harris
17
1,660
Cat SIS 2012 3D viewer
AccuGrade 3D Version 6.11 English
This is a self-extracting zip file that contains all the current production software for AccuGrade 3D version 6.11.
Once extracted the software is broken into three main folders with subfolders to help clarify use of the different file types. Software may be in different file types if the component can be updated through the display as well as through Caterpillar ET.
Radio firmware is located in the appropriate folder under the directory “/Radio”.
Note that this firmware requires the installation of MCG Flash, which is also available through the SISweb Download section.
Folder Structure
· Display - Contains the firmware to update display
· Radio - Contains Radio folders that have firmware to update radio.
· Sensors - Contains two folders since some components may be flashed through the Display and Caterpillar ET
· Valve Module - Contains the current A4:M1 and VM410 software
File Type Usage
*.sg1 Update display software
*.s Update sensor components through the display
*.fls Update sensor components through Caterpillar ET.
*.zfimg Update radios through MCG Flash.
Reference "AccuGrade 3D Version 6.11.pdf" for complete list of software and versions
