bsnss
198
49,445
Doosan Data Monitoring System (DMS-3) v1.41 English
If you download this document, you will be lost 150 Gallons
Win | 71 MB​
The Doosan Excavator/Wheel Loader Monitoring Program (also called “DMS-3”) offers the following functions by connecting Controller (EPOS or VCU) with the user’s IBM PC compatible PC.
1. Monitoring: You can monitor the current status of equipment installed with Controller (EPOS or VCU).
2. Graph Output: The major excavator/Wheel Loader sensor data will be displayed in a graph format. The data can be saved in the hard disk. You can check the excavator/Wheel Loader’s performance through data comparison and analysis.
3. Force Operation: You can use vehicle diagnosis by forcing Controller (EPOS or VCU) outputs.
4. Diagnosis: You can check the real-time and past malfunction history maintained by Controller (EPOS or VCU).
5. History Data: You can analyze the work patterns when using an excavator/Wheel Loader, by checking the operation hours, filter/oil information, and daily operation information.
6. Parameter change protected with code: 18772 (change factory settings). Codes for rpm change/force operation and flash epos: 11830 and/or 18675.
Hardware connection: A separate communication cable is required to establish communication between Controller (EPOS or VCU). and external PC. The communication cable should be connected to the excavator/Wheel Loader’s maintenance connector and user PC’s Serial port.
Homepage -
Code:
http://www.doosan.com
Requirements:
- O.S.: Windows XP; Windows Vista; Windows 7; Windows 8
- CPU: Pentium/Athlon 1.8 GHz or higher
- RAM: 256 MB of system memory
- Hard Drive: 100 MB of available space
- CD-ROM
Doosan Data Monitoring System (DMS) 1.41 - supplies following functions by carrying out the communication with the e-EPOS controller installed to an excavator and PC of a user.
Monitoring - monitors the current information/data which e-EPOS controller has.
Graph - shows the major sensor data of excavator as a graph, and can save the data to the hard disc, making it possible to check the status of the excavator by analyzing and comparing.
Test - carry out various simulation by activating the output signal from e-EPOS controller by force.
Diagnosis - shows current failure information and past ones which e-EPOS controller has.
History - enables to analyze the working trend or style, which shows the operating hours as per each work mode and used hours of filter & oil.
Supported languages: English, Korean.
The DMS-3 program support the following excavator and wheel loader models.
Doosan Excavator
No Model name
DX140LC-3
DX140LCR-3
DX140W-3
DX170W-3
DX180LC-3
DX190W-3
DX210W-3
DX210LCR-3
DX225LC-3
DX255LC-3
DX300LC-3
DX340LC-3
DX350LC-3
DX350LCY-3
DX380LC-3
DX420LC-3
DX490LC-3
DX700LC-3
DX140LC-5
DX140LCR-5
DX180LC-5
DX220LC-5
DX230LCN-5
DX230LCR-5
DX250LC-5
DX300LC-5
DX340LC-5
DX380LC-5
DX420LC-5
DX490LC-5
DX140W-5
DX170W-5
DX190W-5
DX210W-5
Doosan Wheel loader
No Model name
DL200-3
DL250-3
DL300-3
DL300-3 (eMCV)
DL350-3
DL350-3 (eMCV)
DL400-3
DL400-3 (eMCV)
DL450-3
DL450-3 (eMCV)
DL550-3
DL550-3 (eMCV)
DL200-5
DL250-5
DL300-5
DL300-5 (eMCV)
DL350-5
DL350-5 (eMCV)
DL400-5
DL400-5 (eMCV)
DL450-5
DL450-5 (eMCV)
DL550-5
DL550-5 (eMCV)
DX120-9C
DX220LC-9C
DX340LC-9C
DX380LC-9C
DX420LC-9C
DX500LC-9C
DX190WA
DX210WA
DX225LCA
DX225NLCA
DX260LCA
DX300LCA
DX340LCA
DX420LCA
DX480LCA
DX700LCA
DX55W-5 Korea
DX55W-5 China
DX55W-5 EU
DX55-5 Korea
DX55-5 China
DX55-5 EU
