Casagrande Drill Rig C8 Electrical Hydraulic Schematic Operators Maintenace Manual
Brand: Casagrande
Type of Machine: Drill Rig
Type of Manual: Electrical Hydraulic Schematic, Operators Manual, Maintenace Manual
Model: Casagrande C8 Drill Rig
Number of Pages: 264 Pages
1. Foreword
2. Technical Features
2.1. Nomenclature Of Main Components Of Drilling Rig
2.2. Nomenclature Of Main Boom Components
2.3. Dimension
2.4. Basic Machine
2.5. Propulsion Unit
2.6. Mast
2.7. Rotary Heads
2.8. Clamps
2.9. Rotary Head Accessories
2.10. Winch
2.11. Application Of Injectors And Auxiliary Pumps
2.12. Stabilizers
2.13. Accumulators Precharge
2.14. Tightening Torque Data
2.15. Liquid Supplies Chart
2.16. Flexible Hoses
2.17. Sound Level
3. Intended Use Of The Machine
4. Commands And Controls
5. Operation
Use Of Levers C1 And C2 On Movement Control Panel C
Use Of A44 And A45 Lever On Mobile Control Panel A (Option)
6. Maintenance
A - Occasional Maintenance
A1 Special Inspection Of Wire Ropes
A2 Diesel Engine Maintenance After First 50 Hours Duty
A3 Refuelling And Cleaning Fuel Tank
A4 Cleaning/Washing Of The Machine
A5 Check Efficiency Of Chuck Operation
B - Every 10 Hours
B1 General Inspection Of The Machine
B2 Wire Rope Check
B3 Dry/Oil Bath Air Cleaner Filter Check (Option)
B4 Diesel Engine Oil Level Check
B5 Hydraulic Oil Level Check
B6 Indicator Lamps And Instruments Check
B7 Inspection Of Rotary Translation Chain
C - Every 50 Hours
C1 Greasing
C2 Hose Tensioner Adjustment
Mast With Cylinder
Mast Con Motoriduttore
C3 Wire Rope Maintenance
C4 Crawler Reduction Gear Oil Level Check
C5 Winch Reduction Gear Oil Level Check
C6 First Hydraulic Oil Filter Change
C7 Hydraulic Oil Heat Exchanger , Engine Oil, Intercooler
C8 Chain Tensioning And Trolley Play Adjustment
C9 Chain Lubrication
C10 Head Translation Group, Brake And Reduction Gear Oil Level Check
Brake
Reduction Gear
Gearmotor In Vertical Position
Gearmotor In Horizontal Position
C11 Upperstructure Slewing Group, Brake And Reduction Gear Oil Level Check
Brake
Reduction Gear
C12 Pumps Coupling Gear Oil Level Check
D - Every 100 Hours
D1 Tightness Check Of Nuts And Bolts
D2 Battery Check
E - Every 250 Hours
E1 First Crawler Reduction Gear Oil Change
E2 First Winch Reduction Gear Oil Change
E3 Crawler Track Tension Check
E4 Hydraulic Oil Filter Change
E5 General Inspection Of The Machine
E6 First Head Translation Reduction Gear Oil Level Check
E7 First Upperstructure Slewing Reduction Gear Oil Level Check
E8 First Pumps Coupling Oil Change
F - Every 500 Hours
F1 Diesel Engine Oil Filter Change
F2 Diesel Engine Oil Change
F3 Crawler Inspection And Cooling System Cleaning
F4 Uncovered Gears Lubrication (Upperstructure Slewing)
G - Every 1000 Hours
G1 Filter Cartridge Change And Fuel Prefilter Cleaning
G2 Accumulator Maintenance
H - Every 2000 Hours
H1 Dry/Oil Air Cleaner Cartridge Change (Option)
H2 Crawler Reduction Gear Oil Change
H3 Winch Reduction Gear Oil Change
H4 Crawler Component Wear Inspection
H5 Hydraulic Oil Change
H6 Upperstructure Slewing, Brake And Reduction Gear Group Oil Change
Breake
H7 Head Translation Group, Brake And Reduction Gear Oil Change
Brake
Reduction Gear
H8 Pumps Coupling Gear Oil Change
A - Every 2 Hours
A1 Hydraulic Drifter Greasing
B - Every 10 Hours
B1 T5000, T2000, T2500, T1500 Rotary Head Greasing
B2 General Inspection Of Rotary Head
B3 T1200-6v Rotary Head Levels Check
B4 T5000, T2000, T2500, T1500 Levels Check
B5 Drive Sleeve + Swivel Greasing
B6 Chuck Greasing P114, P200
C - Every 200 Hours
C1 Rotary Head T1200 6v First Oil Change
C2 T5000, T2000, T2500, T1500 Rotary Head First Oil Change
D - Every 1000 Hours
D1 Accumulator Maintenance
E - Every 2000 Hours
E1 Rotary Head Oil Change T1200-6v
E2 Rotary Head Oil Change T5000, T2000, T2500, T1500
7. Transport
8. Disuse And Storage Of Equipment
9. Assembly / Disassembly
10. Disposal Of The Machine
11. Hydraulic / Electrical Diagrams
F_2_Ing.Pdf
Brand: Casagrande
1. Foreword
2.3. Dimension
2.4. Basic Machine
2.6. Mast
2.7. Rotary Heads
2.8. Clamps
2.10. Winch
2.12. Stabilizers
2.17. Sound Level
5. Operation
6. Maintenance
B - Every 10 Hours
B2 Wire Rope Check
C - Every 50 Hours
C1 Greasing
Mast With Cylinder
Brake
Reduction Gear
Brake
Reduction Gear
D - Every 100 Hours
D2 Battery Check
E - Every 250 Hours
F - Every 500 Hours
Breake
Brake
Reduction Gear
A - Every 2 Hours
B - Every 10 Hours
C - Every 200 Hours
7. Transport
F_2_Ing.Pdf
- Casagrande C6XP-2014 Service Manual, Hydraulic and Electrical Drawing, Spare Parts Catalogs
- Casagrande B250 Hydraulic Bore Piling Rig Spare Parts Catalogue
- CASAGRANDE B250 hydraulic bore piling Rig operation and maintenance instruction manual
- Casagrande C6XP Perforadora Instruction & Maintenance Manual 2012
- Casagrande Diaphragm Wall Equipment B125 Use and Maintenance Instruction & Spare Parts B125ZC0251 2005
- Casagrande Piling Rig B125 Electrical Hydraulic Schematic Operators Maintenace Manual
- Casagrande Drill Rig B180 HD Electric Diagram
- Casagrande Drill Rig B180 HD Hydraulic Diagram
- Casagrande Crawler Drill C6 C6ZU0658 Parts Manual
- Casagrande Hydraulic Piling Rig CFA26 Operation and Maintenance Manual
