158
643,127
Caterpillar Engine C13 Parts Manual SEBP4130-34
Brand: Caterpillar
Model: Caterpillar C13 Engine
Serial Number: LGK1-Up, RRA1-Up
Part Number: SEBP4130-34
Publication Date: 2011
Number of Pages: 1077 Pages
Repair Alternatives
Supplemental Coolant Additives
Maintenance Parts
Index
Engine Arrangement
Engine Ar-Complete
Engine Ar-Core
Basic Engine
Actuator Gp-Valve
Adapter Gp-Auxiliary Drive
Adapter Gp-Engine To Tmsn
Adapter Gp-Engine To Xmsn
Air Compressor Gp
Base Gp-Valve Cover
Belt-Serpentine
Camshaft Gp
Clutch Gp
Compressor & Mtg Gp-Refrig
Compressor Gp-Refrigerant
Cover Gp-Cylinder Block
Cover Gp-Flywheel Housing
Cover Gp-Front Housing
Cover Gp-Valve Mechanism
Crankshaft Gp
Cylinder Block As
Cylinder Block Gp
Cylinder Head As
Cylinder Head Gp
Damper & Pulley Gp
Damper Gp
Drain Gp-Engine Oil
Drive Gp-Accessory
Drive Gp-Fan
Fastener Gp-Cylinder Head
Fastener Gp-Damper & Pulley
Fastener Gp-Flywheel
Fastener Gp-Front Housing
Fastener Gp-Stub Shaft
Fitting Gp-Air Compressor
Flange Gp-Output Shaft
Flywheel Gp
Gear Gp-Front
Gear Gp-Rear
Governor Gp-Air Compressor
Housing Gp-Flywheel
Housing Gp-Front
Kit-Crankshaft Bearing
Lifter Gp-Valve
Lifting Gp-Engine
Lines Gp-Air Compressor
Mounting Gp-Alternator
Mounting Gp-Belt Tensioner
Mounting Gp-Fan Drive
Mounting Gp-Refrigerant
Compr
Mounting Gp-Valve Mechanism
Pan Gp-Oil
Piston & Rod Gp
Plug Gp-Air Compressor
Plug Gp-Cylinder Block
Plug Gp-Engine
Plug Gp-Flywheel Housing
Power Take-Off Gp
Pulley As-Idler
Pulley Gp
Pulley Gp-Alternator
Pulley Gp-Crankshaft
Pulley Gp-Fan & Alt Drive
Pulley Gp-Fan Drive
Pulley Gp-Idler
Pulley-Alternator
Rocker Arm Gp
Seal Gp-Crankshaft
Shaft Gp-Stub
Support Gp-Engine
Support Gp-Power Take-Off
Support-Front
V-Belt Set
Valve Mechanism Gp
Lubrication System
Base Gp-Oil Filter
Cover Gp-Oil Filter Base
Filler Gp-Engine Oil
Filter Gp-Engine Oil
Fumes Disposal Gp
Gauge Gp-Oil Level (Dipstick)
Lines Gp-Engine Oil
Lines Gp-Turbocharger Oil
Pump Gp-Engine Oil
Adapter Gp-Fan
Coolant Conditioner Gp
Cooler Gp-Engine Oil
Cooler Gp-Transmission Oil
Core Gp-Oil Cooler
Cover Gp
Fan Gp-Blower
Fan Gp-Suction
Filter As-Coolant Conditioner
Flange Gp-Oil Cooler
Lifter Gp-Valve
Lifting Gp-Engine
Compr
Pan Gp-Oil
Piston & Rod Gp
Plug Gp-Engine
Power Take-Off Gp
Pulley As-Idler
Pulley Gp
Pulley Gp-Fan Drive
Pulley Gp-Idler
Pulley-Alternator
Rocker Arm Gp
Seal Gp-Crankshaft
Shaft Gp-Stub
Support Gp-Engine
Support-Front
V-Belt Set
Valve Mechanism Gp
Lubrication System
Base Gp-Oil Filter
Fumes Disposal Gp
Lines Gp-Engine Oil
Pump Gp-Engine Oil
Adapter Gp-Fan
Core Gp-Oil Cooler
Cover Gp
Fan Gp-Blower
Fan Gp-Suction
Lines Gp-Water
Plug Gp-Engine Oil Cooler
Pump Gp-Water
Radiator Gp
Valve-Manual
Air Inlet And Exhaust System
Adapter Gp-Air Cleaner
Adapter Gp-Turbocharger Air
Air Cleaner Gp
Cap As-Air Cleaner
Cap As-Rain
Connection Gp-Exhaust
Elbow Gp-Air Inlet
Elbow Gp-Exhaust
Elbow-Exhaust
Fitting Gp-Exhaust
Flange Gp-Exhaust
Kit-Exhaust Parts
Lines Gp-Air
Manifold Gp-Exhaust
Manifold Gp-Inlet
Mounting Gp-Precooler
Muffler Gp
Pipe Gp-Exhaust
Plug Gp-Air Inlet Manifold
Precleaner Gp
Shutoff Gp-Air
Turbocharger Gp
Fuel System
Cooler Gp-Fuel
Cover Gp-Fuel Filter Base
Fastener Gp-Fuel Lines
Filter Gp-Fuel
Filter Gp-Primary Fuel
Filter Gp-Water Sep & Fuel
Fitting Gp-Fuel Lines
Injector Gp-Fuel
Lines Gp-Flexible Fuel
Lines Gp-Fuel Filter
Pump Gp-Fuel Injection
Pump Gp-Fuel Prm & Prim Filter
Pump Gp-Fuel Prm & Water Sep
Pump Gp-Fuel Transfer
Shutoff Gp-Manual
Valve Gp-Check
Valve Gp-Fluid Sampling
Valve Gp-Fuel Bypass
Electrical And Starting System
Alternator Gp-Charging
Atomizer Gp-Ether
Battery Gp
Cable Gp-Battery
Connection Gp-Electrical
Control & Mtg Gp-Engine Elek
Control Gp-Auto Start/Stop
Control Gp-Electronic
Control Gp-Engine Electronic
Control Gp-Engine Speed
Control Gp-Remote Speed
Control Gp-Unprogrammed
Converter Gp-Electrical
Fastener Gp-Wiring Harness
Guard Gp-Alternator
Harness As-Panel
Harness As-Wiring
Heater Gp-Jacket Water
Lubricator Gp-Air Motor
Module Gp-Interface
Motor Gp-Electric
Mounting Gp-Circuit Breaker
Plate As-Brush
Sensor Gp-Coolant Level
Sensor Gp-Engine
Sensor Gp-Liquid Level
Sensor Gp-Position
Sensor Gp-Pressure
Sensor Gp-Speed
Sensor Gp-Temperature
Silencer-Air Starting
Starting Aid Gp-Ether
Starting Motor Gp-Air
Starting Motor Gp-Electric
Support Gp-Battery
Switch Gp-Magnetic
Switch Gp-Toggle
Valve Gp-Air Starting
Valve Gp-Ether Starting
Wiring Gp-Alternator
Wiring Gp-Electronic Control
Wiring Gp-Engine
Wiring Gp-Unit Injector
Actuator Gp-Pump
Mounting Gp-Pump
Pump & Mounting Gp
Pump & Mtg Gp-Hydraulic
Pump Gp-Gear
Pump Gp-Hydraulic
Rotating Gp-Pump
Valve Gp-Pump Control
Valve Gp-Relief
Enclosures, Guards And Bases
Base Gp-Engine
Plug Gp-Shipping
Pump Gp-Charge
Operator Station
Ammeter Gp
Control Gp-Unprgmed Monitor
Gauge Gp-Coolant
Temperature
Gauge Gp-Engine Oil Pressure
Gauge Gp-Fuel Level
Gauge Gp-Fuel Pressure
Meter Gp-Service
Module Gp-Display
Mounting Gp-Instrument
Mounting Gp-Instrument Panel
Mounting Gp-Tachometer
Panel Gp-Instrument
Tachometer Gp-Electric
Voltmeter Gp
Service Equipment And Supplies
Chart-Plate & Film
Cover Gp-Shipping
Kit-Fuel Priming Pump
Plate & Film Gp
Part Number Index
