Hyundai
85
171,303
Danfoss Variable Displacement Pumps MP1 Service Manual AX179786484978en-000305
Brand: Danfoss
Type of Machine: Variable Displacement Pumps
Model: Danfoss MP1 Variable Displacement Pumps
Part Number: AX179786484978en-000305
Number of Pages: 73 Pages
Introduction
Hydrostatics Servicing Overview​
General instructions​
Safety Precautions​
Symbols used in Danfoss literature​
Technical specifications
MP1 design specifications​
MP1 technical data​
MP1 operating parameters​
MP1 fluid specifications​
Operation
MP1 high pressure relief valve (HPRV) and charge check​
Bypass Function​
MP1 charge pressure relief valve (CPRV) function​
Loop flushing valve​
Electrical displacement control (EDC)​
Swashplate Angle Sensor for EDC Controls​
Manual displacement control​
Forward-neutral-reverse (FNR) electic control​
Non Feedback Proportional Electric Control (NFPE)​
Non-Feedback, Proportional Hydraulic (NFPH) Control​
Automotive Control (AC)​
Control-Cut-Off valve (CCO valve)​
Displacement limiter​
Speed sensor​
Temperature Sensor Data​
Operating parameters
Input Speed​
System Pressure​
Charge Pressure​
Charge Pump Inlet Pressure​
Case Pressure​
Temperature​
Viscosity​
Fluid and filter maintenance
Filtration System​
Pressures measurements
MP1 port locations and gauge installation​
Initial startup procedure
General​
MP1 start-up procedure​
Troubleshooting
Overview​
Safety precautions​
Electrical troubleshooting​
System Operating Hot​
Transmission Operates Normally in One Direction Only​
System Does Not Operate in Either Direction​
System noise or vibration​
Neutral Difficult or Impossible to Find​
Sluggish System Response​
Adjustments
Pump adjustment​
Standard Procedures​
Charge Pressure Relief Valve​
Displacement Limiter​
Control Neutral Adjustment​
Mechanical/Hydraulic Neutral Adjustment​
Minor repair
MP1 standard procedures and pump removal​
EDC Control​
MP1 control solenoids/actuator housing replacement​
MDC Control​
Automotive control​
Charge Pump​
High Pressure Releif Valve (HPRV)​
Charge Pressure Relief Valve (CPRV)​
MP1 loop flushing removal (28/32 pictured)​
Shaft Removal​
Fastener size and torque chart
Fastener size and torque​
MP1 plug size and torque​
