doosanjan
7
490
Doosan DMS 1.41
Download this document, you need 100 Gallons
Doosan Data Monitoring System for use on excavator and wheelloaders 3 & 5 series (newest series)
The Doosan Excavator/Wheel Loader Monitoring Program (also called “DMS-3”) offers
the following functions by connecting Controller (EPOS or VCU) with the user’s IBM PC
compatible PC.
1. Monitoring: You can monitor the current status of equipment installed with
Controller (EPOS or VCU).
2. Graph Output: The major excavator/Wheel Loader sensor data will be displayed in
a graph format. The data can be saved in the hard disk. You can check the
excavator/Wheel Loader’s performance through data comparison and analysis.
3. Force Operation: You can use vehicle diagnosis by forcing Controller (EPOS or
VCU) outputs.
4. Diagnosis: You can check the real-time and past malfunction history maintained by
5. History Data: You can analyze the work patterns when using an excavator/Wheel
Loader, by checking the operation hours, filter/oil information, and daily operation
information.
6. Parameter change protected with code: 18772 (change factory settings)
Codes for rpm change/force operation and flash epos: 11830 and/or 18675
Hardware connection
● A separate communication cable is required to establish communication between
Controller (EPOS or VCU). and external PC. The communication cable should be
connected to the excavator/Wheel Loader’s maintenance connector and user PC’s Serial
port. Create your own diagnostic cable, look at my pin layout. Can be used with usb to serial adapter.
abdul.khaliq
Member
347
#2
doosanjan dear i am download DMS successfully bu i have problem during installation. see attache file and kindly solve the problem
