagnostic Software
Hino 500 Series Diagnostic Software
Hino 300 Series Diagnostic Software
Hino Bus/Coach, Heavy Diagnostic Software
Hino Bus/Coach, Medium Diagnostic Software
Hino Bus/Coach, Light Diagnostic Software
Hino Retro Diagnostic Software
Hino Industrial Engine Diagnostic Software
Hino Others Diagnostic Software
Hino 300 Series (COE) (North America) Diagnostic Software
Hino 300 Series (N engine) Diagnostic Software
Hino 300 Series (J engine) Diagnostic Software
Hino BUS Diagnostic Software
Hino FC bus Diagnostic Software
Hino Bus/Coach, Light (Liesse2) Diagnostic Software
Hino 200 Series (GD Engine) Diagnostic Software
Description: Hino DX2 08/2021 diagnostic program for trucks Hino (Diagnosis, Customization, Reprogramming, Simulation)
- US markets, Japan, Russia and others
- RUS, DEF, JPN, USA , CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
The program runs on any Windows.
BENEFITS TO HINO DX I Low speed HINO DX I in contact with large amounts of data, failure to extend the functionality of the software led to the need to develop a new diagnostic system.
From 2015 to diagnose HINO vehicles introduced to the work of the next generation system
- HINO Diagnostic eXplorer II (HINO DX II) ON THE ACTIVATION and updates to the PM !!!
Hino Explorer Diagnostic diagnostic software for Hino Trucks Version 1.1.21.6
The HINO Diagnostic eXplorer (hereafter referred to as HINO DX) is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
Main Functions
Acquires and deletes trouble data.
Links diagnostic trouble codes read from the ECU to corresponding diagnostic work flow sequences and directly displays the required data.
Obtains sensor conditions from the vehicle when trouble occurs (Freeze Frame function).
Monitors the sensors and actuators equipped on the engine (Data Monitor function) and tests the operation of solenoid valves by forcefully operating them (Active Test function).
Simulates diagnostic work with only a PC(Simulation function).
Automatically saves fetched ECU data and analyzes trouble based on the saved data even when the cause of trouble cannot be grasped.
Full Customization Capability
* Turn on Engine Protection Shutdown System
* Set Maximum Vehicle Speed
* Set Maximum Cruise Control Speed
* Set PTO idle speeds fixed and variable
* Change Injector Calibration QR Code when replacing injectors
* Supply Pump relearning when replacing SCV or supply pump
* Complete DPF testing and regeneration capabillity
* Built in Help Menus for troubleshooting specific diagnostics
Master
Cleaner
719
4,408,523
#2
Region: All regions
Date: 2021/08
Version: 1.1.21.6
Type: Hino DX2 diagnostic program for trucks Hino
Medicine: Present
