158
643,127
Combilift Forklift C4000 Parts Manual
Brand: Combilift
Type of Machine: Forklift
Model: Combilift C4000 Forklift
List of Files:
CM4K00.pdf (165 Pages)
CM4A0.pdf (139 Pages)
Air Conditioning
Air Conditioning Unit
Air Filter
Appendix 1: Routine Maintenance Parts
Bleed Block
Bonnet
Brake Diverter Valve
Cabin - I
Cabin - II
Cabin - Insulation & Accessories
Cabin Door
Cabin Fuses, Loom & Electrical Extras
Cabin Heater Hoses
Chain Drive Mast Carriage
Chain Drive Mast Carriage Cylinder
Cut-Out Solenoid Valve
DPF Muffler Sensors & Pressure Pipes
Diesel Tank
Drive Block Valve
Drive Pump And Coupling
Drive Pump Feed & Return (Oil Cooler) Lines
Drive Pump To Inch Valve, Brake Valve & Tank
Engine Loom & Fuses
Exhaust
Fork Positioner Lines (Elecar Mast With Flow Divider)
Front Motor Bleed & Brake Lines
Front Motor Drive Lines
Front Steering Cylinder
Front Wheel Motor
Hydraulic Accumulator
Hydraulic Oil Flow Divider
Hydraulic Tank
Inch Brake Pedal
Injector & Wire Harnesses
Joystick Dash
Joystick Valve Chest - I
Joystick Valve Chest - II
Joystick Valves
Left Hand Side Swivel
Lever Dash
Lever Valve Chest - I
Lever Valve Chest - II
Lift & Auxiliary Section Lines
Mainframe - Chain Drive Mast Carriage
Mainframe - Left Hand Side
Mainframe - Left Hand Side Optional Extras
Mainframe - Right Hand Side
Mainframe - Right Hand Side Optional Extras
Mast & Mounted Extras
Mast Side Shift Cylinder - Optional Side Shift Mast
Mast Tilt Cylinder
Mast Tilt Cylinder - Optional Side Shift Mast
Oil Pan
Oil Separator
Optional Joystick/Valve Chest Lines - I
Optional Joystick/Valve Chest Lines - II
Optional Joystick/Valve Chest Lines - III
Optional Joystick/Valve Chest Lines - IV
Radiator/Oil Cooler
Reach Cylinder Lines
Rear Arm
Rear Arm Steering Cylinder
Rear Motor Bleed & Brake Lines
Rear Motor Drive Lines
Rear Wheel Motor
Right Hand Side Swivel
Side Shifting Mast Carriage
Standard Hydraulic Fork Positioning
Standard Mast Carriage
Steering Cylinder Lines
Steering Motor
Steering Motor & Valve Chest Feed & Return Lines
Steering Motor Lines
Steering Valve
Three-Port Diverter Valve
Tilt Cylinder Lines
Wheels - Non-Marking Tyres
Wheels - Super Elastic Tyres
Wide Hydraulic Fork Positioning
