Hyundai
84
168,834
Danfoss Bent Axis Motors H1B060 to H1B250 Repair Manual AX00000153en-000702
Brand: Danfoss
Type of Machine: Bent Axis Motors
Type of Manual: Repair Manual
Model: Danfoss H1B060 H1B080 H1B110 H1B160 H1B210 H1B250
Part Number: AX00000153en-000702
Number of Pages: 77 Pages
Introduction
About this manual​
General Instructions​
Safety precautions​
Symbols used in Danfoss literature​
Disassembly
Proportional controls disassembly​
Two-position controls disassembly​
Disassembly of controls with PCOR​
Electric proportional controls M1CA/M2CA and L1BA/L2BA​
Electric proportional controls D1MA/D2MA and K1KA/K2KA​
Two-position controls T*D* and P*D*​
Two-position controls T*G* and P*G*​
Two-position control E*AA​
Two-position controls HEHE and HFHF​
Two-position control THHA​
Two-position control THHB​
Two-position control DHMA​
Two-position control DHMH​
Two-position control KHKA​
Two-position control KHKH​
Two-position controls MHCA and LHBA​
Minimum displacement limiter​
Maximum displacement limiter—two-position control​
Speed Sensor​
Servo piston cover—proportional controls​
Loop flushing spool and charge relief valve​
End-cap and servo piston—proportional control​
End cap and servo piston—two-position controls​
Cylinder block and sync Shaft assembly​
Shaft assembly​
Inspection
Overview​
Shaft assembly​
Pistons and piston rings inspection​
Synchronizing shaft​
Cylinder block​
Bearing plate​
Valve segment​
Endcap​
Housing​
Control shuttle valve​
Optional Minimum displacement limiter​
Servo piston​
Control​
Assembly
Overview​
Piston ring​
Shaft in housing​
Pistons and cylinder block​
Bearing plate​
Servo piston and valve segment—proportional control​
Servo piston and valve segment—two position control​
End-cap assembly​
Loop flushing charge relief valve and spool​
Shaft seal​
Servo cover—proportional control​
Speed sensor​
Electric proportional controls D1M1/D2M2 and K1K1/K2K2​
Proportional controls installation​
Two-position controls installation​
Controls with PCOR installation​
Start-up Procedures
Overview​
Initial startup procedures​
Adjustments​
Pressure measurements​
Port locations
Ports and Gauge Information​
Torque chart
Fasteners and plugs​
Fastener size and torque chart​
Plug size and torque chart​
