Carly for BMW v19.66 [Android] + Instruction
Android | 43 MB
Get the most out of your BMW by keeping it healthy, personalized and connected.
With more than 200-thousand happy customers from all over the world you can’t go wrong.
With the Full Version of Carly for BMW you have the Ultimate BMW solution in your hands. All the main functions are activated with unlimited use:
- Diagnostics – Perform a complete health-check of your car’s electronics
- Codings – Get the most out of your BMW
- Parameters – Analyze BMW engine gauges like a Pro
Homepage -
Code:
http://www.mycarly.com
- O.S.: Android 2.3 or higher
- Bluetooth OBD2 adapter
Instruction:
Here is the way to activate the paid options and how to remove the license verification:
Your phone must have root!!
Step 01: Download Lucky patcher(link in txt-file)
Step 02 : Enable the installation from unknown sources by going to settings > security and tap on Unknown sources check-box.
Step 03 : Now navigate to folder where you have placed/downloaded the luckypatcher.apk file and install it.
Step 04 : Now open lucky patcher app and tap on the app whose in-app purchases you want to hack.
Step 05 : Now select the option “Open Menu of Patches” and then select “Create modified apk”.
Step 06 : Now in next window select “Apk rebuilded for inApp and LVL emulation”
Step 07 : Now in next window select “Support patch for LVL emulation” and “Support patch for inApp emulation”.
Step 08 : Now after selecting these two options, just tap on “Rebuild The App” button at the bottom and it will now start creating the patched app.
Step 09 : Once it get finished, tap on ok and exit the app. Now uninstall the app which you selected in lucky patcher for hacking in-app purchases.
Step 10 : Now open the file manager app and navigate to the Android > data > com.android.vending.billing.InAppBillingService.LUCK > Files > LuckyPatcher > Modified > here you will get two folders one will be of the same name of your app and the other one will be named as Keys.
Step 11 : Open the folder which have the name of your app for example, here we have Subway.Surfer because we have patched it. After opening the folder, you will get the modified apk file of your app there.
Step 12 : Now just install this apk file and open it. Now navigate to the store or etc and you will notice that all purchases are changed to 0$.
Step 13 : Purchase anything and now it will open the dialogue box, just select “Save purchase for restore” and tap on the Yes button to purchase the thing.
Step 14 : Voila! the thing is now purchased. Enjoy.
Thanks to the user "google" for this nice and clear description/tutorial!
Lucky-Patcher is used to remove the license verification, should also work with Freedom but i don't had the opportunity to try it out!
____________________________________________________________________________________________
For those having the 'this app are not fully installed' error try this:
Install and open Lucky Patcher
select Rebuild and install in Lucky Patcher
Select the IVINI BMW app
select rebuild
select 'Apk with changed permissions and activities'
Select 'CHECK_LICENSE' and hit the blue 'Rebuild the app' button
Wait for the process to complete
Hit 'Rebuild and install again', open the 'LuckyPatcher' folder, then 'Modified' folder, then 'Carly.for.BMW' folder and finally select and install the Carly.for.BMW Apk.
- Vivid Workshop Data 2015 Fee download
- Multiecuscan 3.6 [04.2017] Full Patch + Instruction
- Actia Multidiag KG 01.2013
- Multiecuscan 3.7 [07.2017] Full Patch + Instruction
- ElsaWin 6.0 Plus VW [01.2017] Multilingual
- VCDS lite VAG-COM 409 + CRACK+ USB Drive
- Vivid WorkShopData v10.2 full KG 1 LINK Download
- Vediamo License KG 05.00.05
- Fiat Multiecuscan 3.5 [2.2017] Full Patch Instruction
- Multiecuscan 3.9 R1+FIX Full Patch + Instruction
- Volvo PTT 2.03.40 With Full
- DVD Software Volvo PROSIS Construction Equipment Manuals and EPC
- Wurth WOW 5.00.12 [04.2016]
- ELSAWin 6.0 AUDI Database [03.2017]
- Autocom Cars & Heavy Duty R1 2016
