CAT SIS Release Notes
SIS has been tested using Microsoft Internet Explorer 7.0/8.0 on these platforms:
Windows XP
Windows Vista
Windows 7.0
2011B Release Notes:
Added fly over translation text for standard part names in the parts list when the SIS interface language is other than English.
Parts searches that result in a Type 1/Type 2 scenarios will use new data to accentuate the part that is specific to the serial number enlisted in the search.
Updated to a new 3D graphic plug in.
Enhancements for integration with the PartsStore application.
"As Shipped Engine" has been changed to "As Shipped Product". The "As Shipped Product" functionality will enhance filtering for all products instead of as shipped data for engines only.
Serial Number specific parts search capabilities with the option to fall back to serial number prefix only search.
2011A Release Notes:
Migrated all SIS Simplified Interface users to an improved Advanced Interface, enabling access to additional technical information.
2010A Release Notes:
2D graphics and hot-pointing has been added to allow a user on a consist list/graphic screen to click on a numbered callout from the consist list and the reference will be automatically highlighted on the graphic. If a callout on the graphic is not visible, SIS will automatically locate the callout and display it in the graphic to the user.
3D graphics will be added to the consist list/graphic screen. These will enable the user to view more angles and better identify a part with the interactive functionality.
Graphics plug-in necessary for 3D/2D graphics viewing has been added to the Downloads section.
New/updated Dealer logos
SIS 2009B release:
Beginning with the 2009B release, SIS DVD/Network will require an independent license, which will force (or require) a new license be obtained after upgrading to 2009B. SIS will no longer be able use the 2009A or older licenses nor does it inherit from the Service Technician Workbench (STW) or Cat ET (Electronic Technician).
Service Repair Information will have minor changes including twistees to expand/collapse the view for that specific header. Service Repair Information is available through the Document Structure access method. In order to access Service Repair Information through SIS, the SIS Administrator/Service Software Dealer Administrator from the dealership will need to grant access to ALL of the combined information types. The Advanced interface will also need to be selected through the User Preferences section from the Main Menu.
SIS 2009A release:
New Preference setting within SIS for STW integration
STW/SIS Web Integration Default is enabled through SIS Preferences section, displaying the Send to Service Report button. This preference can be turned on and off depending upon your STW usage.
Improved Integration from SIS Web Parts List to STW Service Report
The Send to Service Report option from SIS Parts List now prompts to allow the user options to edit a report that’s already open on the machine, edit a report that is saved on the machine or start a new report.
Hover Text for Consist List
SIS Web now provides hover text displaying code definitions when viewing a consist list saving the technician from scrolling. The code definitions remain displayed at the bottom of the consist list.
Introduction of a New Information Type- Service Repair Information
To improve technician navigation efficiency, we have consolidated five information types (System Operation, Testing & Adjusting, Troubleshooting, Disassembly and Assembly and Specifications) into one called Service Repair Information. On the SIS Main Menu, the user enters the serial number prefix for the equipment to be serviced and selects “Document Structure.” The new information type will display at the top of the screen.
New Commonality Chart references service literature associated with Cat machinery manufactured in the Japan market
The purpose of the Commonality Chart is to display Caterpillar machines that were manufactured for inside the Japanese market. This can be used as a reference between countries. Once the appropriate serial number has been select from the Main Menu, click on the Document Structure access method. You can then select the Commonality Chart from the Configuration screen. The chart will not display if it is not applicable for that equipment.
SIS 2008A release:
Outsourced parts into SIS: Accepts and displays O (outsourced) indicated parts in SIS via the As Shipped Engine access method. This additional data will be made available from the TMI group that currently supplies the As Shipped Engine information to the SIS application
Multiple quantities for same part number into SIS for CCR: Allows the same part number into SIS multiple times, providing they associate a different quantity for each record. SIS Application will display these part numbers with their different quantities in a sorted order
SIS 2007B released December 2007:
New functionality was added to include potential attachments to serial numbers in search results.
SIS 2006B released March 5, 2007:
New functionality was added to the Parts List to provide Related Parts options. This functionality will provide a list of suggested parts based on the users original Parts List.
A new access method, Cat Certified Rebuild Parts Lists, was added. This access method provides CCR parts and updates by segment and operation.
Functionality was added to allow users to store customer and equipment list information.
Minor Fixes
SIS 2006A released July 3, 2006:
There were only minor functional changes for 2006A. Enhancements focused on changes made behind the scenes to increase the stability of SIS Web and the usability of SIS DVD.
Added Simplified Chinese to language preferences for installation, application interface, and data.
Minor Fixes
SIS 2005B released November 7, 2005:
SIS users created with the SIS User Conversion utility can be deleted. See the online help files for more information.
Preference to launch SIS at startup is editable from the configuration dialog. See the online help files for more information.
Back navigation is available to return to the New Information list after viewing a document. See the online help files for more information.
Parts search can be performed again from the parts search results page (advanced interface only).
Two new information types have been added to SIS: "Bench Test Procedures" and "Custom Hydraulic Service." Custom Hydraulic Service used to be located under the "Customer Service Information" information type.
"Guideline For Reusable Parts And Salvage Operations" has been renamed to "Reuse And Salvage Guidelines."
Minor Fixes
SIS 2005A released June 6, 2005:
The Remanufactured Parts Search access method will display all the remanufactured parts available for a given serial number/prefix.
Parts Lists can now be downloaded in XML format.
Maintenance parts lists are available from the Document Structure and Media Search access methods. See the online help files for more information.
A link on the parts consist page will allow kits lookup for the given serial number/prefix. See the online help files for more information.
New Data Privacy Policy.
Minor Fixes
SIS 2004B released November 8, 2004:
All data access methods that were previously available in SIS Windows are available in SIS DVD, with the exception of "Tool Information."
Several new data access methods were added and are available from the main page of SIS DVD. These include "Filter Search," "Similar Parts Search," Service Forms," and "Media Search."
Links on the main page of SIS DVD are replacements for information available through SIS Windows. The Release Notes link replaces the software release notes, and the New Information link replaces the data release notes.
The SIS Users folder and its included tools will no longer be created on the desktop. This has been replaced by a SIS icon that will appear in the system tray when SIS DVD is launched. Clicking on the icon will bring up a menu with options to import users, open the user admin, and configure the data source.
Minimize, maximize, and close functionality was added to the navigation frame of the parts consist page. Also, viewable space was increased for parts and service documents.
For SIS DVD to work properly, TCP/IP will need to be installed on the machine.
Note: More information about each enhancement can be found in a related topic of the User's Guide. Access the User Guide by clicking on "Help" link on the bottom left hand corner of the main page.
Windows XP
Windows Vista
Windows 7.0
SIS 2009B release:
SIS 2009A release:
SIS 2008A release:
Minor Fixes
Minor Fixes
Minor Fixes
Minor Fixes
- CAT SIS 2011B license keys
- JohnDree Service Advisor 4.0 kg Full
- John Deere Service Advisor 4.0 Full
- JCB Service Parts Pro - License Keys
- Caterpillar ET 2012B
- Caterpillar SIS 01-2012 Full
- CAT SIS 2013 Full
- CAT ET 2011A Full
- Cat sis 2012 32/64 Full
- Detroit Diesel Diagnostic Link 7.05 (DDDL 7.05) Full
- CAT Electrical Schematic
- CAT SIS 2010A Full
- Caterpillar ET2014A full
- Cat Electronic Technician CAT 2013A v1.0
- Cat SIS full Iinstallation Guide + SIS 2011B + NetworkSISID 2012
