Combilift Forklift CB4000 Parts Manual
- Download this document, you need 750750 Gallons
Brand: Combilift
Type of Machine:
Model: Combilift CB4000 Forklift
Mainframe - I
Left Hand Side Swivel
Front Wheel Motor
Front Slave Steering Cylinder
Right Hand Side Swivel
Front Master Steering Cylinder
Steering Valve
Mainframe - II
Tilt Cylinder
Rear Swivel
Rear Wheel Motor
Rear Steering Cylinder
Diesel Radiator/Oil Cooler
LPG Radiator/Oil Cooler
Bonnet
Hydraulic Tank
Brake Valve
Diesel Tank
Gas Bottle Carrier
Cabin - I
Inch Brake Pedal
Valve Chest - I
Valve Chest - II
Steering Motor
Cabin - II
Cabin Heater
Cabin Door
Cabin - III
Air Conditioning Unit
Dash
Dash PLC, Fuses & Relays
Diesel Exhaust
LPG Exhaust
Pump/Bell Housing
Drive Block Valve
Kubota Diesel Engine
Kubota Diesel Air Filter
Kubota Diesel Engine Control Unit
Kubota Diesel Oil Pan
Kubota Diesel DPF Muffler Sensors & Pressure Pipes
Kubota Diesel Injector & Wire Harnesses
Kubota Diesel Oil Separator
Kubota LPG Engine
Kubota LPG Air Filter
Kubota LPG Inlet Manifold
Kubota LPG Exhaust Manifold
Kubota LPG Regulator & Lock Off Valve
Kubota LPG Oil Pan
Kubota Air Conditioning
Wheels & Tyres
Diesel Cables, Looms & Fuses
LPG Cables, Looms & Fuses
Mast Mounted Brake Valves
3/8" 6-Port Diverter Valve
Cut-Out Solenoid Valve
Hydraulic Accumulator
Mast & Mounted Extras
Wide Hydraulic Fork Positioning
Standard Hydraulic Fork Positioning
Steering Motor & Valve Chest Feed & Return Lines
Pump Feed & Return / Air Breather Lines
Steering Motor Lines
Purge & Oil Cooler Lines
Front Motor Drive Lines
Front Motor Bleed & Break Lines
Rear Motor Drive Lines
Rear Motor Bleed & Brake Lines
Inching Valve & Brake Valve Lines
Front Steering Cylinder Lines
Rear Steering Cylinder Lines
Tilt Cylinder Lines
Fork Positioning Cylinder Lines
Fork Positioner, Side Shift & Lift Lines
Tilt Cylinder Lines
Brand: Combilift
Type of Machine:
Mainframe - I
Front Wheel Motor
Steering Valve
Mainframe - II
Tilt Cylinder
Rear Swivel
Rear Wheel Motor
Bonnet
Hydraulic Tank
Brake Valve
Diesel Tank
Gas Bottle Carrier
Cabin - I
Inch Brake Pedal
Valve Chest - I
Valve Chest - II
Steering Motor
Cabin - II
Cabin Heater
Cabin Door
Cabin - III
Dash
Diesel Exhaust
LPG Exhaust
Pump/Bell Housing
Drive Block Valve
Kubota LPG Engine
Kubota LPG Oil Pan
Wheels & Tyres
Tilt Cylinder Lines
Tilt Cylinder Lines
- Combilift Forklift AME Parts Manual
- Combilift Forklift C14000J Parts Manual
- Combilift Forklift C2500 Parts Manual
- Combilift Forklift C3000 Parts Manual
- Combilift Forklift C4000 Parts Manual
- Combilift Forklift C4000E Parts Manual
- Combilift Forklift C4000ET Parts Manual
- Combilift Forklift C5000XL Parts Manual
- Combilift Forklift C8000 Parts Manual
- Combilift Forklift CB3000 Parts Manual
- Combilift Forklift MR Operators Manual
- Combilift Forklift MR Parts Manual
- Combilift Forklift MR4 Operators Manual
- Combilift Forklift MR4 Parts Manual
- Combilift Forklift STE Parts Manual
