GMC FAULT CODES
GMC FAULT CODES
2000-05 Engine P codes:
0030 HO2S Heater Control Circuit Sensor 1
0036 HO2S Heater Control Circuit Sensor 2
0101 MAF Sensor Performance
0102 MAF circuit low freq
0103 MAF circuit high freq
0107 MAP low voltage
0108 MAP high voltage
0112 IAT low voltage
0113 IAT high voltage
0117 ECT low voltage
0118 ECT high voltage
0121 TP sensor performance
0122 TP sensor low voltage
0123 TP sensor high voltage
0125 ECT insufficient temp for closed loop
0128 ECT (Eng Cool Temp) below thermostat regulating temp
0130 HO2S Closed Loop Performance Sensor 1
0131 HO2S low voltage Sensor 1
0132 HO2S high voltage Sensor 1
0133 HO2S slow response Sensor 1
0134 HO2S insufficient activity Sensor 1
0135 HO2S heater performance Sensor 1
0137 HO2S low voltage Sensor 2
0138 HO2S high voltage Sensor 2
0140 HO2S insufficient activity Sensor 2
0141 HO2S heater performance Sensor 2
0171 Fuel Trim lean
0172 Fuel Trim rich
0201 Injector 1 circuit fault
0202 Injector 2 circuit fault
0203 Injector 3 circuit fault
0204 Injector 4 circuit fault
0205 injector 5 circuit fault
0206 injector 6 circuit fault
0230 fuel pump relay control circuit
0243 SC boost solenoid control circuit error
0300 engine misfire detected
0301 Misfire cylinder #1
0302 Misfire cylinder #2
0303 Misfire cylinder #3
0304 Misfire cylinder #4
0305 Misfire cylinder #5
0306 Misfire cylinder #6
0325 knock sensor system fault
0327 knock sensor circuit fault bank 1
0332 knock sensor circuit fault bank 2
0335 CKP sensor A circuit
0336 CKP circuit fault/performance
0340 CMP sensor circuit
0341 CMP sensor performance
0385 CKP sensor B circuit
0401 EGR insufficient flow
0403 EGR solenoid control circuit fault
0404 EGR open position performance
0405 EGR position sensor low voltage
0410 Secondary Air Injection system
0412 Secondary Air Injection solenoid circuit
0418 Secondary Air Injection pump relay circuit
0420 catalyst system low efficiency
0440 EVAP system fault
0442 EVAP system small leak detected
0443 EVAP purge sol control faule
0446 EVAP VENT system performance
0449 EVAP VENT sol control circuit
0452 fuel tank pressure sensor low volt
0453 fuel tank pressure sensor hi volt
0462 fuel level sensor low voltage
0463 fuel level sensor high voltage
0480 cooling fan relay 1 control circuit
0481 cooling fan relay 2 control circuit
0506 idle speed too low
0507 idle speed too hi
0522 Eng Oil Pressure Sensor low volt
0523 Eng Oil Pressure Sensor hi volt
0530 A/C pressure sensor circuit fault
0560 PCM system voltage error
0601 PCM Read Only Memory Fault
0602 PCM not programmed
0603 PCM Long Term Memory Reset
0604 PCM Random Access Memory Fault
0605 PCM Programming Read Only Memory Fault
0606 PCM Internal Performance
0607 PCM Performance
0620 generator performance
0650 MIL control circuit
0654 Engine Speed Output Circuit
0656 fuel level output circuit
1106 MAP sensor circuit intermittent hi volt
1107 MAP sensor circuit intermittent low volt
1111 IAT sensor intermittent hi volt
1112 IAT sensor intermittent low volt
1114 ECT sensor intermittent low volt
1115 ECT sensor intermittent hi volt
1121 TPS intermittent hi volt
1122 TPS intermittent low volt
1133 HO2S insufficient switching sensor 1
1134 HO2S transition time ratio sensor 1
1189 Engine Oil Pressure Switch Circuit
1200 Air fuel ratio
1260 Fuel pump speed control relay circuit
1336 Crank Position System Variation not learned
1351 ign control (or coil 1) circuit hi volt
1352 ign bypass (or coil 2) circuit hi volt
1353 ign coil 3 circuit high volt
1354 ign coil 4 circuit high volt
1355 ign coil 5 circuit high volt
1356 ign coil 6 circuit high volt
1361 ign control (or coil 1) circuit low volt
1362 ign bypass (or coil 2) circuit low volt
1363 ign coil 3 circuit low volt
1364 ign coil 4 circuit low volt
1365 ign coil 5 circuit low volt
1366 ign coil 6 circuit low volt
1372 CKP sensor A-B correlation
1374 CKP high to low res freq correlation error
1380 misfire detect - no rough road data avail
1381 misfire detect - no comm w/ EBTCM
1404 EGR closed position performance
1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
1441 EVAP system flow during non-purge
1483 engine cooling system performance
1546 a/c relay control circuit
1554 cruise control feedback circuit error
1571 trac control torque req circuit error
1575 Extended Travel Brake Switch
1585 cruise control inhibit output circuit
1600 PCM Long Term Memory Reset (2)
1602 lost comm w/ EBTCM (ABS) system
1604 lost comm w/ Driver Info Display Control Sys
1605 lost comm w/ HVAC system
1610 lost comm w/ BCM
1621 PCM Long Term Memory Performance
1626 VATS fuel enable signal lost
1629 VATS fuel enable signal not rec'd
1630 VATS learn mode active
1631 VATS start enable signal not correct
1635 5 volt ref circuit 1
1637 charge system indicator lamp control circuit
1639 5 volt ref circuit 2
1640 Output Driver Module (ODM) Circuit 1 Error
1650 Output Driver Module (ODM) Circuit 2 Error
1653 fuel level OR low oil lamp output circuit
1660 Output Driver Module (ODM) Circuit 3 Error
1663 charging sys lamp OR change oil lamp circuit
1670 Output Driver Module (ODM) Circuit 4 Error
1673 Eng cool temp HOT lamp control circuit
1689 Trac control delivered torque output circuit
2000-05 Transmission P codes:
0218 transmission fluid overtemperature
0502 VSS circuit low input
0503 VSS circuit intermittent
0711 trans fluid temp sensor range/performance
0712 trans fluid temp sensor circuit low input
0713 trans fluid temp sensor circuit high input
0716 input speed sensor circuit intermittent
0717 input speed sensor circuit low input
0719 brake switch circuit low input
0724 brake switch circuit high input
0730 incorrect gear ratio
0740 TCC enable solenoid circuit electrical
0741 TCC stuck off
0742 TCC stuck on
0748 pressure control solenoid circuit electrical
0751 shift solenoid A valve performance - no 1st or 4th gear
0752 shift solenoid A valve performance - no 2nd or 3rd gear
0753 shift solenoid A circuit electrical
0756 shift solenoid B valve performance - no 1st or 2nd gear
0757 shift solenoid B valve performance - no 3rd or 4th gear
0758 shift solenoid B circuit electrical
1810 trans fluid pressure valve position switch circuit
1811 maximum adapt and long shift
1814 Torque Converter Overstressed
1819 Internal Mode Switch (IMS) no start / incorrect range
1820 Internal Mode Switch (IMS) Circuit A Low
1822 Internal Mode Switch (IMS) Circuit B High
1823 Internal Mode Switch (IMS) Circuit P Low
1825 Internal Mode Switch (IMS) Invalid Range
1826 Internal Mode Switch (IMS) Circuit C High
1860 TCC PWM solenoid circuit electrical
1870 Trans component slipping
1887 TCC release switch circuit
1997-99 Engine codes
107 MAP low voltage
112 IAT low voltage
117 ECT low voltage
1132 HO2S high voltage Sensor
1133 HO2S slow response Sensor
1134 HO2S insufficient activity Sensor
1135 HO2S heater performance Sensor
1137 HO2S low voltage Sensor
1138 HO2S high voltage Sensor
2140 HO2S insufficient activity Sensor
2141 HO2S heater performance Sensor
2171 Fuel Trim lean
172 Fuel Trim rich
449 EVAP VENT sol control circuit4
550 Power Steering Pressure switch circuit
705 trans range switch circuit
706 trans range switch performance
1257 Supercharger engine overboost
1350 Bypass line monitor
1520 Park/Neutral Position (PNP) switch circuit
1573 lost comm w/ EBTCM (ABS) system
1619 Engine oil life monitor reset switch circuit
1641 A/C clutch relay control circuit
1642 change engine oil lamp control circuit
1646 SC boost solenoid control circuit error
1651 cooling fan relay 1
1652 cooling fan relay 2
1662 cruise control inhibit output circuit
1665 EVAP VENT solenoid circuit
1667 Fuel pump speed control relay circuit
1671 MIL control circuit
1672 low engine oil level lamp control circuit
1676 EVAP purge sol control circuit
1997-99 Transmission P codes.
741 TCC stuck off
742 TCC stuck on
0171 Fuel Trim lean
0172 Fuel Trim rich
1200 Air fuel ratio
0741 TCC stuck off
0742 TCC stuck on
107 MAP low voltage
112 IAT low voltage
117 ECT low voltage
2171 Fuel Trim lean
172 Fuel Trim rich
741 TCC stuck off
742 TCC stuck on
