HINO Diagnostic eXplorer 2 (DX2) v1.1.17.3 Multilingual + Activator
Win | 116 MB
Diagnostic eXplorer reads the failure information from the ECU in the system where the failure occurred, and then displays the troubleshooting procedure so that its location can be pinpointed. In addition to failure information, also reads information which the ECU uses to control the system such as values recognized by various sensors, actuator control states, system settings.
Diagnostic eXplorer can display the information as raw data or in diagrams. Furthermore, makes it possible to change each individual systems' settings. Therefore, Diagnostic eXplorer was developed as a general ECU configuration tool, and by understanding its inner mechanisms and using it correctly, it is possible to manage electronic control systems in Hino products swiftly and effectively.
Homepage -
Code:
http://www.hino-global.com
• CPU: Pentium/Athlon 2 GHz or higher
• RAM: 512 MB of system memory
• Hard Drive: 5 GB of available space
• Optical Drive: DVD-ROM
• Required Hardware: Hino-Bowie Interface
- Full Software Volvo IMPACT 2011
- Volvo VCADS Pro V2 Full
- VCDS Lite 1.0 full
- VOLVO IMPACT 2015
- Download Cummins INCAL 04/ 2013 the newest
- Volvo VCADS Pro 2.3.500
- Tech Tool V2.01 FULL Installation
- Perkins SPI 2012A KG
- Volvo prosis 2013 full active
- Metafile for CUMMINS CALTERM
- Allison Doc 8 KG
- WABCO TEBS-E v2.0 Activation + PIN
- How to your ECM with Calterm III
- CAT SIS ET CBT 2012 Master Install
- DVD Software MAN MANTIS EPC Update 477 (02.2012)
