Autotruck
Driver
71
263,727
Download AllisonDOC 8.4 Full
Download this document, you need 600 Gallons
Download AllisonDOC 8.4 Full Crack
Allison DOC(TM) (Diagnostic Optimized Connection) For PC - Service Tool
FEATURE LIST for Version 8.0.0 for Dec 18, 2008
1 ) Monitoring of 1K/2K and 3K/4K 4th Generation Controls.
2 ) Monitoring of CEC2 Electronic Control Unit (ECU) data.
3 ) Monitoring of CEC (On-highway and Off-highway) Electronic Control Unit (ECU) data.
4 ) Monitoring of World Transmission Electronic Control (WTEC) II/III Electronic
5 ) TAC Data Collection capability for WTEC III ECUs.
6 ) Monitoring of 1000/2000/2400 Series Transmission Control Module (TCM) data.
7 ) Display of multiple transmission parameters and Diagnostic Trouble Codes.
8 ) Display of Failure Records.
9 ) A graphic display of limited data using analog and digital gauges.
10 ) Reprogramming of ECU or TCM settings.
11 ) Ability to activate/reset tests and tranmission capabilities (clutch
test, solenoid test, adaptive shifts, throttle calibration, etc.)
12 ) Recording of vehicle data bus information into snapshot sessions.
13 ) Display of vehicle data bus traffic.
14 ) E-mailing of snapshots along with optional comments.
15 ) Ability to Export snapshots to a comma-delimited file (4th Gen Controls only).
16 ) Ability to create/display/print diagnostic reports.
17 ) Access to transmission Troubleshooting Manuals, including context-sensitive links.
18 ) Integrated help with video-based training materials.
19 ) The ability to launch TCM Reflash when installed.
20 ) Automated application updates.
21 ) Access to Service Information Letters via the Allison Transmission web site.
22 ) Ability to monitor TRANSHEALTH(TM) status and to generate and display TRANSHEALTH(TM)
reports.
23 ) Display of vehicle prognostics information, when supported by a 4th Generation TCM.
24 ) Language support for English, French, Japanese, Spanish, Russian, German, Portuguese, Simplified Chinese, Traditional Chinese, and Korean.
INSTALLATION INSTRUCTIONS:
Notes:
- You must have administrative privileges to install and uninstall this program.
- On Windows Vista you must have administrative privileges to run the program and UAC
must be disabled.
- Allison DOC (TM) requires (and automatically installs) Adobe Acrobat Reader V7.0.
If you have previous versions of Adobe Reader on your PC, you should uninstall
those versions prior to running the Allison DOC (TM) installation program.
1 ) Insert installation CD into CD-ROM Drive.
2 ) If installation process does not begin momentarily, Select "Start"->"Settings"->"Control Panel"
from the "Start" menu on the task bar.
3 ) From the Control Panel select "Add/Remove Programs".
4 ) Select "Install" on the Add/Remove Programs Properties Dialog.
5 ) Select "Next".
6 ) Do NOT reboot/restart if prompted by Adobe Reader installation or Windows Media Player
installation.
NOTES:
1 ) Some 'Help' sections of 'Allison DOC (TM)' require
'Adobe Reader'. Adobe Reader version 7.0 is automatically installed if needed.
2 ) NEXIQ Universal drivers version 1.0 are located on this CD in the "NEXIQ Universal Drivers" folder.
Run "setup.exe" to install the drivers.
3 ) NEXIQ USB-Link drivers version 5.4 are located on this CD in the "NEXIQ USB-Link v5.4" folder.
Run "USB-Link5.4.exe" to install the drivers. NEXIQ Universal drivers are not needed for the USB-Link.
4 ) The DLA 2.2.6 drivers are located on this CD in the "Noregon DLA 2.2.6" folder. Run "setup.exe"
5 ) The Noregon USB DLA v1.7 drivers are located on this CD in the "Noregon USB DLA v1.7.0.0" folder.
Run "Noregon_USB_DLA_Driver_1.7.0.0.exe" to install the drivers.
6 ) The Noregon RP1210A API Version 2.5.2.0 drivers are located on this CD in the "Noregon RP1210A API"
folder. Run "setup.exe" to install the drivers.
7 ) The DPAIV drivers are located on this CD in the "DPAIV Drivers" folder. The DPAIV drivers are
automatically installed with the application.
8 ) The Noregon Softing RP1210A API is automatically installed with the application. To use a Softing
device with the application, you must install the device drivers and copy the "can*.dll"
('*' is based on the particular device being used) to the Windows folder.
HARDWARE / SOFTWARE CONFIGURATION:
Allison DOC™ For PC – Service Tool V8.0.0 has only been tested and
validated on PCs with the following configurations:
o Microsoft® Windows XP® Professional, Windows 2000® (SP4 or later)
Professional, and Windows Vista® Home Basic (or better)
Note: In order to install and run Allison DOC™ For PC – Service Tool
V8.0.0 on Windows Vista®, the user must have full administrator
privileges, and must have the User Account Control feature turned
OFF.
o 20 GB Hard Drive, (40 GB or greater recommended)
o 600 MB free hard drive space required to install the program (after
software installation, the operating system requires sufficient free
hard disk space to run the program)
o 1GHz (or greater) 32-bit (x86) or 64-bit (x64) processor
o 512MB of RAM system memory (1GB recommended)
o One available USB port—USB 1.1 (USB 2.0 recommended)
o A serial port is required if connecting legacy CEC1 controllers, or
if using the J 44652-A - SPX J1850-VPW (Class 2) translator device
o 16x CD-ROM, (48x or greater recommended)
o Full administrative privileges are required to install, use, and
update the Allison DOC™ For PC–Service Tool
o Internet connection capability (Internet Explorer® 5.0.1 or greater)
(NOTE: A broadband internet connection is recommended for receiving
updates and file downloads)
o Adobe® Acrobat Reader® is installed by default
Error messages, sudden disconnections, and poor performance are some of
the results users will experience if Allison DOC™ For PC – Service Tool
V8.0.0 is installed on PCs that do not meet one or more of the above
specifications.
Translator Device Support:
o For B&B J1708D15 - Noregon RP1210A API version V2.5.2.0 or better.
o For Noregon DLA - V2.2.6 drivers or better; V2.2 firmware.
o For Noregon USB DLA - V1.7 drivers or better; V1.11 firmware.
o For Magikey PDM - NEXIQ Universal drivers V1.0 or better.
o For NEXIQ USB-Link - NEXIQ USB-Link V5.4 or better.
o For Dearborn DPAIV - Drivers are automatically installed with the application.
o For SPX AT1J1850 - no drivers are required.
SUPPORT/CONTACT INFORMATION:
US/Canada: 1-866-621-2128 | International: 1-800-345-2233.
allison1.jpg allison2.jpg allison3.jpg allison4.jpg allison5.jpg allison6.jpg allison7.jpg allison8.jpg allison—connection1.jpg allison—connection2.jpg
and Use this data
key:1
Password: 3
Reprogramming
Password: 3
Product Serial Number: 40000
TAC Data:
Password Autoritation: 1129281110171032015
Password Admin Parameters: 11292871821819613
julianos
56
#2
The Link for this download its not working its says Could not find the file you requested. Please Help.
julianos
56
#4
Yes, I upload new link !
I have managed to download and install the software. However I have issue registering it. I guess the reg file is not working for me. I am suspecting that maybe it is because I running Windows 7 64 bit. Could you help me out of this situation if possible?
