158
643,127
Combilift Forklift C2500 Parts Manual
Brand: Combilift
Type of Machine: Forklift
Model: Combilift C2500 Forklift
Number of Pages: 157 Pages
Mainframe - Left Hand Side
Mainframe - Right Hand Side
Mainframe - Optional Extras
Rear Swivel
Radiator/Oil Cooler - GM LPG
Radiator/Oil Cooler - Kubota Diesel
Radiator/Oil Cooler - Toyota LPG
Bonnet
Hydraulic Tank
Diesel Tank
Gas Bottle Carrier
Cabin - I
Cabin - II
Cabin - III
Cabin Door
Cabin Optional Extras
Air Conditioning Unit
Inching & Accelerator Pedal
Diesel Exhaust
LPG Exhaust - Tier 1
LPG Exhaust - Toyota
LPG Exhaust - Tier 4 PSI
Air Filter
4-Port Changeover & 6-Port Diverter Valves
Bleed Block & Brake Valve
Electromech Lock Valve Chest
Steering Motor
Steering Cylinders
Carriage, Tilt, Side Shifting Mast & Fork Positioner Cylinders
Wheel Motors
Engine/Pump - LPG
Engine - GM LPG Impco EU Non Certified
LPG Supply System
Exhaust Manifold - LPG
Engine/Pump - Toyota LPG
Engine - Toyota LPG
LPG Delivery System - Toyota LPG
Manifolds - Toyota LPG
Ignition Coil, Distributor & Leads - Toyota LPG
Engine - LPG PSI Tier 4
Exhaust Manifold - LPG PSI Tier 4
Mixer, Throttle & EPR - LPG PSI Tier 4
Regulator & Lock Off Valve - LPG PSI Tier 4
Ignition Coil, Distributor & Leads - LPG PSI Tier 4
Fuse Box/ECU/Wiring Loom - LPG PSI Tier 4
Pump/Engine Coupling - Diesel
Engine - Diesel
Dash - I
Dash - II
Mast & Mounted Extras
Hydraulic Accumulator
Cut-Out Solenoid Valve
Wheels - Standard Tyres
Wheels - Non Marking Tyres
Mast Carriage
Standard Hydraulic Fork Positioning
Wide Hydraulic Fork Positioning
Engine - Diesel
Dash - I
Dash - II
Mast Carriage
